Andy's 91' 80q
Re: Andy's 91' 80q
Like a glove!
Mr.
Previous cars:
Previous cars:
Re: Andy's 91' 80q
Glad you kept it! I've been checking out your build. Love the airboxrennenmsports wrote: Mon Nov 03, 2025 1:28 pm Hello again. It’s been a long time. I decided to keep it. Too sentimental. The piston rings went. I’m going to be able to get a short block from Marc in about 6 months. Now that I know which turbine housing I’m going to use I can make the exhaust and intake as well.
rennenmsports
Re: Andy's 91' 80q
Thank you! I worked hard on this. I’m glad you like it. Hopefully it will be ready to tune by the end of Aprilaudifreakjim wrote: Fri Jan 30, 2026 2:16 pmGlad you kept it! I've been checking out your build. Love the airboxrennenmsports wrote: Mon Nov 03, 2025 1:28 pm Hello again. It’s been a long time. I decided to keep it. Too sentimental. The piston rings went. I’m going to be able to get a short block from Marc in about 6 months. Now that I know which turbine housing I’m going to use I can make the exhaust and intake as well.![]()
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
Here’s progress so far. No oval tubing. Can’t get it to fit
do you all run 3” tubing? I’m worried about ground clearance and melting things?
rennenmsports
Re: Andy's 91' 80q
rennenmsports
rennenmsports
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
rennenmsports
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
That is the question
Bonding silicone to aluminum:
Permabond
Polyolefin primer
Permabond cyanoacrylate 105
Permabond
Polyolefin primer
rennenmsports
rennenmsports
Re: Andy's 91' 80q
Re: Andy's 91' 80q
I bypassed going up and around the diff on mine. It is now the first thing that hits anything. I plan on redoing mine to snake around. Your image looks like what I had I mind. 45deg over the CV. I kinda gave up fitting it correctly. Even the same box of amazon pipe but in 2.5
Hanger situation sucks. My rear oem muffler broke at the welds, so it was my quick fix.
I am not happy with my setup.
rennenmsports
Re: Andy's 91' 80q
Yes. A 3” 45 degree slightly cocked will go right through with 2 bolts flanges on both ends to get it out without lowering the subframe or axle. There’s only 1/4” of clearance in a bunch of spots going through though. I’m currently figuring out the mounting situationdspl1236 wrote: Fri Mar 06, 2026 1:01 pm I bypassed going up and around the diff on mine. It is now the first thing that hits anything. I plan on redoing mine to snake around. Your image looks like what I had I mind. 45deg over the CV. I kinda gave up fitting it correctly. Even the same box of amazon pipe but in 2.5Hanger situation sucks. My rear oem muffler broke at the welds, so it was my quick fix.
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
- 70682280128__A94618B9-0B8E-41DB-B75A-29EE7C948027.jpeg (2.25 MiB) Viewed 5325 times
- 70682279011__70E6D2CA-F54F-420E-B965-1336A19FA256.jpeg (3.01 MiB) Viewed 5325 times
- 70628169062__0B883E30-E8A5-465E-9B5C-8C9D1E6EA189.jpeg (2.82 MiB) Viewed 5325 times
- IMG_0280.jpeg (2.54 MiB) Viewed 5325 times
rennenmsports
Re: Andy's 91' 80q
I think I’m going to put this under the passenger side rear seat. Attempting to quiet it down on top of the Flowmaster under the trunk
rennenmsports
Re: Andy's 91' 80q
Flowmaster super 44 3” muffler under the trunk
Biggest one they had that fits.
rennenmsports
Re: Andy's 91' 80q
It came
rennenmsports
Re: Andy's 91' 80q
It fits
rennenmsports
Re: Andy's 91' 80q
Haven’t had much time lately but did make some progress
