Page 5 of 9
Re: Matt's 1995 Casablanca Urs6 Build!
Posted: Thu Apr 02, 2015 7:46 pm
by EDIGREG
Sounds like it's gonna be tight. There's gotta be room for a big cooler on the driver's side...
Posted: Thu Apr 02, 2015 9:03 pm
by CassaUrS6
I'll post pictures tomorrow Ed of why I didn't move it over to that side. I built a 10x6x6 aluminum tank to hold more coolant for the ic system that's in the location of the Stock Ic.
Posted: Thu Apr 02, 2015 10:20 pm
by EDIGREG
Ah, gotcha.
Stock oil cooler doesn't match the rest of the build... I would try to find a way to get fit something bigger, somewhere.
Posted: Fri Apr 03, 2015 4:49 am
So pushy!
Posted: Fri Apr 03, 2015 6:00 am
by EDIGREG
Lol
Just looking out for everyone's best interest
Posted: Fri Apr 03, 2015 9:08 am
by ringbearer
Troof, oil Temps are a bitch to keep under control.
Posted: Fri Apr 03, 2015 9:34 am
by CassaUrS6
Posted: Fri Apr 03, 2015 9:38 am
by mushasho
In front of condensor maybe? Top portion...
Posted: Fri Apr 03, 2015 9:52 am
by CassaUrS6
the hood wouldn't clear a 2'' thick oil cooler, and they don't really make any -10 fitting ones that are less then 2'' thick
Posted: Fri Apr 03, 2015 10:27 am
by ringbearer
Not much extra room.
lots of hours in the fab as is.
Posted: Fri Apr 03, 2015 11:50 am
by amd is the best
I have never had an issue with the factory cooler. Maybe on a road course it would become and issue but on a street/strip car where the most it will be is WOT for 10-20 seconds it will not be an issue.
Posted: Fri Apr 03, 2015 1:00 pm
That's what I've been thinking as well...
Posted: Sat Apr 04, 2015 9:49 am
by EDIGREG
Sure if you're only using WOT for 10-20 seconds then you won't have any issues....is that really the hardest you drive your car??
Any repeated WOT activity like a road course or driving twisties on the street where you're accelerating out of each corner banging off the rev limiter
and the stock cooler is insufficient, specifically with big turbo/higher power band.
Protect the most important parts of your engine!
Posted: Sat Apr 04, 2015 10:42 am
by amd is the best
Optimal oil temp, based on my research is between 230-260°. For as hard as I've ever driven my 200 it has never surpassed these temps.
Some people will just blindly bolt an oil cooler on their cars when it's not needed. Then the oil is below ideal. We'll obvoisly watch temps though.
Posted: Sat Apr 04, 2015 11:06 am
by Marc
amd is the best wrote:Optimal oil temp, based on my research is between 230-260°. For as hard as I've ever driven my 200 it has never surpassed these temps.
if the oil cooler thermostat is working properly even the biggest oil cooler should allow the temps to reach 230F. it doesn't open until around there so the water boils off.
Posted: Sat Apr 04, 2015 11:14 am
by EDIGREG
The AAN has an oil cooler thermostat. A larger cooler will provide better cooling capacity and efficiency, not cause oil to run under operating temp.
Posted: Sat Apr 04, 2015 11:30 am
Obviously 200 20Vs are better at cooling oil than urS4s are.
I never once saw oil temp rise above normal in mine, but I probably just drive like a puss.
I agree on the thermostat statement though.
Posted: Sat Apr 04, 2015 11:38 am
by EDIGREG
loxxrider wrote:Obviously 200 20Vs are better at cooling oil than urS4s are.
Does the 3B have a different cooler?
Posted: Sat Apr 04, 2015 11:51 am
Sarcasm doesn't translate well over the Internet, but I'm not sure? Could be! I was serious about the rest though. Like I said, I probably just drive like a sissy.
Posted: Sat Apr 04, 2015 12:38 pm
by EDIGREG
Oh, lol I see the sarcasm now /duh
Posted: Sat Apr 04, 2015 4:58 pm
by amd is the best
3B's have the thermostat and what looks like a very similar cooler (if not identical). 200's are superior though.
Posted: Sat Apr 04, 2015 5:19 pm
Like ^^^
Posted: Sat Apr 04, 2015 6:00 pm
by EDIGREG
Lol here we go. Get out of the urs6 thread you t44 butt-buddies
Posted: Sat Apr 04, 2015 7:36 pm
by amd is the best
I have no choice but to be involved with this vehicle ED.
Posted: Sat Apr 04, 2015 7:41 pm
Did you purposely capitalize both letters in his name so people would mistake it as the acronym for an unfortunate male problem? That's uncalled for man.
