13 psi be damned, here's a video anyway :-P
http://www.theswansonfamily.us/modules/ ... i_dyno.wmv
WAUG0806
Post by WAUG0806 »
was the exhaust in the stealth mode or loud mode?
Derracuda
Post by Derracuda »
looks good Marc!
fasterthenrs2
Post by fasterthenrs2 »
a4kquattro wrote:13 psi be damned, here's a video anyway :-P
No graph, I guess my hands was shacking to much when im was zooming that in :D
Toxcheap
Post by Toxcheap »
Yup that sounded like a pretty bad leak
sounded like the mic on the camcorder going balistic more than anything. I'm going to pressure test it hopefully tonight.
3bAudios
Post by 3bAudios »
I'll have to take a look a the vid from the quick ride Marc took me on today and if its any good ill post it up.....nice seeing you today Marc. Hayden took me for a ride on the track later...............holy crap.....my neck hurts....but it was fun!!!!
Hi Bill, I cant hotlink to waytek's catalog but they are under fuse products->ATO/ATC Fuse Holders, about 3'rd page of results in. 034 also sells them.
Fun riding around with Haydn at NHIS innit? 8-)
3bAudios
Post by 3bAudios »
lots of fun, i found the holders but they talk about gangs,
FUSE BLOCK 6 GANG NO GROUND or FUSE BLOCK 10 GANG NO GROUND, what does that mean? which one do i need to get, thanks for your help.
"gang" just refers to the number of circuits, eg 6 gang = 6 slots for fuses, etc.
3bAudios
Post by 3bAudios »
ahhh, going by the picture they were all the same, thanks for the clarification.....enjoying the cider Marc?
3bAudios wrote:ahhh, going by the picture they were all the same, thanks for the clarification.....enjoying the cider Marc?
hell yeah :thanks:
pressure tested the intake today, big arse leak at the back of the motor. I have an o-ring that is supposed to seal between the intake pipe and the manifold but the seal isn't there anymore :wtf:
I can't quite fathom how the seal came out but it appears my motor ate it. oh well, only rubber, probably burned up pretty quick!
HT Motorsport
Post by HT Motorsport »
DOH!
timmmy wrote:DOH!
I'm amazed I was still making 13 pounds with that much air leaking out :-o
any more impressions on the catch can?
ShavedQuattro wrote:any more impressions on the catch can?
yes, the thing definitely works as advertised, no question there.
My only problem with it currently is that get a lot of oil splashback up the drain line so I need to install a flap valve or one way valve to make sure the oil doesn't come back up the drain. Other than that the filtration portion of the unit works awesome :)
Just put a low point in the drain line so it holds fluid and doesn't allow air to rush by. Kinda the same idea as your shitter at home :wink:
LOL :lol: :lol:
WAUG0806
Post by WAUG0806 »
I had that thought... seriously might work with some 3/4" copper
Attachment ( 9576 ) : ptrap-hookedup_large.jpg
I just use a 5/16" fuel line, no problems so far.
Muffinpox
Post by Muffinpox »
a4kquattro wrote:pressure tested the intake today, big arse leak at the back of the motor. I have an o-ring that is supposed to seal between the intake pipe and the manifold but the seal isn't there anymore :wtf:
Your motor has a healthy appetite. That's a good sign.
got the o-rings in today, saw 22psi as I forgot I had dialed the hell out of the boost controllers on the dyno. Leak fixed ;)
I actually figured out why the o-ring came out. One of the two nuts holding the bracket to the back of the motor came out which allowed the rear intake pipe to expand and go crooked under boost, probably opening up a significant airgap as pressure increased. Makes total sense now 8-)
3bAudios
Post by 3bAudios »
:woowoo: glad you got it figured out.....was it silly fast at 22 psi??? if i come down there later in the week id like another ride
HT Motorsport
a4kquattro wrote:got the o-rings in today, saw 22psi as I forgot I had dialed the hell out of the boost controllers on the dyno. Leak fixed ;)
Sweet, nice to have an explanation as that really was a wierd one!
Now before you dial back from 22psi....lets go for a spin :)
H
p.s. when are you ehading back to the dyno then? LMK and make it a sensible time so I can tag along and learn something about my future :)
