Page 47 of 106
Re: Taco's 4KTQ 20vt Swap: Project Red Baron - RALLY BASKET!
Posted: Sat Jan 26, 2013 8:38 pm
by AngryTaco
Replaced distributor, welded up ebrake body sheet metal, and fixed alignment from that nasty snow bank yesterday......
I can not
Believe how strong the ebrake is now. It has never been this solid as long as I have owned it. Happiness!
Posted: Sat Jan 26, 2013 11:08 pm
by 85oceanic
SWEEET! Good work man!
Posted: Sun Jan 27, 2013 10:31 am
by mounty
lol. thatd be a hell of a road trip with more than a few stops at the gas pump.
i picked up some small bottles for testing my injectors from harbor freight last night. if only it wasnt so cold outside.. grr
Posted: Sun Jan 27, 2013 2:35 pm
by AngryTaco
You can see why the effectiveness of my ebrake went to hell
Crappy welds but that's because the metal was so thin I kept melting the sheet-metal and had to keep filling in the holes
Posted: Sun Jan 27, 2013 2:41 pm
by DE80q
Not exactly pretty, but im sure that made one hell of a difference!
Posted: Sun Jan 27, 2013 3:25 pm
by AngryTaco
Its pretty much bullet proof with all the filler metal I had to use. There is absolutely 0 flex in the body anymore. Makes me wonder just how well the PO treated this car....
It also helps to have a bucket of snow next to you for when some of the insulation and paint catches fire lol. Only scary part was when the rubber ebrake grommet caught fire from under the car....thats what compressed air is for LOL
Posted: Sun Jan 27, 2013 7:00 pm
by AngryTaco
Should I powdercoat the roof basket black or white? Black will look good but white would go well with the wheels? Thoughts?
Posted: Sun Jan 27, 2013 7:05 pm
by DE80q
I vote black!
Posted: Sun Jan 27, 2013 7:57 pm
by AudiSport4000
White will make the car look like a candy cane......
DO IT WHITE!!!!
Posted: Sun Jan 27, 2013 10:27 pm
by mounty
White sticks out... black blends in... how about red?
Posted: Sun Jan 27, 2013 11:08 pm
by AngryTaco
I dont think red would look good to be honest. Oye I hate decisions
Posted: Sun Jan 27, 2013 11:44 pm
by mounty
A suggestion..
Posted: Mon Jan 28, 2013 7:42 am
by AngryTaco
Oh I know. I was considering red in the beginning but figured that might be a little too much red on the car.
Posted: Mon Jan 28, 2013 7:51 am
by ringbearer
Black. White will be tan/brown unless you clean it all the time
Posted: Mon Jan 28, 2013 7:53 am
by my2000apb
black, itll look dirty any other color
Posted: Mon Jan 28, 2013 8:48 am
by AngryTaco
ringbearer wrote:Black. White will be tan/brown unless you clean it all the time
True. I thought about that and looked at my wheels which still look new from the powdercoater. I think they self clean in the water lol
Posted: Mon Jan 28, 2013 9:21 am
by 85oceanic
I think you should go gun-metal.
Posted: Mon Jan 28, 2013 9:37 am
by pkw
black. white would make it look like a cheap toy, not a real car. imho
Posted: Mon Jan 28, 2013 9:43 am
by mounty
I think black honestly. Idk how often you think about changing wheels on it. But they might not be white all the time.
Plus the roof rails are already black arent they?
Posted: Mon Jan 28, 2013 11:49 am
by AngryTaco
K weird thing happening with car. Starts fine in the morning no problem. If I let it sit say for the 2 hours I'm in class, I go to start it and I have to crank and crank and crank before it fires. Runs great though. Not throwing codes. I'm thinking I need to re-tune the fuel dizzy perhaps?
Posted: Mon Jan 28, 2013 12:31 pm
by my2000apb
failing fuell pump check valve?
Posted: Mon Jan 28, 2013 12:59 pm
by GTJeff
or leaky injector? What's your system pressure? And rest pressure?
Nice job on the rack. I vote for black.
Posted: Mon Jan 28, 2013 1:03 pm
by AngryTaco
GTJeff wrote:or leaky injector? What's your system pressure? And rest pressure?
system pressure last checked out at approx 115+ psi with relayed pump. I know control pressure was 55psi
Not sure of rest pressure. Is that when pump is off?
Posted: Mon Jan 28, 2013 1:17 pm
by mounty
Yes i belueve so.
2 hours shouldnt be vapor lock. Double check all pressures. If all seems fine tgen check the injectors
Posted: Mon Jan 28, 2013 1:18 pm
by GTJeff
What you might have going on is your injectors leaking into the cylinders quite a bit because your system pressure is so high causing the hard starting. I think it's sort of a classic symptom of having the system pressure set too high. What you might be able to do is back off the fuel pressure some and then go one full turn or so (from where you originally started) on the individual injector adjustments ot make up for some of the flow lost by reducing system pressure. I don't think you want to go more than 1 full turn because you can damage the fuel dizzy.
Yes, rest pressure is when the engine is turned off. It'll decay down over time but if it gets too low it can cause hard starting. Usually caused by a leaky injector.
Oh, yea, and vapor lock is the other thing. Do you have the injector cooling fan working and the shroud installed (I don't see it in the picture....)? It's usually only a problem when the weather is warm though.
