Page 6 of 9
Re: Aarons RWD car - 5/31: Front struts placed.
Posted: Sun Nov 16, 2014 11:23 pm
by speeding-g60
so imma put this up to the now.
June 6th (i put these up on another forum, copy/paste with dates ;) )
speeding-g60 wrote:started the fronts.
Posted: Sun Nov 16, 2014 11:24 pm
by speeding-g60
June 15th.
speeding-g60 wrote:Pinto rack in and done, tie rods made, rack mounts built, diagonals in. also got the body all mounted to the cage, and played around with an empty motor just looking at things, seeing how its going to look in there.
Posted: Sun Nov 16, 2014 11:25 pm
by speeding-g60
June 15th again.
speeding-g60 wrote:and played a little with an empty block/head to see how things look. the front plate is lexan just to make it easy to mess around with, once i get the exact location and what i want i will transfer it to aluminum and make the actual plate. stock intake manifold, again to visualize location and interference issues. i have an intake that is a stock replacement in mind, but it may not actually work out ideally for this setup. we will see.
but DAMN there is a lot of room in there. i think if the 4 cylinder doesnt do what i want it to do (and it should) or i get the yearning for more (we NEVER do that do we? haha) i will entertain the idea of an Audi 40v 4.2L V8 motor with twin turbos in its place. keep it Audi/Volkswagen at least for the motor, be different, whatever.
by speeding-g60
July 11th
speeding-g60 wrote:done a shit load more work, not in this order. this is the latest.
needed some room for tires. so i stretched the rear wheel arches 4" towards the front. the front end will be stretched completely (hood, fenders, etc ) the same 4".
done all of this myself with some pretty good guidance from an excellent chassis builder.
testing a 32" x 14" wide on a 14" wide wheel as this is the size i will probably run when i learn to drive this thing.
both sides done and cut. only driver side reassembled.
putting 3/4" backing strip in so we have something to weld to. sheared all of these strips. and the complicated section at the body moulding area, i used factory material there and split it .
hand formed the filler plate.
as he tacks these spots, he pulls the body work out and then tacks it. to keep its shape and prevent warpage. its not completed yet but it is visually good for clearance. and this is the wheel/tire i will use for the street. 315/60-15 on a 12" wide wheel, aka 30 tall by 13 wide. these are my training wheels so to speak. and YES it will be titled and reg'd and streetable.
then a trial fit with the side skirts. gonna be sorta low there :arco: :o
Posted: Sun Nov 16, 2014 11:26 pm
by speeding-g60
more July 11th.
speeding-g60 wrote:test fitted some engine stuff, like turbo and cell and stuff. made engine front and mid plates, and the front end is now welded out.
Posted: Sun Nov 16, 2014 11:27 pm
by speeding-g60
and even more July 11th. that must have been a big update day for TurboBullet dot com!
speeding-g60 wrote:sighting the mainline to pinion center.
welding the front out (not me)
made the trans mount. also serves as a thrust block of sorts.
Posted: Sun Nov 16, 2014 11:29 pm
by speeding-g60
shit July 11th was a big day for them i guess :P :guns:
speeding-g60 wrote:set up the turbo for manifold building.
then i put the front hubs and stuff together for good.
worked on center rail supports and mounting the seat.
Posted: Sun Nov 16, 2014 11:33 pm
by speeding-g60
i had surgery on my shoulder on July 9th, so thats how they got power-updated; i was bored as a mofo!. remember, i said long ago if i didnt get interaction i wasnt spending time to update this. no big deal.
but, on the very day of my surgery, i had to be in Portland at like 1:15 or something. ready to get sliced and diced. i worked on the car all morning until the very last minute i could, with barely enough time to get home, shower, and change and leave. that is how dedicated to this i am.
and then, at the end of July, we finally got the new place, so i moved away and have not had a lot of time with the car. been power-building the new shop though, but that is a different thread. i dont rest. perhaps i should have, but oh well, sleep enough when ya dead!
August 21:
speeding-g60 wrote:i have not worked on this since i had shoulder surgery on 7-9-14. BUT i plan to get back to it soon. i did some more, up to 2 hours before surgery even on the very day of surgery.
Needed to open up the rear wheel arches 4″ to fit tires. No big deal. Test fitting the Goodyear 32×14 on a 14 to see how they fit as ultimately I will build towards the future.
This thing is going to be rather low after all haha. I hand made all the pieces to do this, and used factory sheetmetal for the area around the body trim.
this is the 32x14 i will eventually run, mine are the 315/60-15 aka 30x3.50's to start out with.
formed this piece by hand for the gap filler.
Posted: Sun Nov 16, 2014 11:34 pm
by speeding-g60
August 21st:
speeding-g60 wrote:and the sexy little axles came in after about 6 weeks?
Strange 40 spline, rifle drilled, flange lightened and profile milled. i cant believe that was all only $725 shipped!!!!
Sept 4th:
speeding-g60 wrote:put the axles together, popped them in the car (on the wrong sides of course, i dont know this shit!) and got the car off the jig to take it to our show/race this weekend to let people see it, rep a couple sponsors, that sort of thing.
also put the new motor in the AWD chassis, and put it on the dyno to break it in. turned the boost down ~10 psi (from >47 psi back to 38) and made right at the same power as before, almost 760 awhp and a little more torque at right at 570 ft lbs.
i just had shoulder surgery so i cant drive, but i have a buddy who will drive for me this sunday. my son is hyped about the car as well.
Posted: Sun Nov 16, 2014 11:36 pm
by speeding-g60
Sept 9th:
speeding-g60 wrote:I like it naked too. Time to weld this thing out. :o
more from the 9th:
speeding-g60 wrote:version one was very unhappy that it finally got to meet its replacement at the show sunday. i spent a good amount of time and money building a motor JUST to run this one single day this year in support of those who support me. my car is one of their booth cars and the fastest/quickest (usually sans breakage that is) car at the show. but as such, it attempted suicide by trying to eat the wall directly off the line. my driver (i am out this year from shoulder surgery) is a damned good driver, much better than i am i say, and he kept it off the wall. rear diff blew up, took off the top of the housing and spit part of a spider gear.
he did good, kept it off the wall. we got this one single launch and that is ALL for the entire year. bummer, too, cuz we also missed out on 8 pure silver dollars and a few hundo in cash along with trophys and crown. next time.
[youtube]http://www.youtube.com/watch?v=OFSdWlIQ7Dk[/youtube]
Posted: Sun Nov 16, 2014 11:43 pm
by speeding-g60
and now, let me grab the phone to update the thread to THE PRESENT! just steering stuff basically, i think. and brake pedal.
Re: Aarons RWD car - 11-16: Super MEGA update!!!!
Posted: Sun Nov 16, 2014 11:51 pm
by speeding-g60
Phone stuff.
A mole trap shot.
Now we should be all caught up to the "now".
Posted: Sun Nov 16, 2014 11:55 pm
by speeding-g60
Saw the pix of workin the pass side rear quarter.
Posted: Sun Nov 16, 2014 11:57 pm
by speeding-g60
Posted: Tue Nov 18, 2014 12:51 am
So much detail in fulfilling your vision, all the pics make it easy to follow.
I'm especially digging on the fender mods, as I have some UrS fenders I'd like to use up front for some wide/flare action.
Posted: Tue Nov 18, 2014 8:38 am
by scubagli
I can not wait to see this thing hit the track, what are your goals for the car? I really want to see how fast a 1.8t can go.
Posted: Tue Nov 18, 2014 9:50 pm
by speeding-g60
with the AWD car the goal was, for me, 9.50's and under 150 mph. around 145 mph i wanted to go. not >150 where parachute is mandatory, and other stuff.
it went 9.34 and made 5 or 6 passes into the 160's, peaked 167 even. so i made the goals there, pushed for awhile longer, and redesigned my goals.
the calcs show that at raced weight and trapping 167, the car (if it were RWD) was putting down 1033 whp. that was 2680 with driver! the new car is looking to be sub 2000 pounds no driver. couple that with big traction, more power/bigger motor (the AWD car uses the smaller of two race motors i have), the goals set forth should happen with time.
this cars goals are set equally as conservative. trap speeds around 180 mph or so will be plenty for me. and 7.80's are the ET goals. in the long run, not right away. its going to take some time for me to learn how to drive it you know. i didnt get to drive all year this year, the racecar that is.
Posted: Tue Nov 18, 2014 9:53 pm
by scubagli
So awesome, I commend your vision...
Posted: Tue Nov 18, 2014 9:54 pm
by Marc
do we know what the 1.8t powerplant record is, worldwide vs usa?
Posted: Tue Nov 18, 2014 9:58 pm
by speeding-g60
i know of a couple 1000+ whp (FWD) ones on the East Coast.
the first one that i know of to hit 9 bills was Joel Brown in his Rado drag car. 934 whp/720 wtq.
Posted: Wed Dec 03, 2014 2:15 pm
by speeding-g60
Worked on it over the last few weekends..... finished building my gas pedal. Started tin work with cardboard templates then actual tin. Driver side is steel welded in and pass side is aluminum dzus tabbed removable.
Was about to weld in the driver side but needed to make the drive shaft loop and enclosure stuff first.
And tin work.
And transferred to steel.
And tunnel work.
Posted: Wed Dec 03, 2014 2:32 pm
by speeding-g60
i dont know why i get doubles posting from Tap-a-talk.
Re: Aarons RWD car - 12-3: Tin work has begun
Posted: Wed Dec 03, 2014 10:46 pm
by ringbearer
That is a work of art
Posted: Sun Dec 07, 2014 12:12 pm
by speeding-g60
Drive shaft enclosure in chromoly done. Modular and removable top and bottom pieces. Welded in the first three pieces of tin. Put some bracing for weight bearing where driver feet go getting Into the car. Started the driver floor. Put center belt tab in.
Re: Aarons RWD car - 12-7: driveshaft enclosure done
Posted: Sun Dec 14, 2014 9:26 pm
by speeding-g60
Well it's sunday so Saturdays update.
Finished the driver side floor. Welded down. It's the only side that has to be steel the rest is aluminum and removable. Also made some little pieces to fill some triangulation braces. Little details. ....
Also helped some with this 60 Vette. Blown big block on E85. Headrest for cage.
Car sounds mean!!!!!
also, got injectors finally and got the awd car up and running. its about ready for next year! next it goes into the trailer and the Rado project and the Rabbit move inside for good.
[youtube]http://www.youtube.com/watch?v=bWUhtGjAY0w[/youtube]
