Page 57 of 119
Posted: Thu Jan 21, 2010 5:29 pm
by speeding-g60
so the NHRA has made amendments to the cage rules. a different setup for the "D" bars. no more going to the floor. needs to go to the side of the tunnel or to a bar that goes from hoop leg to leg.
funny thing, its so much more work to do now, too. they say you can have plates welded to the rocker panels, and this bar go across the car, and then mount the hoop legs to it. all well and good if i built a cage THIS YEAR! i built it last year, so i gotta change some stuff.
and finally, i do some work on the car.... WOOHOO!!!!!
Posted: Thu Jan 21, 2010 5:31 pm
by speeding-g60
and along with this, imma put the AWIC ice reservoir up on the back seat area like i wanted it in the first place. i thought i would have driver seat convenience by having it in the pass seat area. F-that, its in the way there.
YAY!!!!! i am working on this car!!!!!!
also, unrelated, but i picked up a COMPLETE VR6 longblock for $100.... IM, ex mani, all acc, TB, everything.
and NO ITS NOT GOING IN THIS CAR
Posted: Sat Jan 23, 2010 4:36 pm
by speeding-g60
its no good for me to be bored, have too much time on my hands, and a car to work on
i changed the WG dump tubes, i didnt like them the way they were. JC Whitney to the rescue, with some flex pipe in SS..... ATPTurbo.com for a pair of Tial WG outlet flanges (v-band) and Joey welded them on for me. i just melt thru this thin shit like nobody's business.
also, i figured out what roll cage bars i needed, took some tube to Vanderbecks (local race car builder, he bends the tube for me), just waiting on the call to pick em up. these guys build some bad ass cars..... i am gonna have to schedule a time where i can go out and crawl around under a few of them, get some idears for the next rabbit iteration.
here is a pic or two, nothing much really. have yet to trim the second tube. will make a bracket to mount to the factory front sway bar tab there.
Posted: Sat Jan 23, 2010 9:33 pm
by PRA4WX
Nice idea with the SS flex DP's!! Don't know if I've seen them used on DP's before! Nice work as usual! I can't wait for this season! 8)
Posted: Mon Jan 25, 2010 4:29 pm
by my2000apb
:woowoo: :woowoo:
Posted: Tue Jan 26, 2010 4:24 am
by tsin
you dont affraid of vibration noise of thexe flexs?
Posted: Tue Jan 26, 2010 6:12 am
by my2000apb
tsin wrote:you dont affraid of vibration noise of thexe flexs?
im sure this car makes a lot of noises with a DP coming out of the fender hah
Posted: Thu Jan 28, 2010 4:39 pm
by speeding-g60
the flex tubes are the open dumps for the two wastegates.... i have a dual scroll manifold, thus have two wastegates, one for each paired cylinder set.
i picked up my head today, and happy about that. back to the first head, majorly ported small port head. the 592 AWHP head. added +1mm OS intake valves this trip. still the inconel exhaust, ST springs/retainers, CAT cams. also blended the bowls more, and behind the valves was worked over to about 70 degrees to actually take advantage of the larger valves. then a 3-angle valve job, lap in the valves, cut .007, done. also polished the cam journals while in there.
also working on the changes to the roll cage. i got my cross bar approved, now to get his blessing on the "D" bars and we are in business. first T-n-T is Mar 5, and i am trying to be there. i will wait til the final word/blessing is given on the cage, then i will post pix of the changes.
Posted: Fri Jan 29, 2010 7:17 pm
by speeding-g60
2010 roll cage changes are in effect. my inspector said this is what he wanted to see, and he ran it by the HEAD NHRA Chassis guy in NC.
the AWD falls with RWD category for the trans tunnel, and they want an extra cross bar in the car now. it was this or to 6x6 plates welded to the tunnel SIDES, for the "D" bars, from the hoop/harness bar to the tunnel or floor. i am not done yet, i am going to plate the tunnel top as extra, and tie the bar in front and rear.
Posted: Fri Jan 29, 2010 7:55 pm
by speeding-g60
and because Joey told me so, i pulled the motor for him to go thru it this weekend. anything at all from that last head-lift will be attended to at this time.
cherry picker to remove turbo and manifold? sure makes it easier LOL.
Posted: Fri Jan 29, 2010 9:00 pm
by gtimitch
Man - that is awesome, I love it:
Who built your fuel surge tank - or did you do it? I would like to have a unit container like that.
Please contact me when you have an opportunity, I would like to talk to you if you have time. my email is
fjrmitch@bellsouth.net
From there we can open a line of communication. I look forward to talking to you.
Awesome --- the post finally came through. there is a delay that I'm not accustomed to.... please disregard the Roderic of the following post:
:-) :thanks:
Posted: Fri Jan 29, 2010 9:12 pm
by speeding-g60
hi Mitch
you get ETKA goin?
that is the whole fuel cell in that pic, on the rabbit. not a surge tank. i run a small fuel cell up front of each chassis. eliminates long runs of fuel lines, etc.
and we make ALL ALUMINUM parts on the car... friend and i.
you have my number call me when you need to
Posted: Fri Jan 29, 2010 9:14 pm
by gtimitch
Hybrid_Hatch wrote:speeding-g60 wrote:one thing i am sure someone will have to mention, but the fender trim does not match the door trim.
that is because the fender is from a b4 not a cq or cab
The only way I can respond is to Quote the last person to leave a message.
speeding-g60
Please contact me at
I look forward to talking to you. I can not figure out the post system on this forum. I'm probably overlooking the most obvious but -- none the less ... please contact me so we can continue our conversation --- your car is no less than absolutely awesome.
Posted: Fri Jan 29, 2010 9:22 pm
by gtimitch
Did that make any sense.... I messed it up pretty bad.
I do not have the ETKA running yet and would really appreciate your help --- whenever you have the opportunity. I know you have your hands full of a bundle of joy -- but whenever you have opportunity.
Posted: Fri Jan 29, 2010 9:28 pm
by speeding-g60
in the open window at the bottom of the page.....
then push SUBMIT under that.
Posted: Fri Jan 29, 2010 9:29 pm
by speeding-g60
i will call you tomorrow, got a specific time idea?
will try to meet that agenda.
lets get you online with the TKA cuz its cool
Posted: Sun Jan 31, 2010 6:16 pm
by speeding-g60
and cage is finished. final welded out. added the plate to the tunnel, tied it in. this car will be stiff as a MOFO....
also, while i was at it, i moved the AWIC reservoir to the rear of the car, access was the reason, and boredom.
and the reservoirs new home.
Posted: Sat Feb 06, 2010 8:21 am
by my2000apb
wooooooooooot
Posted: Sat Feb 06, 2010 9:45 am
by Noisy Cricket
It looks like they don't trust the floors anymore, they want a crossbar or the cage mounted to the sides.
GOOD.
Posted: Sat Feb 06, 2010 4:00 pm
by Wizard-of-OD
Whats that green cable running to the boot for Aaron?
Posted: Sat Feb 06, 2010 4:15 pm
by speeding-g60
i already had my rear mounted battery cutoff. the red cable is the power FEED to the front circuit breakers. the green cable is the alternator output, and it goes to the battery side of the cutoff switch. if i connected it to the starter like normal, and the cutoff switch was turned off, the car would stay running from the alternator.....
catch 22. so i just ran the charge wire to the rear.
they do sell the correct switch to make this happen, but i already had this one.
Posted: Sun Feb 28, 2010 6:44 pm
by speeding-g60
so. i have some updates.....
i got my shortblock.
and i took apart the gold motor, but i am sure we can already guess what that news is. ready, ready. yes.
the tool steel tapered end pins i bent them.
the piston wrist pin bores i wobbled them. :?
the rod bushings i wobbled them too. :(
completely wasted it again. full motor. so, i am throwin the dice. putting the big motor in, with the short block made by Issam and the head made by Joey. it is the last straw for my race career. lets hope i can get to the track
cuz once this one is done, so am i.
had some issues with the trans as i went to put axles back in, as well. got it sorted out though.... and that gave me time today to install the NHRA drive-shaft loop. WOOT one step closer. i also got a new radiator and AWIC. but i pressure tested my AWIC to 100 psi and no leaks. all this wrist pin damage is coming from the head lift incidents, water gets in the motor and hydralocked. the weaker ( 0.140 wall) wrist pins broke. the stronger ( 0.180 wall) wrist pins bent. JE has one size larger, @ 0.210 wall. that would probably break the crank knowing my luck LOL.
so to save much needed funds, i skipped rebuilding the hydro motor, straight to solid lifter setup, and pray. i meant it when i said when this one is done so am i.
Posted: Sun Feb 28, 2010 7:00 pm
by zerb
w00t w00t.
10's orrrrrrrr......
9's, no bust.
:woowoo:
Posted: Sun Feb 28, 2010 7:22 pm
by PRA4WX
speeding-g60 wrote: i meant it when i said when this one is done so am i.
:slap: Oh stop it!
You can't stop!
Posted: Thu Mar 25, 2010 11:53 am
Its been nearly a month. I wanna see some monster turbo and solid lifter head updates!
