Page 57 of 83
Posted: Thu Aug 13, 2009 2:55 am
by cuatrokoop
chapel wrote:what will stick out?
the LS2 coils use standard plug wires. the coils are mounted on the firewall.
Then how would they affect running a 7A valve cover? They wouldn't...But yes the 7A should fit an AAN. Same base casting for both heads.
Posted: Thu Aug 13, 2009 8:20 am
by chapel
I guess I wasn't sure what you were getting at will 'stick out'
Posted: Thu Aug 13, 2009 8:22 am
by my2000apb
chapel wrote:I guess I wasn't sure what you were getting at will 'stick out'
i think he thought you were using a COP setup whihc would look all weird with a 7a cover
Posted: Thu Aug 13, 2009 8:25 am
by chapel
Aha, that's what I thought he was getting at too.
Posted: Thu Aug 13, 2009 8:26 am
by my2000apb
chapel wrote:Aha, that's what I thought he was getting at too.
although it wont be much more goofy lookin that the plug wires coming out of the aan vc haaha
Posted: Thu Aug 13, 2009 8:32 am
by chapel
I just like the flatter look and the little vanes that run down it and the old school audi logo
Posted: Thu Aug 13, 2009 10:07 am
by derracuda
aha.. ok. so you would just run long leads back to the firewall. that shouldn't be a problem....
Posted: Fri Aug 14, 2009 12:02 am
by vagrant_mugen
your gonna love the flow of those new manifolds. i just hate to see people running cast units when its really not that expensive to make your own, as well as being pretty fun too.
i like what i see derek........... 8)
Posted: Fri Aug 14, 2009 12:57 am
by naudi80quattro
2nd that you can make so much money making and selling your manifolds too :-)
Posted: Fri Aug 14, 2009 11:22 pm
by Longitudinal
derracuda wrote:header wrap tends to destroy things when it comes to turbo temps.... it keep too much heat in and crystalizes the metal. it's better to have an air gap around the pipes so they don't retain too much heat.
It's not that the metal crystallizes. Metals wouldn't be much without crystals. The crystal structure is able to change (going larger, I believe?) and cause the metal to become more brittle. Whether this is able to happen in a car, I cannot confirm or deny from my own experience, but it definitely DOES happen to metals including stainless steels given enough heat. A friend of mine is a retired electrical engineer for GE and dealt with such problems all the time on power generators.
Posted: Sat Aug 15, 2009 7:40 am
by Hank
A lot of it can be written off as work hardening. As the part goes into compression and tension with heat cycles, it becomes harder and harder, and want to expand less and less. That is a lot of the brittle stage that usually spells the death for headers. Metals that expand an contract less fair better, but head cycles work harden the workpiece as well, and eventually over a long period of time, they will harden as well. The thing they have going for them is that they dont expand to instigate the crack.
Posted: Sat Aug 15, 2009 7:43 am
by my2000apb
ShavedQuattro wrote:A lot of it can be written off as work hardening. As the part goes into compression and tension with heat cycles, it becomes harder and harder, and want to expand less and less. That is a lot of the brittle stage that usually spells the death for headers. Metals that expand an contract less fair better, but head cycles work harden the workpiece as well, and eventually over a long period of time, they will harden as well. The thing they have going for them is that they dont expand to instigate the crack.
a well designed / good flowing cast manifold is a beautiful piece in form and function as many will go hundreds of thousands of miles
Posted: Sat Aug 15, 2009 7:45 am
by Hank
highway miles maybe. I dont believe they will if beat on like most headers do. They typically dont see the heat extremes that headers do as well, and are usually not on extreme high HP appications.
Material Sience is material science.
Posted: Sat Aug 15, 2009 8:55 am
by ChrisAudi80
ShavedQuattro wrote:Material Sience is material science.
Funny you should say that. There was a bit of a discussion a few pages back about trained engineers vs. hands-on self-taught fabrication. The latter insinuated the former was being cocky.
However, if you know about materials science, any engineer would, you will know that when steel or iron gets heated up very high, say 800Celsius, the crystal structure makes the material very hard. That is why it gets brittle. The hardness readings go through the roof unless its stress relieved and made to be ductile again.
One of the reasons SS headers sometimes crack at the welds, is because of these extreme temp swings. Can you imagine what happens if you are out racing, your EGTs hit 1200-1500 and you splash through a deep puddle?
Ductility gone. There is a lot to be said for cast iron EMs and mild steel pipes.
Posted: Sat Aug 15, 2009 9:10 am
by ChrisAudi80
Say Derek, are you going to test the FMIC for flow and temperature distribution over that humongous core?
It should be possible to place some temp tape or even better some thermo couples and hook those up to a laptop. Blow in hot air under pressure with a big fan simulating cooling wind.
Your design is interesting and I saw your statement about effective cooling only taking place of the first 6" of core. I assume you mean in the flow direction.
Anyway, the direction of the air into the IC is quite sharp will the pressure be distributed evenly?
I hope it works.
Your IM work is far out too. Just weld it up like you want to. Who knows what it will do. Seeing what you have done so far, if you are not happy with it, you will tinker more with it. A perfectionist :-)
Posted: Fri Aug 21, 2009 11:19 am
by derracuda
mmm... goodness.
section width/contact patch still is virtually identical, and these tires are about .75" shorter
Posted: Fri Aug 21, 2009 11:39 am
by ChrisAudi80
Can't wait to see this in action again. :-D
Posted: Fri Aug 21, 2009 11:41 am
by WOMBAT
ahhh lookin good sir!
Posted: Sat Aug 22, 2009 3:52 am
by derrish_vulf
Those wheels look great!!
Posted: Sat Aug 22, 2009 9:06 am
by my2000apb
countdown to waterlands?
Posted: Sat Aug 22, 2009 12:24 pm
by derracuda
i dunno if i'm gonna make waterlands :( i'm waiting on my ECU from 034. the block is at the machine shop and i'm hoping to have it assembled this week. i jsut got word my interior might be ready though by the show..... so i could set up my interior at the show and see how that goes
meanwhile i play with the wheels and oogle them.. man, i am happy with these
205's suck
i lowered the front .5" so it has some proper stance finally
man, i love how wide these wheels and tires make the car look.
Posted: Sat Aug 22, 2009 12:42 pm
by my2000apb
derracuda wrote:i dunno if i'm gonna make waterlands :( i'm waiting on my ECU from 034. the block is at the machine shop and i'm hoping to have it assembled this week. i jsut got word my interior might be ready though by the show..... so i could set up my interior at the show and see how that goes
again a case of beauty and the beast, you and aaron, hahaha
it def doesnt sound impossible, judging from what youve put together in a short time. you can do it if the parts come in, wooooot
Posted: Sun Aug 23, 2009 12:08 am
by ChrisAudi80
That FMIC you fabbed looks badass, Derek. Any flow testing done on it?
Are those the runners I can see in the last pic? I can't wait to see what your IM will look like.
Posted: Sun Aug 23, 2009 3:27 am
by derrish_vulf
I mustve missed up but whats the size and et of your ronals??
They look killer with the new tires on :woowoo:
Posted: Sun Aug 23, 2009 11:42 am
by derracuda
derrish_vulf wrote:I mustve missed up but whats the size and et of your ronals??
17x8.5" ET34
