Page 57 of 76
Posted: Tue Apr 08, 2008 2:21 pm
by HT Motorsport
Cool, makes more sense Mark, although you should probably rebuild the box anyway as a spare or a sale item.... or just flog it in need of a rebuild.
I am being selfish as I want to help you rebuild it when i get back to see what they are like inside
H
Posted: Tue Apr 08, 2008 3:30 pm
by Marc
timmmy wrote:Cool, makes more sense Mark, although you should probably rebuild the box anyway as a spare or a sale item.... or just flog it in need of a rebuild.
H
I may rebuild the EDU, but I'll let my credit card cool off first
Posted: Tue Apr 08, 2008 5:49 pm
by fastscirocco
a4kquattro wrote:
EDU
1st 3.5:1
2nd 1.89:1
3rd 1.23:1
4th .96:1
5th .80:1
6th .68:1
DQT
1st 3.5:1
2nd 1.89:1
3rd 1.23:1
4th .87:1
5th .67:1
6th .56:1
Your gear ratios look the 6 Spd 2.5L TDI trans, you can find them on the
ratios on this page
http://www.elektro.com/~audi/01E/
Posted: Tue Apr 08, 2008 5:56 pm
by yodasfro
See told you so............... to get a hold of SD 8)
Posted: Tue Apr 08, 2008 8:17 pm
by Marc
so I've got a thought to make some more room for the passenger side intercooler (it sits too low right now, and there isn't a lot a room for it to go up much further because the alternator is in the way).
I'm thinking about possibly relocating the alternator to the other side of the engine (where the power steering pump used to be). This would actually have a number of advantages:
1) more room for the intercooler
2) REALLY short belt, short enough where I think I can get away without a dynamic tensioner, just some kind of bolt adjustment to tension the belt vs the alternator.
Thankfully the 4.2 block is sitting right here for me to head scratch over without a whole lotta effort.
Posted: Tue Apr 08, 2008 8:30 pm
by HT Motorsport
Yup, s'agoodplan.
Pretty straight forward when you do the 4.2 swap too. You could watercool the alternator too
How about a gear drive with a shaft from the flywheel instead of a belt. No seriousely it wouldnt be too hard. Cut a hole in the bellhousing. weld on a couple of mounting plates, bolt on a pillar block bearing, take the gear off a starter motor and weld it onto a shaft and mount the other end of the shaft to the front or back of the alternator (Dependant on which way it has to turn) with a regular 1/2" drive socket style attachment so it just drops in.
H
H
Posted: Tue Apr 08, 2008 8:33 pm
by Marc
you really are all about that can of worms, aren't you?
interesting idea, although I'm not sure it buys me much since the pulley is already there for serpentine drive and I've got plenty of room in the location where the power steering pump used to be.
Posted: Tue Apr 08, 2008 8:35 pm
by Marc
So Haydn, about that plasma cutter (I'd buy my own, but apparently I'm spending all my money on transmissions and machine shop work) :-P
Posted: Tue Apr 08, 2008 9:10 pm
by HT Motorsport
heheheh.....The plasma ain't so good on Aluminum bellhousings tho, better off with a sawzall.
You know where it is......Ill have to start charging you for tips
Posted: Tue Apr 08, 2008 11:00 pm
by 90'cgnewbie
while your at it, throw in a flywheel driven superchrger like the prototype cummins diesel engines.
Posted: Tue Apr 08, 2008 11:27 pm
by HT Motorsport
For the intercooler you could still go Water to Air and put it up in the fender?
Just a thought....
H
Posted: Thu Apr 10, 2008 9:36 am
by Marc
timmmy wrote:For the intercooler you could still go Water to Air and put it up in the fender?
Just a thought....
H
A plan is brewing related to intercooling. As a hint, it brings me back to an earlier plan that I abandoned, bringing it back to life because I figured out a way to make it work
Posted: Thu Apr 10, 2008 10:34 am
by 3bAudios
a4kquattro wrote:timmmy wrote:For the intercooler you could still go Water to Air and put it up in the fender?
Just a thought....
H
ok im curious.............
Posted: Thu Apr 10, 2008 12:48 pm
by c4mby
Mark,
What is the final drive on the DQT gearbox? My ETOS parts catalogue isn't working. Is it 3.89:1 like ur quattro? or is it something funny?
Hoping it's a 4.11:1.
Posted: Thu Apr 10, 2008 12:50 pm
by Marc
c4mby wrote:Mark,
4:11
Posted: Sat Apr 12, 2008 1:59 pm
by Marc
Here's a hint to my upcoming intercooling plans. Fan re-configuration (I'll probably add a 3rd fan to make sure there is enough flow):
Posted: Sat Apr 12, 2008 3:40 pm
by oldsklaudidub
What is this car dynoed at?
Posted: Sat Apr 12, 2008 3:46 pm
by 3bAudios
Looks good Marc..... :woowoo:
Posted: Sat Apr 12, 2008 4:21 pm
by PRA4WX
I'm always amazed at how much of the under the hood real estate you've made use of on this car! Wow!
Posted: Sat Apr 12, 2008 10:11 pm
by AudiSport4000
Holy cow Marc, thats crazy
I assume you are bringing it to Carlisle? I have been dying to see this!
Posted: Sun Apr 13, 2008 5:07 am
by Marc
oldsklaudidub wrote:What is this car dynoed at?
411hp, 431tq:
Posted: Sun Apr 13, 2008 5:08 am
by Marc
AudiSport4000 wrote:Holy cow Marc, thats crazy
yep, it'll be there. Not sure if the 4.2 will be done by then though.
Posted: Sun Apr 13, 2008 7:37 am
by Audilard
Dang it!!! Again....I want a V8!!!!
Posted: Thu Apr 17, 2008 1:38 pm
by Marc
So thanks to Janis for bringing me up a pair of used stock lifters to hack apart for the last bit of tooling I need to flow bench the 4.2 heads. Basically this piece allows me to create a fixed amount of lift for both the intake and exhaust valves:
I also picked up some 3/4" cross buffs from standard abrasives to help clean the remaining gunk from the exhaust ports (Not really fair to compare flow bench numbers before and after when there is gunk on the walls...). These things work *awesome*.
With any luck I'll head over to the machine shop tomorrow to play around with the flow bench and get some baseline numbers.
Posted: Fri Apr 18, 2008 11:59 am
by glibobbo21
yeah... they work i had red ones...but go easy they will crumble if you force them too much..they're just scotch brite basically
