Page 63 of 76
Posted: Sat Oct 18, 2008 11:37 am
by Jonathan
Cool. I welded an appropriate nut onto the two I removed from MC engines, threaded in the shaft of the shop slide hammer and popped them out.
Posted: Wed Oct 22, 2008 11:07 pm
by Marc
So I've had some random misses while revving at high rpm and suspected it was crank trigger related since my AIM dash would flash the shift lights as if I had brought the car to redline but this was well below that where this was occuring, around 4500rpm or so. I finally got around to logging it and sure enough WDBG was jumping around during the miss. Checked sensor gap, looked good. Replaced crank sensor, problem still there. Over time it started getting worse, so I spent some more time looking at the issue.
Once before when I was running 034 on my wagon the car would not start one morning after it had been sitting for a while and I discovered it wasn't reading any crank triggering at all. I checked the crank pulley and noted it had a lot of surface rust on the teeth so I brushed it up and voila, the car started.
So I thought perhaps something similar in this case? Problem is the pulley is not exactly easy to get to on the v8 since the radiator is so close. I managed to get in there with my long reach head porting tools to clean a few of the teeth at a time so I could bump the starter and get all of them. Problem seems cured, knock on wood... Hope so, cause I've got Watkins Glen with the audi club this weekend :-P
Posted: Wed Oct 22, 2008 11:10 pm
by Marc
while I was at it, I also wanted to figure out why my HVAC blower switch stopped working completely. All the connections were good so I checked the fusebox. Hmm, #17, lets see, can anybody spot it?
hmm, somethings not quite right there
PSA: its ok to buy tools from harbor freight, but refrain from buying things like fuse kits. mkay?
Posted: Thu Oct 23, 2008 12:22 am
by quattro87
Nope...it looks like it is gone, as in up in smoke. LOL Did it actually melt the plastic or did you break the plastic trying to get the fuse out?
Posted: Thu Oct 23, 2008 4:41 am
by Jonathan
quattro87 wrote:Did it actually melt the plastic or did you break the plastic trying to get the fuse out?
I am pretty sure I see a pool of plastic (black?) at the base of the fuse. I'm glad I have oodles of good, used VW fuses on hand.
Posted: Thu Oct 23, 2008 4:45 am
by pro_mtn_biker
Harbor Freight fuse kits are extremely dangerous! I've seen 10amp fuses support 30+ amps before popping.
Posted: Thu Oct 23, 2008 5:31 am
by BarTender
Marc,
Good to hear you got the beast's hiccup solved.
Guys, I got a ride in this car and its impossible to describe the noise and feel of Marc's coupe. There aren't enough superlatives so I'll just say I want one, I NEED one..... I just need to convince him to do it all over again.
Buying 100 lottery tickets today :-)
Posted: Thu Oct 23, 2008 6:29 am
by Quattro Krant
marc, you're number 17 fuse looks like my #5 holder on my beater 4000Q. In order to get the fuse to work, I have to bend the tabs of the fuse so they touch whats left of the metal in the fuse block, good stuff :bashtard: I really would like a ride in this beast at Carlisle this spring, or, perhaps if you have a beer or too, I could pilot it :D
Posted: Sat Nov 08, 2008 10:38 pm
by Marc
started putting the heads back together tonight but I've got a problem. there is a part in the bags I put together when I stripped them down last year that I dont recognize!! Cant find it in etka either. Looks like a mini-lifter but for the life of me I dont remember removing it. Bueller? (lifter for scale)
Posted: Sat Nov 08, 2008 10:44 pm
by HT Motorsport
Just one of them Mark, not 2? (I have no Idea what that is BTW, but if only one not 2 probably means something ;)
Posted: Sat Nov 08, 2008 11:02 pm
by Marc
I just checked. one. and it was in the bag marked for the passenger side head.
Posted: Sat Nov 08, 2008 11:14 pm
by naudi80quattro
looks kinda like a cap that would sit under a cam that is if the top was shiny. :?
Posted: Sat Nov 08, 2008 11:16 pm
by Marc
naudi80quattro wrote:looks kinda like a cap that would sit under a cam that is if the top was shiny. :?
top is shiny. definitely looks like a mini-lifter in that regard, so it likely sits under a cam but there is no hole for it that I can find.
Posted: Sat Nov 08, 2008 11:20 pm
by yodasfro
Look like the center to a lifter but not a v8 lifter.
Posted: Sat Nov 08, 2008 11:30 pm
by Toxcheap
looks like the oil squirter jet for the head
In my head 20v it actually blew out once and got cut in half by the cam, I found it in my oil pan after searching for loss of oil pressure. it was easy to replace.
Posted: Sat Nov 08, 2008 11:34 pm
by yodasfro
Center of 5 cyl. lifter for reference :wink:
Attachment ( 13975 ) : Picture 130.jpg
Attachment ( 13976 ) : Picture 126.jpg
Posted: Sat Nov 08, 2008 11:37 pm
by Marc
Yoda, I think you hit the nail on the head. I did take apart a pair of junk lifters that Janis gave to me for the flow bench rig used to set the valve lift points. maybe it fell into my bag of parts? that pic looks just like it. Thanks!
Posted: Sat Nov 08, 2008 11:43 pm
by yodasfro
That's exactly what I hypothesized when going back a few pages in the thread. :-D
Posted: Sun Nov 09, 2008 12:15 am
by naudi80quattro
my mistake i mixed up the 2 parts
Posted: Sun Nov 09, 2008 7:13 am
by MikkiJayne
It doesn't look like anything I've ever taken out of a 16V head, so I'd concur on the 'part of a lifter' hypothesis :thumbup:
Posted: Tue Dec 09, 2008 11:09 pm
by Marc
valvetrain is back together, pulled the crankcase breather plate off the short block, I'll probably re-use the 3.6 intake manifold and modified breather plate off my current motor. Any reason I cant do this?
heads may join block this weekend. :woowoo:
Posted: Wed Dec 10, 2008 8:14 am
by 3bAudios
:woowoo: nice work Marc
by a_CQ
About time...
Posted: Wed Dec 10, 2008 9:05 am
by RSCoupe
:stupid:
:woowoo:
Posted: Wed Dec 10, 2008 9:48 am
by Derracuda
so is there going to be a live 4.2 by the spring time? :D
