if you want you can donate the GTX3071 to my 4000!!! Ha
That would be a really sweet setup. With how quick a normal GT3071 spools I can only image the GTX.
Alex recommended that I look into maybe a smaller wastegate actuator which is a good idea. Another option would be get a new V-band flange, cut and re-weld but I dont know how much real estate that would gain me.
James Bufkin
Pat,
Just read through your build. Very nice.
One thing to make sure before you put the engine and transmission back into the car. Since you used a new clutch, flywheel, etc. (parts from different ) and you had some resistance on the mate up, Please make sure you have good enough throwout and clutch release.
Are you going to sell the RR Airbox? I notice youre using a custom manifold,standalone and not going RS2? The RR is rarest thing you got there actually to get a stock 20V look.
James
James
I still have some things to sort out on this build, different choices of valve covers, airbox, turbo etc. the manifold that is pictured I might actually save for another project, its carbon steel not stainless and would require some modification to fit with this EFR turbo... I do have an RS2 exhaust manifold and could run that airbox with it but I am leaning towards a custom tubular V-Band exhaust manifold much like the one pictured but made out of stainless.
I have a feeling this wont be the first time the engine is in and out because I still have some things to sort out. I also have an 01E trans with the wide first and a different diff that I could put in the car but I think that will wait.
Today's update... Got my hands on a sweet piece.
So that avoids me from spending days trying to reinvent the wheel and engineer my own intake manifold.
On the exhaust manifold I'm not sure what to do yet. I will most likely end up looking for a nice stainless piece that has no fitment issues.
WOW sweet intake manifold. What a find.
BTW, nice to meet you and your lady at battle born.
That is a sweet looking manifold, and one I have not see before. Any more information on it?
dana wrote:WOW sweet intake manifold. What a find.
You too Dana, that was great meeting you guys.
It really sucked not having a car to drive though so Im trying to get my Shit together over here.
the german wrote:That is a sweet looking manifold, and one I have not see before. Any more information on it?
The manifold is a really sweet piece and I had a friend import it for me. He has access to 3 or 4 more if anyone wants one.
The only thing I am not a fan of is the huge letters. But as far as function goes it will do exactly what I need. I can run stock radiator fitment with this and its forward facing which is nice. Shouldn't have too much of a problem getting the PS pump in there too.
http://www.bst-turbo.de/home/ansaugbr%C3%BCcken/audi-s2-rs2-s4-200/
it sounds crazy, but i think you could use quality body filler to fill those letters in and paint over.
dana wrote:it sounds crazy, but i think you could use quality body filler to fill those letters in and paint over.
Hmm. What about the heat, would that affect the filler?
Afterthought wrote:dana wrote:it sounds crazy, but i think you could use quality body filler to fill those letters in and paint over.
I dont know? I have used filler on one of my intake pipes where the pipe joint wasnt too pretty and it held up fine right next to the turbo/
Heres a pic of a test fit on it. The flange is 20mm so around 5mm thicker than stock so I'll have to get some new bolts for that.
- ringbearer
Looking mighty fine
I like the intake... Project is looking good.
indeed, looks great Pat.
I saw it on german ebay, the hefty price tag pushed me back. Maybe if they would give back the MwSt....
varia wrote:indeed, looks great Pat.
I typically would never spend like that on a project but I actually got it from a buddy who is here local , within minutes of me... He found something better and I couldn't pass this up.
I was going to make my own intake and I still plan too but I am not an engineer like Hank. Some jobs I could spend 2 days on, and end up with a product that is far from perfect but If I ever want to get this car running I have to farm a few out.
Yeah it looks awesome. Nice pat
That looks bad ass.
I would not recommend body filler on the intake manifold; the aluminum has a very different coefficient of thermal expansion from polyester or vinylester putty (body filler). Added that that, putties shrink over time as they continue to cure, which is hastened by heat. That translates to: it may look good at first, but it will crack and fall out then look like poo. I would just live with it. You can't see the letter on the intake while you're driving it anyway.
Yeah that's true. I really like the intake the letters don't bother me too much. If it did I would just put my own logo and tack a plate over it. I don't have a logo yet though ha
If you really, really wanted to you could fill in the letters by welding (be sure to pre/post heat to 200*F for at least 20 mins before & after the weld), then grind it smooth and paint/Cerakote everything a uniform colour.
Otherwise everything is progressing nicely, appreciate the updates.
Wiring:
One of the next steps on this project is to start getting the wiring started.
For this car I have purchased the VEMS I-6 "Base" Twin Shield Harness and am attempting to do a portion of the wiring myself, both because I'm cheap and because I'm an idiot.
EFI Express supplied me with a pretty sweet set-up, he got me the harness and also all of the pins and connections on the end so I can make these terminations myself and end up with no butt connectors anywhere in the harness. It will make for a real clean setup because it has everything I need and nothing I don't (except one extra injector).
For starters I am laying the harness out and figure which wire is which and label the end so I can make the terminations I need. I'm now trying to acquire data and knowledge about that harness, If anyone has any links to any cool how-to's about understanding the harness and the VEMS computer please feel free to post them here!
http://www.vems.hu/wiki/index.php?page=MembersPage/PhatBob/UserGuide
V3.6 Pinouts : http://www.vemssupport.com/forum/index.php/topic,1266.0.html
Got the URQ back on the lift. I am awaiting some parts , but figured I would start a few things that need to happen anyways. Time to shift my momentum towards this now that my 4k runs.
The rear tie rods need to be redone , but they are completely froze up. I tried PB blaster and a torch as well, letting them soak overnight now .
Next I figured I would looking at the rear section of the exhaust ... not sure I should run a muffler or not but I'll probably use a single Borla 3" straight through.
Also haven't decided on single or dual
Tips .
I screwed around for quite a long time trying to make a Y out of stainless for dual 3" tips , but I ever got where I wanted to with it . Can't figure out how to tie the single 3"
In with it.
Tips .
In with it.
got a little more done on the exhaust . Made some hangers and got the muffler in place.
The over the axle piece, I hate that part.
Using a special tool in a few key areas to make sure there is clearance
Thats it for now, I'm cold. I gotta go to vegas.
Tried using these tie rods, MOOG ES2263R BMW ends, supposed to fit in the rear for UR Quattro.
At this point they are adjusted all the way in and the car is still toed in slightly. Will see if I can find a way to make up any of that- if I can get them to work they would be a good 9.00 solution.
Very little updates but thinned the herd down and moving this to the top priority.
I really wanted to drive this car to Vegas this year so need to speed things up a little bit to get it done.
*Got a proper small chassis oil pan and blasted out the inside- getting ready to swap over
*Fit up my throttle cable to go with the new forward facing manifold
*Cleaned the paint overspray off the drivers door.
Throttle cable
Drivers door before:
After:
Throttle cable
After:
Tackled a few things today had to pull the engine unfortunately to fix an issue.
Started buttoning up the brakes and stuff, re-installed the dust shields, started installing braided stainless brake lines, the rears I am missing one small piece. Looks like maybe I need a male-male bubble fitting. And also need to get some sort of tool to compress the pistons in the rear to fit new pads in.
Brakes almost done:
Missing something here, have two female ends.
Rear tie rods are in but not adjusted yet. these are the $9.99 BMW tie rod ends.
Also started making a bracket for the PS pump, but with the configuration of the forward facing intake manifold, It will not have the adjustment it needs.
so I need to either scrap the plan of V-belts and put on an AAN damper to run a serpentine setup, or come up with something else. I do have an MR2 electric PS pump laying around, may be a wise time to use it.
These wheels actually might not be a bad look for this car with some spacers. But I kind of like the old school look. This is just to roll it around on for now.
Have all the parts I need to configure my 01E linkage now. URS4 linkage, Small chassis lever arm and linkage, and a new ball and cup.
Heres where its left off for now..
Next step is to finish the brakes so I can fill and bleed the whole system, test the operation of the clutch and make sure that's all good before I move forward
Brakes almost done:
