Page 90 of 106
Re: Tacos 4KTQ 20vt Swap: The Red Baron - MOAR PICTUREZ!!
Posted: Thu Jun 05, 2014 4:21 pm
by AngryTaco
I think ive bent over 20 valves now lol! Then again I think ive tried doing things a little different in some areas
Posted: Thu Jun 05, 2014 8:23 pm
by AngryTaco
Im wiring in a push button for the csv. Tired of this hotstart bullshit
Posted: Thu Jun 05, 2014 9:49 pm
by Wilford Brimley
AngryTaco wrote:Im wiring in a push button for the csv. Tired of this hotstart bullshit
What are your control and system pressures? Are the injectors new?
I've had CIS cars start in 0 degree temps without a CSV
Posted: Thu Jun 05, 2014 10:10 pm
by AngryTaco
All pressures are within specs. Only problem I cant solve is control drops to 10psi immediately upon shutdown
It starts fine when cold. Its only after sitting for 20 mins when hot
Posted: Thu Jun 05, 2014 10:34 pm
by Wilford Brimley
Fuel pump check valve or accumulator.
What is the residual system fuel pressure? It should stay at ~3bar for multiple hours.
Posted: Thu Jun 05, 2014 10:35 pm
by AngryTaco
Sorry thats what I was meaning. The residual pressure that you check at the wur immediately drops off upon shut down
Posted: Thu Jun 05, 2014 11:04 pm
by Wilford Brimley
Valve closed (reading system pressure) or valve open (reading control pressure)?
You could close off the valve on your pressure tester (system), then shut off the car before it dies to see if the pressure is bleeding off between the metering head and the tank.
Posted: Fri Jun 06, 2014 12:10 am
by AngryTaco
ohhh gotcha. I will check that tomorrow. If the system pressure bleeds off upon shut down, does that indicate accumulator, or does control pressure signify that?
Posted: Fri Jun 06, 2014 12:33 am
by Wilford Brimley
System pressure would indicate issues with the fuel pump check valve/accumulator. Also look into this:
http://www.sjmautotechnik.com/trouble_s ... html#vapor
Posted: Fri Jun 06, 2014 12:47 am
by AngryTaco
I actually just stumbled onto this thread over at quattro world
http://forums.audiworld.com/showthread.php?t=2194572
The 2nd post accurately describe every symptom I am experiencing. I believe it to be the accumulator. There is a junker 4000 in the local yard, so I think I'll pull it and replace it. I'm wondering if the relayed fuel pump put too much pressure through it?
Posted: Fri Jun 06, 2014 1:16 am
by Wilford Brimley
AngryTaco wrote: I'm wondering if the relayed fuel pump put too much pressure through it?
Negative. Your system pressure is regulated by the metering head (MC1 cars used shims, MC2 used an external reg like the NG engine). There was no increase in pressure, but there was a flow increase.
Assuming it is the accumulator, a big contributing factor to its demise would be the pump going from ~11.2v (what I have usually measured at the terminals) to ~13.5v. Extra flow will have detrimental effects on older parts in a fuel system (especially parts with diaphragms).
Case in point: a friend had a neon that kept eating FPRs. We eventually discovered that the PO had installed a relayed walbro 255 on an otherwise stock engine in anticipation of boosting the car. All of that extra fuel going back to the tank was raising hell with the reg.
Posted: Fri Jun 06, 2014 1:56 am
by AngryTaco
Interesting. Is there any kind of alternative to installing another accumulator? Or should I just grab one out of the junkyard and hope it works?
yay CIS lol
Posted: Fri Jun 06, 2014 2:41 am
by scubadave
YES!!! VEMS
Posted: Fri Jun 06, 2014 2:52 am
by AngryTaco
yeah yeah yeah! I'm working on it! Broke azz shit from school tuition
Posted: Fri Jun 06, 2014 3:03 am
by Wilford Brimley
AngryTaco wrote:Interesting. Is there any kind of alternative to installing another accumulator? Or should I just grab one out of the junkyard and hope it works?
yay CIS lol
Grab it, and soak those fittings in PB blaster.
If it doesn't work, you're out a few dollars. Only bad thing I imagine happening is the lines going to the accumulator break on the baron when you try to remove it.
Posted: Fri Jun 06, 2014 8:45 am
by themagellan
yay CIS lol
Wow - Nice CIS info dude.
Pro tip to not break those lines - Get yourself a set of vice grips and use cardboard or packing foam to clamp onto the metal line near but a few inches away from the fitting. If you put all of your force at the top of the line where the fitting is, that will be your path of least resistance. Allow it to give a little bit and it will come over time.
After super PB saturation, attempt to tighten, then untighten - Repeat this while holding equal parts pressure. I don't think anyone can take off crusty hydraulic lines better than me in a dirty garage haha!
Posted: Fri Jun 06, 2014 12:11 pm
by AngryTaco
Well, guess I'm grabbing an extra accumulator today after I mail out a bunch of stuff.
Now here's a strange boost issue.....
1st gear through 4th, it will hold 14-15psi with out issue at any rpm
5th gear and the boost will skyrocket towards infinity......why!?
Posted: Fri Jun 06, 2014 12:15 pm
by Wilford Brimley
AngryTaco wrote:Well, guess I'm grabbing an extra accumulator today after I mail out a bunch of stuff.
Engine load increase.
Posted: Fri Jun 06, 2014 12:16 pm
by themagellan
I'm willing to bet under full load your wastegate could simply just not be able to keep up - What are you running currently (hardware/spring)
Posted: Fri Jun 06, 2014 12:26 pm
by Wilford Brimley
Another likely scenario is the stock 20vt WG being unable to bleed off boost with the tiny 30mm plunger when loaded up in a high gear. Check to see if there isn't a tear in the WG diaphragm too.
A good upgrade is the 34mm WG off of an AAN engine. It is a direct fit to the 20vt engine.
Are you using an MBC or the stock N75 to regulate boost?
Posted: Fri Jun 06, 2014 12:29 pm
by AngryTaco
Using the stock N75 for right now. Diaphragm isn't torn and is relatively new. Already done numerous vacuum tests to make sure. I was starting to wonder if the wastegate had become a little too small
Posted: Fri Jun 06, 2014 12:34 pm
by dana
Wilford Brimley wrote:Another likely scenario is the stock 20vt WG being unable to bleed off boost with the tiny 30mm plunger when loaded up in a high gear. Check to see if there isn't a tear in the WG diaphragm too.
do you have experience to back this up, or is this just a theory? I used a 20vt WG on my car, and never had an issue with boost creep. My car was around 350whp, maybe more at 30psi.
Posted: Fri Jun 06, 2014 12:41 pm
by Wilford Brimley
AngryTaco wrote:Using the stock N75 for right now. Diaphragm isn't torn and is relatively new. Already done numerous vacuum tests to make sure. I was starting to wonder if the wastegate had become a little too small
Disconnect the N75 and see what the boost holds at through the gears. It should be pretty low, something like 7psi with a 2.2bar spring in, since the N75 is no longer applying pressure to the upper WG chamber.
Posted: Fri Jun 06, 2014 12:44 pm
by Wilford Brimley
I had my boost set at 17, and it would creep to 20 if I was in 4th or 5th.
You also have to remember that this is on a 20v, which has an awful exhaust manifold design when compared to the 3b/AAN. Not all of the cylinders even feed the WG...
Posted: Fri Jun 06, 2014 12:50 pm
by dana
good point, mine was on a tube header.
