Page 10 of 13
Re: Tim's '86 BLAZE 4kq 16vT UPDATE!!!!!!!!!!!!
Posted: Sat Dec 29, 2012 1:39 am
by my2000apb
MORE UPDATE!!!!
So I built this catch can a while ago and got it welded up by Ryan, thanks again, and it was time to get it mounted in the engine bay. I wanted to have nice flat or slightly uphill hoses and it needed to be easy to drain.
I made a mounting bracket and tacked it to the body. I welded a m6 weldstud to a band clamp and used that for attaching it to my bracket.
It fits pretty well between/inwards of the coolant and washer fluid reservoirs.
I got started mounting my battery in the trunk right after that. Thanks again to Haydn, for this spare battery box he had kicking around. It’s mounted in place with two m8 coupler nuts welded to the frame rail and an m8 weldstud on the back/blindside so it’s much easier to get the nut started.
I also welded a m8 stud to the frame rail to use as a ground stud.
I mounted a 150A breaker to the top of the battery box, ill snap a pic of that later.
While I was hammering away on that Toph installed my hood pins. He recently installed some Aerocatch pins on his CQ with exceptional attention to detail so I had no problem letting him loosing drilling holes in my car.
Posted: Sat Dec 29, 2012 6:34 am
by Rallyfreak202
Nice work Tim. The catch can looks familiar. Is it part of an evaporator from an UrS car?
Posted: Sun Dec 30, 2012 9:49 am
by my2000apb
yeah its most of it, theres an update a few pages back with its construction. its been cut apart and lengthened, as well as some down tubes where the inlets are.
heading back out to the garage for IM and boost piping mods, exh tip work, and some custom k24 cooling lines
update to come!!
Posted: Sun Dec 30, 2012 4:40 pm
by glibobbo21
nice idea on the intake end cap modding :wink:
Posted: Mon Dec 31, 2012 3:23 pm
by my2000apb
glibobbo21 wrote:nice idea on the intake end cap modding :wink:
thanks, my local euro tooner parts delivery guy suggested it
new year , need a new car, back to wrenching
Re: Tim's '86 BLAZE 4kq TALL DECK STROKER this
Posted: Sat Jan 05, 2013 11:41 am
by my2000apb
back to the lab
Posted: Mon Jan 14, 2013 2:38 pm
by my2000apb
UPDATE!!!!
Ok a few small catch up things and then its on to the fabrication update!!
Got my light bar finished up, I need to wire it up and then POR it.
It should provide ample light
Customized up some trans/diff mounts. Race spec
I miss the old pre-fade orange, well fresh paint it will be then realtree blaze camo vinyl.
I got my rear trunk patch painted and now time to reinstall the trunk liner.
Cleaned up the AEB starter and its heat shield
And lastly the d11 v8 taillights about to be cutup for t-85 usage
Posted: Mon Jan 14, 2013 2:43 pm
by my2000apb
UPDATE!!! I finally got a chance to get started on some of the smaller, rebuild/clean up/reassemble stuff that would need to get done, just getting to all the smaller tedious steps before it can run.
I popped my wastegate off and proceeded to tear it down. I already had a 1.9 bar spring, but I wanted to add a new diaphragm as insurance. Jim, glibobbo21, had also ordered a box of M5 cap nuts and washers in stainless, so I added those for a nice clean look.
I also got a chance to teardown and cleanup the t-44 brake master cylinder and my 4kq vacuum booster. The m/c got a bit of wire wheeling and the booster got a bit of sandpaper and some enamel. I was going to sand it down and recoat a few times but F it! It’s a brake booster and its now protected from the elements so that’s good enough!! I want to drive it!!
I also got a check valve from a porsche 911, PN 191 611 933F
It uses the same size booster grommet and vacuum line to the manifold, its extra nice and clean as it’s a 90 degree valve so it keeps the vacuum line tucked out of the way.
Posted: Mon Jan 14, 2013 2:53 pm
by my2000apb
MOAR!!!
I got into the bay and got to finish welding.
Finished- clutch m/c brace, steering rack/strut brace, misc weld studs for lines and wiring, aux water pump mount, oil cooler and intake shields/duct work, etc etc
It’s all done and now for bay priming, sealing and painting.
And two pics, unsure where the rest are
The bay is getting another coat and then its reassemble time!!!!!!!!!!
Re: Tim's '86 BLAZE 4kq 16v/ABA/o1E/TURBO!!!!
Posted: Mon Jan 14, 2013 3:16 pm
by Val
my2000apb wrote: I cut and inch and a half into the frame rail and used some large steel plates to reinforce the area.
What will MOT say about this?
Anyway, good progress you make.
Posted: Mon Jan 14, 2013 5:59 pm
by glibobbo21
my2000apb wrote:I also got a check valve from a porsche 911, PN 191 611 933F
got mine and tophs for free from a chevy :-D
Posted: Mon Jan 14, 2013 9:34 pm
by vagrant_mugen
Val wrote:my2000apb wrote: I cut and inch and a half into the frame rail and used some large steel plates to reinforce the area.
most inspectors in america are lazy :jerk:
Posted: Tue Jan 15, 2013 10:33 am
by my2000apb
Posted: Tue Jan 15, 2013 10:34 am
by my2000apb
Next up was oil cooler ducting
With the intake side done it was time to duct the oil cooler. The cooler sits inside the drivers fender in a small cage to protect it from us sliding into things haha
Posted: Tue Jan 15, 2013 10:45 am
by my2000apb
Posted: Tue Jan 15, 2013 11:03 am
by DE80q
Looks like you are moving along nicely. Cant wait to see this in person.
Posted: Tue Jan 15, 2013 11:06 am
by my2000apb
Posted: Tue Jan 15, 2013 11:09 am
by my2000apb
MORE undertray fab.
I got the framework all welded up with the sides as well. It is already a pretty stout piece.
Started skinning the bottom. The center is 16 gauge and the sides are 22 gauge. I could have made it all from 16 or 22, but I went with the thicker stuff in the middle as it will get a lot more debris, but 22 gauge on the sides to help keep weight down but also as there won’t be nearly as much rocks, sticks etc. coming in from the sides.
I also picked up one of these cool punch/flare tools for sheet metal last time I was at Summit. Its all-star products
http://www.summitracing.com/parts/aaf-all11074 It is a combo punch and flare, 2” hole up to 16 gauge!!! So I set about drilling pilot holes and getting my punch and flare on!!! This makes the panels much stronger! As well as look uber motorsport hah
Posted: Tue Jan 15, 2013 11:16 am
by my2000apb
Posted: Tue Jan 15, 2013 1:34 pm
by vagrant_mugen
this is quite the ralley build.
ill be pleased if my sport comes along like this, but your gonna miss the winter if u keep up this madness....
youd be suprised how fun a stock b2 chassis is w/ a 300hp 16vt, you couldve waited for allthis extra mayhem.
shit by the time this things tuned itll be spring time... but i suppose you fellas got plenty of dirt to go
slide about in, theres very few dirt roads down here w/out angry walkers on them.
CT yuppys suck
Posted: Wed Jan 16, 2013 10:25 am
by my2000apb
vagrant_mugen wrote:this is quite the ralley build.
CT yuppys suck
no way buddy, this thing will be roadworthy in no time, gotten way too mcuh done to update, no going to take pics of basic rebuild/reinstallage so im making even more progress
and yes we have tons of dirt and loggin roads for hooning, ct yuppies do suck
fuel tray being built, IM being finshed welded and PC'd with a bunch of other parts, also have a batch goign out for hard black anodizing as well
Posted: Fri Jan 18, 2013 1:44 pm
by my2000apb
Mini update, got a little bit of time in the garage last night.
I got my k24 coolant line adapters back from Ryan, and they look sexxxxy! I’m using a 3b coolant feed freeze plug with a low profile Aeroquip weld-on AN fitting. This allows me to still be able to press this plug in as its fits easily inside of a 19mm impact socket. I’m not sure where the flare portion came from, I think it’s b4. Either way, k24 cooling is just about finished; I just need to make the 6an lines to and from the adapters.
Most of my stuff has been blasted and its going to get black wrinkle powder this weekend, the cast and IM is all getting PC’d and all the billet / extrusions are all getting black hard anodizing. It’s going to be sexy
I managed to get the final coat of paint on the engine bay. The flash makes it look very gold where It’s really a much darker bronze color.
Toph, working on the v8 shorty taillights, more to come on those modifications
And similarly to the under tray I built for the front. I wanted to build a small shield for the fuel tray area. I had initially thought of just making a protective shield for all the factory tray/ filters etc., but then I thought why restore/clean/prep/prime/paint the old one, when I can make a new one and integrate the filter/pump mounting and the protective shield all into one. So I started making a nice little tray of ½” 16 ga. Box tubing and 22 gauge sheet. it will be more than strong enough to hold the fuel pump and filters but also protect the stuff from misc. debris
And we got the mega crimper of death from the neighbor who installs generators, so I can finish my battery and ground leads.
Posted: Fri Jan 18, 2013 5:26 pm
by dubsmith
Go man go! AWESOME
Posted: Sat Jan 19, 2013 7:22 am
Sweet. You're on a roll, I need some of that in my life! Haha
Posted: Sat Jan 26, 2013 12:07 am
by my2000apb
UPDATE
Ive finished up the fuel tray and its been por15’d. its ½” box with 22 gauge sheet, with flared holes. Its plenty strong. I got a few fuel pump and filter brackets powder coated over at Higbee Fab and mounted them up to the tray.
I also cleaned up the AEB oil pan that I had and compared it to the pan I got from Justin. He hooked my up with a brand new, late b5 pan! The difference being it has the spot for oil level sender but its not drilled. So I was going to use the AEB pan anyway but the coating is all cracked on the inside and I don’t want it coming off and clogging my oil pickup. So the brandy new pan got its drain tapped to ½ NPT and I was good to go.
Ill be installing it tomorrow with the new AEB oil pump and ABA ( possibly modded) windage tray / gasket.
and lasty i saw in Mr AngryTaco's 4kq thread how wornout his clutch pin was i popped mine out and look at that, its worn out as well, so i got another one of those from the dealer and itll go in when i put the freshly painted master cylinder back in.
i will make a comprehensive parts number list on page one shortly
clutch pin part number N0231531
