Ohhh how much I love wiring... NOT. Any tips or tricks on getting the engine harness out? It becomes such a clusterf**k underneath the relay panel.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
DomP90 Coupe Quattro
Re: DomP90 Coupe Quattro
'93 90q- 3m Matte Black Vinyl wrap, 17x8 et30 Rotiform BLQ, Koni Yellows/Vogtland springs
'90 Coupe Quattro- Project
I just went through the same thing on my 90. What I did was pull that front relay harness down from its perch and then followed the wires to all the plugs and took pictures of each before unhooking. I then pulled from the engine side out as it won't go the other way. It took a while and wasn't very comfortable but eventually I got the harness out in one piece through the firewall.
Not sure that helps much but good luck just the same!
Ended up snipping wires that went to the connectors and had a friend pull them in the engine bay. Seriously looks like its been messed with before. Or the people putting the car together 23 years ago really just didnt care lol. Either way got it done.
- SmokeTheRear
word on the street is Domp90 removed the abs pump out of the car
Ill' Be damned, them nissans is skid racing
Yep, ABS has been deleted, just need to remove the harness. Joy oh joy another harness to pull... Right now doing little stuff, but staring at the turbo sitting on my desk in my room really makes me want this thing done already!
- SmokeTheRear
Not much of an update but progress is progess. Bottom end is off at the machine shop. Should be done sometime this week. Ill post up some pics when I get everything back and start assembly
- SmokeTheRear
word on the street is you getting some stuff done and aquired some new stuff
