RufCTR wrote:I made sure your order shipped today and you should have received a tracking number from our shipping department. If the Fed-Ex estimate is correct, you should receive your parts on Friday of this week.
With regards to fitment, you will need to take the metal sleeve out of the original throttle-cam and insert it into the new 034MS part. This will ensure the new part fits just like the old one. There is also a plastic piece that the spring sits on you will need to transfer to the new part. Make sure you are careful when you remove the spring as well since it is under pressure... you will need to set it up just as it was originally.
If you have any additional questions about this product or any others, please feel free to e-mail me at sresnick@034motorsport.com.
Thank you Sir!
The pump stays on... You can set how long after power up it takes for the pump to turn on and how long after inactivity (engine dies) that the pump turns off, both in seconds. Are you saying after power up without starting it should turn off? I'll agree with that.
