DITTO... kinda looks like your hotside went to the southside LOLToxcheap wrote:Damn I just saw the pics what the hell happened?
virtuapete
WAUG0806
So I was driving along doing 2nd gear pull after 2nd gear pull fine-tuning the car. It was running great at 24 psi of boost. I did a bunch of runs at this level because my knock light kept lighting up and I couldn’t figure out why. Finally narrowed it down to the coils had to much dwell and were tripping it. Cool. So I gave the schrapenalknobben a good turn. Sweet, 27 psi no knock. Damn, I didn’t have the logger going so let’s do it again, but with more boost. Another 1/2 turn later there’s sparks shooting out of the hood vent. WHOA! FECK, the turbo just let go. Lucky for me the car was still running, but with a large exhaust leak so I limped it home 3 blocks and found this:
So why did this happen? Well, who knows. I did just get done trasfering everything over to a new bearing housing because I was having problems with oil seeping out the back. Well it's still dry even after all this. It looks like the turbine just snapped off. I made sure everything went back on exactly how it came apart, and it's not like I haven't done this before..... I think I just overspun it. 30 psi is alot of boost at this altitude and I really had to crank on the boost controller to get it up there.
So now I have to decide to get a GT30R or GT35R. I really wish I could have hit the dyno with this, but after logging boost curves I think I can get a good plot of what it would have done. I think this turbo would have landed right between the two, which is where I want to be.
Toxcheap
I almsot feel like I should post a folllowup saying sorry for your loss? Heck, the way we treat our turbos I dont think thats fitting
Yea, it's funny, I'm pissed that it happened, but first thing I went up, grabbed the wife and said come look at this crazy shit! All the while laughing while taking pictures. She told me she's taking the new turbo money and committing me. I’ll pull it all apart tomorrow, but the turbo still spins free with little play and from what I can tell the compressor didn't even hit.
The new bearing housing was a last ditch effort to save this guy so I’ve been looking at new turbos for a while, kind of anticipating this. The GT30R is great at sea-level and no doubt I’d go with that if I lived down there. But the reality is it takes a pressure ratio of 3.9 to get there at my altitude. Toss in a 12,000 ft pass every now and then and I really start to fear for turbos up here. No wonder those K03’s fail all the time here. I’ve done a bunch of plots at work and I’ll post them tomorrow to see what you guys think. I really want to see how Hap’s car does on the dyno with the GT35R and I honestly might wait if he gets it on the road this weekend.
Then there’s the, how fast does this really need to be factor. It was frightening at 27 lbs of boost, and without the diff locked it was a real handful. I need to talk to my supplier and see what he thinks
pro_mtn_biker
virtuapete
TheArchitect
birdmanmt
TheArchitect wrote:You mean your pusher?audifreakjim wrote:I need to talk to my supplier and see what he thinks
So how do you like being able to "see" 27 psi?
LOL! Being able to tune up in that range is awesome. It's nice to just set the main scaler and crank up the boost. No more special tuning for the top row :woowoo:
Yes I'll be keeping the dents in the hood! My wife was more concerned about that than the turbo
John, I looked at the 3071 just because of the insane pressure ratios it can hold, but the real fun in this motor is up top, and that's what I built it for.
I'm 99% sure I'm going with a GT35R. The compressor wheel and turbine are smaller in size than my current turbo. Add ball bearings into the equation and I can't see how I could be worse off response wise than I am right now.
Now I just need to decide what A/R housing to use. I'll probably stick with a .63 and use closed loop boost control to combat surge in higher gears.
WAUG0806
audifreakjim wrote:She really doesn't care, but she was the only one around so I forced her to come see. Thanks for the hood offer, but one of these days I'll be doing a B4 hood with S2 bumper conversion :-D
Jim,
It looks like you'd have "holed" your hood if not for that heatshield...
I have replacement for same turbo coming (hopefully today) from Swanson Motors ... mine trashed the center seals/bearings in a much less spectacular way...although it's the biggest cloud of smoke i ever made with a car - I'll be going from 50 trim to 57... felt like the 50 trim was "out of breath" (700' -2500 elevation here) above 5000RPM and boost drops so hope the 57 can keep up better... imagine you do need bigger turbo as your 20V has almost every heavy breathing bit available + the thin air...
JShadzi
84urq20v
