AudiSport4000 wrote:4ktq's make great daily drivers
So do 4.2 V8 4KQ's. The torque down low and in the mid range is really nice.
Taco, just put a couple jumper cables form the negative post up to somewhere on the engine or trans and then try to turn it over. That will tell you if you have a ground wire issue. Then its up to you to find if its the batter bround cable or the engine ground.
Re: Taco's 4KTQ 20vt Swap: Project Red Baron
Posted: Fri Aug 24, 2012 7:41 pm
by AngryTaco
Ok issue fixed. It did end up being the battery ground. However, when I did the multimeter test, I was freaking out because it was still reading 12.5v from ground post to cable. But then I realized that from positive to negative post also read 12.5v. But now I could arc my connections around the car, like the starter and common connection where all lines meet. The sparks were gigiganormous compared to before. But....still getting soft click at starter. WTF!? So I jump the solenoid to the power and the starter sounds like it is grinding and freely spinning. Well now that the starter is insanely easy to change thanks to no more battery tray and reunkulous down pipe, I put the starter in that was from the JT. Just tested it, turns over like a charm
Posted: Fri Aug 24, 2012 7:44 pm
by AngryTaco
So do 4.2 V8 4KQ's. The torque down low and in the mid range is nice
Get urself a small block Dodge like me
More than enough bottom end to go around. Midrange is good but top-end sucks!
Those 4.2L are killer on the top end. I like the sound better than my Dodge to be honest
Posted: Fri Aug 24, 2012 8:32 pm
by AngryTaco
Got the oil primed. Gets a solid 30psi when cranking over. Kinda got scared at first cause the gauge kept reading 0 till I turned it over for the 3rd time
Posted: Fri Aug 24, 2012 8:40 pm
by DE80q
so, does it make cool turbo noises yet?
Posted: Fri Aug 24, 2012 9:02 pm
by AngryTaco
Maybe this weekend lol. I still gotta get the front drivers and rear passenger suspension bolted up too. Tires are getting ordered this Friday
Posted: Fri Aug 24, 2012 9:05 pm
by Kliminati
Project Red Baron?.....
so does that mean your going to follow the paint scheme?......cause that would be pretty freakin sweet 8)
Posted: Fri Aug 24, 2012 9:20 pm
by AngryTaco
Sure am. Red Car, white wheels with black trim
Posted: Fri Aug 24, 2012 9:27 pm
by AngryTaco
Ill have more pictures tomorrow
Posted: Fri Aug 24, 2012 10:26 pm
by 85oceanic
Dude, you should totally add that livery to your car somewhere.... eeerrrmmm... like on the front doors!
Posted: Sat Aug 25, 2012 7:41 am
by AngryTaco
I am. Already had that planned lol. On the rear quarters, it's gonna say "One bad mother fokker"
Posted: Sat Aug 25, 2012 7:50 am
by DE80q
AngryTaco wrote:I am. Already had that planned lol. On the rear quarters, it's gonna say "One bad mother fokker"
Posted: Sat Aug 25, 2012 7:57 am
by 85oceanic
HAHAHAHAHA That right there is amazing.
Posted: Sat Aug 25, 2012 8:00 am
by AngryTaco
HD Bilsteins!!
Putting rear driver suspension back together
I used the front 4kq springs in the rear
See what I mean? Red Baron all the way
Posted: Sat Aug 25, 2012 8:02 am
by 85oceanic
WOOT nice work man!!! You gotta bring this thing to BBQ man!!! I want to see it in person!
Posted: Sat Aug 25, 2012 8:48 am
by AngryTaco
We'll see lol. All depends on school and monies lol
