Page 14 of 31
Re: 1990 CQ-will an Urq 034 rear Diff mount fit on a B3?
Posted: Fri Oct 12, 2012 4:01 pm
by Kuma
yep, i got the location. but didnt realize its a press in thing.. crap.
all this bushing and pressing shit is fiddle sticking going to piss me off....
i dont want to pay someone to do it for me.
i want to do it myself.
Thanks for the insight bud
Posted: Sat Oct 13, 2012 2:15 pm
by zarati
Kuma - 034 doesn't make an "Urq Rear Diff mount".
They have two styles of rear diff mount (Assuming your talking about the center mount and not the side mounts).
One is Delrin. The other is Density Line Rubber.
BOTH are speced as B2/B3 mounts. BOTH Should work fine in a B3 as B3's have the hole right in the center just like 034's mounts.
Now the Urq and early 4kq have the hole on that mount Offset. So if anything, I would think that the issue would be running the 034-Mounts on an early urq/4kq. In practice though I doubt it matters. All it does is change the tilt of the rear diff a bit on the early cars lining the driveshaft up with the input a little more. (Hole is offset to the top at the rear which will drop the rear and raise the front of the Diff.
Posted: Sun Oct 14, 2012 9:44 am
by Kuma
guy said that the one he has is a rear diff mount? from 034?
im just going on what the guy said.
although, he said he does have a Powerflex B3 mount.
are those any good?
Dave E. Said they are quite popular.
Posted: Sun Oct 14, 2012 8:34 pm
by PRA4WX
Peter ran one in his car. I was going to (and their C/A bushings) but 034 made me an offer i couldn't refuse on the same parts.
Posted: Mon Oct 15, 2012 9:50 am
by zarati
Both the Powerflex & the 034 stuff are "Good". Depends on what your looking for.
Subframe:
For a daily Driver, I'd definitely go Powerflex over Aluminum 034 stuff. But for track I aleady did go 034.
Control Arm:
Again, for a daily, I prefer Rubber (I would think Powerflex might be a good way to go too). For a weekend car or track car, then Delrin from 034 would be my preference.
Diff / Tranny Mounts.
Again, for a track only car. I'd go Delrin. But for a street car, Id go with either of the 034 Density Lines. I personally did Track in the back (Diff), and did Street for the transmission. BUT...If I had a chipped 5cyl-Turbo, I'd do track for the tranny too.
Not sure if that helps any.
Also, not sure if you have looked under the car yet but it seems your not to sure about how the rear diff mounts are oriented. Basically there are three that triangulate the diff.
2 side mounts. They are identical and are the same as the Transmission mounts. These bolt in with 3-bolts. (2-for mount to subframe, one for mount to Diff). They are fast and easy to swap and are the first thing I do on any old Audi I buy. 034 does have a delrin (Race) Version of this mount but I dont view it as an option for anything other than a track car or weekend 500hp monster.
1-Rear mount. This is a press in if you go with a OEM or 034 Densitly line. That means you have to pull the Diff out to do it. "Also a good time to replace your Output shaft seals." For this mount 034 also has a Delrin version that should install without a press, but you still have to press out the old one.
I would run the same mounts for all three. IE...If you go delrin on the sides, make the rear Delrin. IF you go rubber on the sides, make the rear one a rubber one. Putting a delrin rear mount in, and leaving floppy rubber side mounts, will put a lot of stress on the delrin mount and would think with enough power could break something.
Posted: Mon Oct 15, 2012 10:03 am
by DE80q
zarati makes a good point. I would make sure you have the same "style" mounts in all 3 places on the diff. I actually prefer to have the entire driveline using the same, but to each his own. I will be running the 034 density series on the entire thing, engine, trans, and diff.
But on the subframes, and CA's I will be running the solid mounts. Again from 034(kinda) :wink:
Posted: Mon Oct 15, 2012 2:50 pm
by Kuma
OKAY, so that is the most explained answer i have received and i actually get it.
so, if i get this powerflex bushing then i should match the others with it as well.
GOT IT.
Thanks TOdd and the rest
i got my short shifter...
it has German parts numbers but i looked them up with no luck.
its not a Billzcat1 shifter, i asked him. Mr. Hoffman said its not his.
Re: 1990 CQ- Identify this short shifter? German part # on i
Posted: Wed Oct 17, 2012 7:55 am
by Kuma
im thinking about getting the 034 tubular small body control arms. Any experience on these? worth it?
you can get them with or without ball joints.
Posted: Wed Oct 17, 2012 8:49 am
by DE80q
I had thought about it, but then again, I cant justify the extra cash on them. Aaron uses the cast CAs on all four corners on the CQ. That is test enough for me.
Posted: Wed Oct 17, 2012 8:54 am
by DE80q
As for your shifter, I think its the factory shift rod, with a modified rabbit shift ball. Im not sure what the alum plate if for though. Maybe its there just to tighten things up, or possibly to keep the shift ball from falling out.
Are there any part #s on the shifter mount? You dont normaly get the shift rod with it, ust the mount.
Posted: Wed Oct 17, 2012 9:12 am
by HeartlessNomad12
like i said before, looks much like the corrado setup with the plate to keep the ball in.
Posted: Wed Oct 17, 2012 9:35 am
by savagerocco
HeartlessNomad12 wrote:like i said before, looks much like the corrado setup with the plate to keep the ball in.
All corrado's were cable shift and they didn't look a thing like that. The MK1's looked a little like that.
Posted: Wed Oct 17, 2012 9:39 am
by Kuma
the ball isnt falling out though... the plate on top is an anchor plate i suppose.
ill snap a picture of the rest of the shifter in a bit.
ill install tomorrow.
Posted: Wed Oct 17, 2012 9:55 am
by rally3
Could also be a vanagon shifter plate. I think that is the other one that will work as a short shifter.
Later
Aidan
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Posted: Wed Oct 17, 2012 1:16 pm
by Kuma
got a picture of the powerflex bushing.
Posted: Wed Oct 17, 2012 1:22 pm
by Kuma
Posted: Wed Oct 17, 2012 3:49 pm
by Kuma
Posted: Wed Oct 17, 2012 4:27 pm
by Glug
893711159B shows this in the German market:
US market:
Not sure if thats what you wanted to know..
Posted: Wed Oct 17, 2012 4:35 pm
by Kuma
So, it's not a short shifter???
Posted: Wed Oct 17, 2012 4:46 pm
by yodasfro
Might help you figure this out http://forums.vwvortex.com/showthread.p ... eplacement
Posted: Wed Oct 17, 2012 4:53 pm
by Kuma
Ohhhhhh, it goes underneath.
Re: 1990 CQ- Short shifter installed! Tinted?repaired my tai
Posted: Sat Oct 20, 2012 7:29 pm
by Kuma
what do you think?
Posted: Sat Oct 20, 2012 8:02 pm
by SapperMike
Looks like it turned out great! Ill swing by Friday, ill be out in the field again from Sun-Thurs so now its three meets in a row ill miss.
Sent from my LT28at using Tapatalk 2
Posted: Sat Oct 20, 2012 8:12 pm
by DE80q
Came out nice. I have thought about doing the tails in my 80. Die you use film or spray?
Posted: Sat Oct 20, 2012 8:35 pm
by Kuma
sanded with 1000 grit and then wet sanded with 2000 grit
then cleaned them off
Sprayed 1 layer and waited 5 minutes
then sprayed 1 layer and wet sanded again with 2000 after it had dried
then automotive clear cause krylon is garbage. ill have to look at what we used to do it and report back
also, my radio died, my inside lights dont come on and my tail lights are dimmer on one side then the other, then they are perfectly fine later on... its driving me nuts. the bulbs are ALL NEW.
