Page 14 of 83
Posted: Thu Mar 22, 2007 10:57 pm
by djapothecary
just curious, and you may have said it well before hand, but how the f*** did you get the head that clean?!
I'm guessing sandblasting . . .
if so I'll just return to my cement patio with wire brush and degreaser . . .
Otherwise certainly more than a comendable project! it's re-igniting my love for my first 4000 and just causing me to eye the one down the street more and more.
Keep up the good work, and p'rhaps someday my ur-quat will gairner such high praises!
peace on it
dj apothecary
Posted: Fri Mar 23, 2007 12:18 am
by 90_Koop
Damn Derek! You are one meticulous doooood! love it. BTW: forgive the expression but the check (Money order) is in the mail for the CQ subframe and swaybar.
Posted: Fri Mar 23, 2007 7:12 am
by derracuda
djapothecary wrote:just curious, and you may have said it well before hand, but how the f*** did you get the head that clean?!
Othe,rwise certainly more than a comendable project! it's re-igniting my love for my first 4000 and just causing me to eye the one down the street more and more.
yes, the head was bead blasted by the machine shop. i'm not quite sure what medium they use, but it works :P
and yeah, i love the 4kq's. simple, good looking, distinctive lines.
90 koop, i'll be keeping an eye out for the check, i got the subframe and suspension dropped yesterday 8)
Posted: Fri Mar 23, 2007 2:49 pm
by Shawn M.
:o
damn..as usual looks amazing.
Posted: Sat Mar 24, 2007 11:08 am
by quattrostyle
derracuda wrote:either the old spoiler off larryflint's zermatt car, or the v8q spoiler off my now ruined alpine bumper, of which only the top half is toast.
do you have a picture of it? don't wich cars you mean cause I've just got here :wink:
Posted: Sat Mar 24, 2007 12:32 pm
by Audicted2quattro
So how much you going to sell it for when its complete derek......HAHAHA EVERYTHING HAS A PRICE :D :D :D
Posted: Sat Mar 24, 2007 6:03 pm
by derracuda
if you cut me a (good :P )check for $15k, i'd sell it.
Posted: Sun Mar 25, 2007 5:48 am
by Audicted2quattro
I should of took it when u were selling it for 2k LOL, But that still not bad !!! Sweet Car man, Cant wait to see it finished. Love the pics keep em comming. Maybe i can rob my brother (pharmacist) for 15k LOL
Posted: Sun Mar 25, 2007 7:16 am
by derracuda
yeah, well, the zermatt car i was selling for $2k is spoken for and should be leaving for indiana april 11th :)
Posted: Sun Mar 25, 2007 7:21 am
by AudiSport4000
Evansville IN to be exact? :D
Posted: Sun Mar 25, 2007 9:53 am
by Audicted2quattro
whoops it was a diff zermatt one :bashtard: lol
Posted: Sun Mar 25, 2007 10:00 am
by Wizard-of-OD
Ok so enough of this chatting...updates Derek!
Posted: Sun Mar 25, 2007 7:50 pm
by derracuda
Wizard-of-OD wrote:Ok so enough of this chatting...updates Derek!
i'll update when i'm good and ready! and when i have more updates..lol
and yes, evansville, indiana :)
Posted: Mon Mar 26, 2007 1:23 pm
by Clouse
What did you use to plug up the hole on your brake booster?
Posted: Mon Mar 26, 2007 1:57 pm
by derracuda
nothing yet, that will get hooked up to IM vacuum through a 1 way valve :)
Posted: Mon Mar 26, 2007 2:57 pm
by Clouse
Hmmm... what did you do for your MC in your white 4k? I can't find any good pictures of your engine bay.
I want to remove this ^, so it'll help to stop the dreaded ticking.
Posted: Mon Mar 26, 2007 3:27 pm
by derracuda
i just ran the hose to the IM on the white car. i never had a vacuum pump on it. you can just run a straight vacuum hose from the IM to the check valve on the brake booster and then pull the pump off the side of hte head and pull the rod out and then put it back to cover the hole.
Posted: Fri Mar 30, 2007 10:03 am
by derracuda
ahhh, two weeks are finally over :P
first thing's first, i had to bring one of my A8 rims down since this car is 5x112 now and see if a 235/40/17 would even remotely fit......
slight touchy touchy on the rear inner tie rod, but that's fixed with 2-3mm spacer
more clearance here than with my old 7.5" ET35 and 215's 8)
the fronts will fit too, but i need to rotate the steering arm a tad. otherwise, i'm pleased and will be looking for a couple more A8 rims and then ordering up some new 235/40/17 kumho ecsta SPT's 8)
this is how the car sits with 200 20v rear springs in the front, and 5ks rear springs in the rear..... high :P
Posted: Fri Mar 30, 2007 10:33 am
by Wizard-of-OD
:o
How many A8 wheels you have now?
Posted: Fri Mar 30, 2007 11:15 am
by derracuda
Wizard-of-OD wrote::o
3, only two are in useable shape. the third is missing a chunk of one lip
Posted: Fri Mar 30, 2007 11:24 am
by ralleyquattro
What size and offset are the A8 rims? Thanks!
Posted: Fri Mar 30, 2007 11:50 am
by derracuda
17x8 ET48 :)
Posted: Sat Mar 31, 2007 7:43 am
by derracuda
ok, got some more stuff put on yesterday, the IM is bolted on for good, the knock sensors are in and torque'd, spark plugs, the remaining 5 exhaust manifold studs came in and made their way home, some water temp sensors, the turbo, etc....
hey sparky 8)
i grabbed the waterneck off my 90q parts car and gave it a quick polish, not to bad for not even sanding it down or anything...
coming together nicely :)
also, i was going to put the wastegate bellow on and went... hmm, this is pretty ugly :P so i cleaned it up a tad and polished the ribs. it'll look sweet when the heat makes it change colors
the turbo is bolted on, the lines are cleaned but need to be installed, and the compressor housing need to come off as well as the wastegate cap for cleaning and then put them back. some final wiring in the engine bay, then mount the alt, front snubber, radiator, P/S pump, IC and plumbing, and then i can put a little focus on the wires that are important to making it run :D
Posted: Sat Mar 31, 2007 7:53 am
by Audilard
Dude, you can't leave that wastegate looking like that with everything else so nice and pretty! Get to work on that will ya!
But the rest looks fantastic.
Posted: Sat Mar 31, 2007 8:02 am
by s2 on the way
it'd be sweet if the wastegate was powdercoated black..........with a red turbo housing,,,,wait, that would be biting rj with the housing.....
but the turbo side needs to be matching since all else is so pretty and perfect....
would the downpipe and headers take to powdercoating and hold with all the heat?
looks great.......
