Page 16 of 31
Re: 1990 CQ- Prep for paint! Sanding and primer-Paint soon!
Posted: Tue Oct 23, 2012 5:57 pm
by Repaair
When you get tired of it you can lock the brakes up a few times and peel it off.
Posted: Tue Oct 23, 2012 6:07 pm
by Kuma
plastidips lasts pretty well on wheels, as my buddy has his wheels dipped and they havent peeled yet. Going on three months.
next time hes going to dip them Purple. they have the new BLAZE colors out now.
Posted: Tue Oct 23, 2012 6:43 pm
by EasyTarget
Body filler is not meant to be used to fill holes. It has different expansion rates than the material it is applied on, and I can guarantee that you will be able to see that hole shortly after it is painted. I would recommend that you chip that filler out and use a two part epoxy resin to fill the hole, then finish with a glaze of filler. Also, I wouldn't suggest using spray can primer if you ever plan on having a quality urethane paint applied over it, as the products are not compatible.
But the car looks good, and I'm excited to see the finished product!
Posted: Tue Oct 23, 2012 7:11 pm
by Kuma
i didnt know that! well, its not permanent anyways. It will all get sanded off again anyways in a few years. This is just to get it one solid color for a car show coming up and to hault some creeping rust.
plus, i hate the color white.
any info thats helpful is always welcomed!
thanks
Posted: Wed Oct 24, 2012 7:23 am
by Kuma
Will these fit my cq?
http://killeen.craigslist.org/pts/3303801793.html" onclick="window.open(this.href);return false;
Posted: Wed Oct 24, 2012 8:00 am
by DE80q
Should, they are the ford 4 lug which is the same. Ask about the offset though.
Posted: Wed Oct 24, 2012 8:09 am
by Kuma
Guy says et18 215-55-16 tires
Posted: Wed Oct 24, 2012 8:13 am
by DE80q
I think you will need spacers, and not sure about the tires
Posted: Wed Oct 24, 2012 3:29 pm
by Kuma
awesome... Discovered a GIANT crack in the front subframe.
BUT i am gonna go and get another one in Dallas in a week or so.
Re: 1990 CQ- Paint on Friday-Broken front Subframe)-;
Posted: Wed Oct 24, 2012 4:04 pm
by Kuma
the car is still bogging down. What are some reasons the car will bog down or misfire?
it has new 034 injectors 3000 miles and complete top end rebuild as well...
dunno about the knock sensors
dunno if its the dizzy
not sure if its the fuel filter
...yet
when i start the car the idle jumps up to 1300 RPMS and stays there for a few seconds, then levels out at 1000RPM.
then when i am starting off the car will bog down then launch then bog down then stutter, with my foot on the gas. if im at idle, its chill no issues. the RPMS will creep up to 1300 RPM when im sitting at a redlight, but if i tap the gas pedal it will go back to normal.
Its wierd.
Posted: Wed Oct 24, 2012 6:51 pm
by ur20v
Vac leak?
I have the original front subframe from my Coupe. Pick it up when you're in town. Price as we discussed!
Posted: Wed Oct 24, 2012 6:56 pm
by Kuma
i will! I'll give you a call when i get up close, how far are you from the car show? its on East Lamar? or what have you or near there. the website is down.
You gonna go?
how do i track down a vacuum leak?
Posted: Wed Oct 24, 2012 7:08 pm
by scubadave
Look over the intake boot very carefully and you may find a crack. They do crack pretty easy when they are as old as they are. I had a crack in mine and cleaned it as good as I could, sealed it up with a dabble of the Right Stuff. ( good quality silicone ) you can spray carb cleaner or flammable brake cleaner around connections, hoses, gaskets that have to do with the intake tract/vacuum while the engine is running. When you hear the idle go up on its own, you found a leak. It's kindof a getto way of doing it but it works. Don't set yourself on fire. Or find a buddy wither a smoke machine and find it the pro way.
Posted: Wed Oct 24, 2012 7:13 pm
by Kuma
intake boot you say?
that can cause all that to happen?
guh, okay, i will have to check it tomorrow when the light is out.
Thanks Dave.
Posted: Wed Oct 24, 2012 8:12 pm
by rally3
Another thing to check is the throttle position sensor, you will need an ohm meter and and probably a wiring diagram to check it's sweep for glitches,
Later
Aidan
Sent from my Xoom using Tapatalk 2
Posted: Wed Oct 24, 2012 8:15 pm
by Kuma
okay, note taken.
i feel like sometimes maybe my throttle body is getting stuck open?
Posted: Wed Oct 24, 2012 8:22 pm
by ur20v
Hope you don't need a TPS. I think they are about $350 now if you can find one.
Posted: Wed Oct 24, 2012 8:26 pm
by Kuma
fuchhhh.
are the 3b ones swappable?
Posted: Wed Oct 24, 2012 9:26 pm
by scubadave
I don't believe so. I have a couple extra so don't fret just yet. As long as its the hitatchi components that is. I may need to start charging you for all my spare parts though. I even have that spare intake boot I repaired if you need it.
Posted: Wed Oct 24, 2012 9:47 pm
by Kuma
im down.
by 90quattrocoupe
Kuma85 wrote:plus, i hate the color white.
Too bad. Alpine is a rare color.
Greg W.
Posted: Wed Oct 24, 2012 10:02 pm
by Kuma
90quattrocoupe wrote:Kuma85 wrote:plus, i hate the color white.
Greg W.
it will always be Alpine at heart.
Posted: Wed Oct 24, 2012 10:08 pm
by CollinsCj
Hey trade me Alpine White for my Tornado Red!
Posted: Thu Oct 25, 2012 3:45 am
by audiPete
Throw some isopropyl alcohol gasoline dryer into the gas....i've pulled my hair on similar symptoms before and it was water in the gas...also check for tears on the underside of the intake boot, where the crankcase ventline enters
Posted: Thu Oct 25, 2012 4:22 am
by Kuma
okay, ill take a peep at the boot today.
alcohol you say? that makes sense. how much?
EDIT: nvm, ill just ask at the parts store.
Cj, how are we gonna trade you all the way up north!!!
but ill take that 3B you got!
