Re: AMD's 91 200q Project
Post by jbrentd »
Car looks and sounds great Nick!
crappyoldaudis
"HD" alt
Post by crappyoldaudis »
Al those "rebuild" shops do is spray paint the body and put in a new regulator, which is held to the back with two screws. you can get the "HD" regulators (bosch!) from any worldpac supplier for $30 and put it on yourself. If you actually have a bad bearing - usually from overtight belt and/or 20 years of at spray (makes noise), you'll want a $$$ Bosch rebuild to insure you have good bearing otherwise, take apert the housing and get a known high quality bearing from Timkin or whoever. The $100 rebuilts probably use chinese bearings.
amd is the best
Post by amd is the best »
Damn throttle cam broke. I appoxied it back together and I hope that'll hold. If not I'll have to suck it up and buy 034's steel one.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
lol mine broke too and I zip-tied it back together
amd is the best
Lol, common failure I take it? I haven't been on much lately. How's your car??
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
yep, pretty common these days considering the age of these cars.
My car is doing alright... its still not running yet because I'm waiting for my Bilsteins to get back (shortened and revalved) and for Hank to finish up my new tubular exhaust manifold, dp, and wg reroute :) Then it will be back together enough to at least move around and hopefully fab the rest of the exhaust and ic piping soon. Then I'll beat on it a bit on low boost (on the HX52 :D ) and next summer it comes apart again to do engine build and tranny! Meanwhile I've got a '94 530i to drive around. I just broke that too though. Should be back together by the end of the week lol
gtn116
Post by gtn116 »
hells yeah zip ties. I have a 944 TB that has a nice metal cam on it. I might use it on my car.
yodasfro
Post by yodasfro »
amd is the best wrote:[/quote]Damn throttle cam broke. I appoxied it back together and I hope that'll hold. If not I'll have to suck it up and buy 034's steel one.[/quote]
Mine broke too I made one from a 20vt work briefly(read couldn't keep it tightened down because of the stupid metal sleeve) before having to purchase the 034 piece which is nice. But in my opinion could be made better if the hole was sized to the shaft of the throttle body. Yet instead you must use the stock metal sleeve which made tightening it down a chore.
amd is the best
Epoxy failed. Ordered 034's steel cam. Can't have it break on my 7 hour trip to H2O.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Ronald G Wainwright+
Post by Ronald G Wainwright+ »
U using ARP studs? And if so why?
amd is the best
Ronald G Wainwright+ wrote:[/quote]U using ARP studs? And if so why?[/quote]
ARP studs for what? All of my engine is unopened and bone stock...
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Huh......thought u were running some power through this car?
amd is the best
Ronald G Wainwright+ wrote:[/quote]Huh......thought u were running some power through this car?[/quote]
I am...on a stock engine. Somewhere around 375-400awhp if I were to guess.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
So ur using stock head bolts?
amd is the best
Ronald G Wainwright+ wrote:[/quote]So ur using stock head bolts?[/quote]
amd is the best wrote:[/quote]Ronald G Wainwright+ wrote:[/quote]U using ARP studs? And if so why?[/quote]
All of my engine is unopened and bone stock...[/quote]
Yes sir.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
I was using them at 24psi with my 56mm turbo (equivalent to 30r). Have ARP's now because I for one WILL be taking the head on and off several times in a short period and I'll probably need them soon as far as tensile strength is concerned. For boost... not for detonation lift lol.
amd is the best
loxxrider wrote:I was using them at 24psi with my 56mm turbo (equivalent to 30r). Have ARP's now because I for one WILL be taking the head on and off several times in a short period and I'll probably need them soon as far as tensile strength is concerned. For boost... not for detonation lift lol.
Lol. Lots o boost! When I go through the engine this winter I plan do do ARP's everywhere.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
A few recent pics for fun:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
What's ur boost level now?
jcarrick
Post by jcarrick »
Man i love your car Nick! Before you tear down the motor this winter you gotta get some dyno numbers for that stock motor :)
amd is the best
Ronald G Wainwright+ wrote:[/quote]What's ur boost level now?[/quote]
I'm back on pump gas for my trip to H2O next weekend so it's around 20-21psi. On E85 I was running a bit more...23-24psi.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
jcarrick wrote:Man i love your car Nick! Before you tear down the motor this winter you gotta get some dyno numbers for that stock motor :)
Thanks Jon! That's actually a great idea. I'll wait until it's nice and cold so my (still) stock intercooler has a better shot at staying cool ;).
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Thank u.
CH's look awesome
amd is the best
loxxrider wrote:CH's look awesome
Thanks Chris. I like them on there too. A tiny bit more poke in comparison to the RK's too because of the extra half inch of width.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
