Page 19 of 49
Re: Casey's 200 20v: Motor is in!
Posted: Wed Jul 06, 2011 3:28 pm
by Hank
Noted. This was my first attempt at a 200 motor. I have one here that I could do off the pictures you gave, or we could just get yours in the mail for rework.
Posted: Wed Jul 06, 2011 4:11 pm
bahaha "why? because race car."
Posted: Wed Jul 06, 2011 5:44 pm
by WOMBAT
ShavedQuattro wrote:Noted. This was my first attempt at a 200 motor. I have one here that I could do off the pictures you gave, or we could just get yours in the mail for rework.
Awesome! If you'd like I'll just send mine back to you, I don't mind!
Address?
Ps - thanks! I don't see this as a hassle at all, I appreciate your dedication to perfection 8)
Posted: Thu Jul 07, 2011 10:37 am
by my2000apb
theres plenty of room to lower the motor and trans before any issues come up, 10 mm is easy
Posted: Fri Jul 08, 2011 5:11 am
by WOMBAT
my2000apb wrote:theres plenty of room to lower the motor and trans before any issues come up, 10 mm is easy
Hanks the man and has already figured out a T44 solution 8)
Posted: Fri Jul 08, 2011 5:31 am
by my2000apb
sweeet
Posted: Mon Jul 11, 2011 2:18 pm
by WOMBAT
Getting closer.... Sending the mani tomorrow Hank!
Posted: Thu Jul 21, 2011 4:37 am
by WOMBAT
More work completed!
First task was to replace the non functioning ebrake cables...
New
Nice to have an ebrake finally - never did before on this car
Next up I wanted to swap my springs front to rear, as the car felt unbalanced and rode like a pickup truck.
and out of curiosity I wanted to see if my wheels/tires would contact the fender, and it looks ok - even at this level there wasn't contact! But I still wish the wheels were sized properly... some other day when I have funds to throw at it.
T44 guys understand that when you put Bilstein sport shocks in the back of your car, a mysterious knock comes around and drives you nuts. You replace every suspension component and it still doesn't go away. I have always thought that it sounded as though the strut was hitting the body... welllllllllll yes it is!
smooooshed
Time to space the struts a bit to lessen the amount of threads above the strut mount!
~20mm
Washer spacers
~16mm. We'll see if that takes care of the knocking.
With the car back on jack stands I reinstalled the driveline
and then spent lots of time getting all of the plastic in the front end back together - the brake ducts, radiator ducting, and making small connections like the horn, oil temp/pressure, etc... I dropped the rear ride height 12mm to lessen the rake. Eventually it looked like a car again!
And a shot of the office... Sure do miss spending time here
All of this push was to get the car in one piece to move out of the shop since we've been asked to vacate, now delayed to Sept. 1st. What remains to be done is the intake/IC plumbing, Turbo back exhaust, ECU, and TIGHTEN THE CRANK PULLEY!!! Can't forget that one.. That's all for now 8)
Posted: Thu Jul 21, 2011 8:42 am
nice job man, I'm having to push to get mine back together too. I do miss the old girl already! Looks great.
Posted: Thu Jul 21, 2011 8:48 am
by Hank
Can you give ne a dimension from the back of the head to the firewall? Do it by where the cam seal is on the drivers side
Posted: Thu Jul 21, 2011 8:50 am
by WOMBAT
ShavedQuattro wrote:Can you give ne a dimension from the back of the head to the firewall? Do it by where the cam seal is on the drivers side
Will do!
Posted: Thu Jul 21, 2011 8:59 am
by WOMBAT
Hank - there really isn't a passage for a forward facing intake on the 200.... The guys at Rene Rumler used a smaller radiator and moved it back for clearance... Might be worth pursuing
Posted: Thu Jul 21, 2011 9:30 am
by pilihp2
is that what the knock comes from!? Cool! It's driving me INSANE!
I wonder if drilling a larger hole in the area where it contacts would work as well?
Posted: Thu Jul 21, 2011 9:35 am
by WOMBAT
pilihp2 wrote:is that what the knock comes from!? Cool! It's driving me INSANE!
see what's above that hole.. if all looks clear, give it a shot!
Posted: Thu Jul 21, 2011 9:38 am
by yodasfro
There is suppose to be a rubber spacer on the rear bilstein's. It sits on top of the washer at the base of the threads, also be careful not to over tighten the top nut with said spacer installed.
Posted: Thu Jul 21, 2011 9:40 am
by WOMBAT
yodasfro wrote:There is suppose to be a rubber spacer on the rear bilstein's. It sits on top of the washer at the base of the threads, also be careful not to over tighten the top nut with said spacer installed.
Mine didn't come with any? Well phooey.
Re: Casey's 200 20v: Looking like a car again
Posted: Thu Jul 21, 2011 9:45 am
by pilihp2
which rubber spacer? the big rubber mount? like this?
Edit: oh, at the BASE of the threads.
I don't have that either...
Posted: Thu Jul 21, 2011 10:14 am
by yodasfro
See pic
Attachment ( 27055 ) : W01331604189BIL.JPG
Posted: Thu Jul 21, 2011 11:45 am
by Glug
lou king good my man
Posted: Thu Jul 21, 2011 11:55 am
by autoholic
That is one nice T44, like what you've done with it. Love that intake and header.
Just curious, parking it all winter?
Posted: Thu Jul 21, 2011 12:03 pm
by WOMBAT
It hibernates for the winter, otherwise Vermont would rust it back from whence it came 8)
Posted: Thu Jul 21, 2011 12:49 pm
by autoholic
Yea, i figured. Not sure if my 4k will be parked, such a shame with such a fun blizzard car. I drove it last winter a little bit. I'm going to cosmoline the heck out of it like i did my MB wagon. I drive the MB year round and the cosmoline really helped. I completely tore out the interior, cleaned out rockers, doors, floors, etc and coated it all like 5 yrs ago, holding up pretty good. Such long winters to park a car, I sooo effing hate salt!
Posted: Thu Jul 21, 2011 1:08 pm
by WOMBAT
Thanks for the kind words guys! Yoda, that looks like the solution! I bet it got chucked since I'm a big ol dummy.
Yea, the 200 enjoyed a couple winters and it was fantastic! I just can't let the salt get to it anymore. I'll have to pick up a beater quattro some day for the winter. Nothing goes through the snow like these old things... Puts my subie to shame
Posted: Thu Jul 21, 2011 2:52 pm
by Ronald G Wainwright+
U said u swapped springs (front to back) whats ur spring rates again?
WOMBAT wrote:I'll have to pick up a beater quattro some day for the winter. Nothing goes through the snow like these old things
Well the convert is no beater.....but a fine Winter beater she is ;-)
Posted: Fri Jul 22, 2011 8:07 am
by my2000apb
ya casey! get er did
