Page 19 of 76
Posted: Sun Aug 20, 2006 5:05 pm
by HT Motorsport
Plumbing and the oil cooler look great Mark, I am jealous as I had to work today :( so no V8 fun for me.
H
Posted: Sun Aug 20, 2006 5:23 pm
a4kquattro wrote:audifreakjim wrote:Nice oil cooler, I need one like that.
B&M 12x12 80 bux(!!) at summit racing. I've heard people bitch about the quality but frankly I haven't had a problem (I run one on my wagon too). You just have to make sure to use a wrench to secure the socket on the oil cooler when spinning on the 1/2" NPT adapters, otherwise the metal will twist.
Sweet, looks like I have another project coming
Posted: Sun Aug 20, 2006 5:32 pm
by Josh
Hi mark I happen to notice today that the v6 starters have a longer gear than the 7a starter. I suspect that the starter you got was from a v6 setup.
I'm not sure but figured I mention it. I happened to be reading your thread and wasn't sure if you knew why it happened.
If anything I'm happy I saw the difference so it doesn't happen to me.
Posted: Wed Aug 30, 2006 10:11 am
by WAUG0806
:bump:
Posted: Wed Aug 30, 2006 11:14 am
by Ronald G Wainwright+
Josh wrote:Hi mark I happen to notice today that the v6 starters have a longer gear than the 7a starter. I suspect that the starter you got was from a v6 setup.
Are you refering to the starter gear marks on his FW & the spacer he had to make?? if
so I can assure you that the starter is from a V8q. The reason I know that is cause the starter was mine & I gave it to him.
Posted: Wed Aug 30, 2006 11:22 am
by Alloutofdonuts
Mine(starter) did the same thing to my AL FW(I think Marc and I are using the same AL FW, Spec clutch?) but I didn't have the problems that Marc did with his. IE: mine dug into the FW, but it just chewed into it, it didn't keep it from rotating
. Not sure why that is. :?
When I asked about it I was told it was a good sign, meaning it was making full contact and at least it wasn't doing th opposite
Posted: Wed Aug 30, 2006 11:57 am
by Josh
well it seems some of the starters have different gears. My 7a starters are about 3-5mm shorter than the v6 starters.
Posted: Wed Aug 30, 2006 12:55 pm
by Toxcheap
Alloutofdonuts wrote: IE: mine dug into the FW, but it just chewed into it, it didn't keep it from rotating
Didn't stop Marc's either, I noticed that this battery was no good and that's why it wasn't cranking right.
Posted: Wed Aug 30, 2006 1:47 pm
by Marc
Toxcheap wrote:Alloutofdonuts wrote: IE: mine dug into the FW, but it just chewed into it, it didn't keep it from rotating
it slowed it way the hell down tho, because the starter ring gear failed to retract after ignition off, so I was fighting the torque of the starter motor on every crank revolution by hand.
Posted: Sat Sep 02, 2006 7:01 pm
by Marc
got a bit of a late start at the shop today since I had to deal with some web server shiz (some of you may have noticed motorgeek was down the AM, that would be part of it...)
Anyway, got some intake plumbing further along today. I had to switch to a different gas tank for my welder because they sold me argon last time that.. isn't.. argon. Dunno what the hell it was but the welds were coming out ugleeeee as sin.
I've got very little clearance between the small front mount intercooler and the outlets but by cutting the stock outlets off the core and welding on 45 degree pieces of mandrel bent pipe I was able to clear the bumper with no cutting:
The drivers side intake plumbing is pretty much done.. I just need to get some more 2.5" mandrel bends to finish everything up.
Shot of the plumbing into the intake manifold:
The 'y' pipe will join somewhere down here:
As for an intercooler for the passenger side turbo, my stock S6 intercooler was too big, so I bought a small intercooler of an eclipse that will take its place.
More updates tomorrow, I'm hoping to have the radiator sealed up by then :woowoo:
Posted: Sat Sep 02, 2006 7:07 pm
by Marc
other happenings around the shop:
Dennis has been busy :-D
Eventually a k24 will live there, with a 20v/20v style external wastegate :-D (needs to move the wastegate flange a bit tho)
New brake lines on his UrQ too, nice job Den!
Note to self, use somma that stuff next time I need to do a brake job (plastic coated steel tubing)
Posted: Sat Sep 02, 2006 7:33 pm
by Josh
looks good mark.. Hope the package came in one piece.
:-D
Posted: Sat Sep 02, 2006 7:37 pm
by Derracuda
yeah MarC.... looks real good
Posted: Sun Sep 03, 2006 2:56 am
by 3bAudios
always nice to see you making good progress marc, makes me wish i had some more motivation for my damn projects....how long untill she'll be ready for a road test?
Posted: Sun Sep 03, 2006 4:22 am
by HT Motorsport
[quote="a4kquattro"]other happenings around the shop:
Wait, what car is that Mark?
H
Posted: Sun Sep 03, 2006 4:24 am
by Marc
timmmy wrote:Wait, what car is that Mark?
Dennis's A4.
Posted: Mon Sep 04, 2006 12:51 pm
by Marc
spent part of today working on teh car.
pressure testing the radiator
I ended up completely redoing the y-pipe from the version I had initially built for the NA setup. I wanted a closer ratio 'y' so I ended up fabricating one that joins at about a 30 degree angle
and the finished y-pipe to downpipe exhaust section
I also installed a 3" car chemistry insert after the collector
All I had to do was just drill some small holes where I wanted the insert to sit and tack weld the insert in place. I really like these things.
Still need to fabricate the rear section, probably next weekend :woowoo:
Posted: Mon Sep 04, 2006 1:01 pm
by 3bAudios
im dumb, what is a 3" car chemistry insert? what does it do?
Posted: Mon Sep 04, 2006 1:04 pm
by Derracuda
i don't remember when or where it was said to get those muffler baffle things. i'd like to try one on my v8 setup
Posted: Mon Sep 04, 2006 6:53 pm
by Toxcheap
Man those y-pipes look like they came out awesome!! :woowoo:
Posted: Mon Sep 04, 2006 7:26 pm
by RockinV8q
3bAudios wrote:im dumb, what is a 3" car chemistry insert? what does it do?
Its a stealth chambered muffler. Check Car Chemistry's website for a full explanation.
Posted: Mon Sep 04, 2006 7:28 pm
by RockinV8q
derracuda wrote:i don't remember when or where it was said to get those muffler baffle things. i'd like to try one on my v8 setup
I think I know where the idea comes from.
Posted: Mon Sep 04, 2006 7:29 pm
by Marc
RockinV8q wrote:derracuda wrote:i don't remember when or where it was said to get those muffler baffle things. i'd like to try one on my v8 setup
cabrio Q
I had heard of car chemistry inserts before.. in fact I threw one into an 80q I used to own to quiet down a single muffler setup I had on the car at the time. Worked like a champ.
Posted: Tue Sep 12, 2006 9:21 am
by Marc
'new' intercooler for the passenger side turbo arrived today. I shouldn't have any difficulty fitting this into the available space.
This one is a stock unit off a mitsu eclipse:
Also, I never posted these pics from last weekend, did a little more work on the exhaust (added bung for wideband, started mounting MR2 power steering pump)
And here's what the PO of my coupe thought was a 'cool' exhaust system mod. Cripes, most of the adnoH ricer tips I've seen aren't even this big :-P :bashtard:
Posted: Tue Sep 12, 2006 9:32 am
by Derracuda
i'm gonna bet that you get a lot of P/S harmonics with it mounted solidly to the fender well there
