Page 20 of 49
Re: Casey's 200 20v: Looking like a car again
Posted: Wed Aug 03, 2011 4:33 am
by quattro87
Had to refresh my mind on your project. Looks like a way nicely done T44. I've probably got a lot more miles in T44s than I do in small chassis Audis and still have that soft spot for them. Yours looks clean.
Posted: Wed Aug 03, 2011 5:01 am
by WOMBAT
Thanks!! It means a lot to me! I've wanted to build a 200 20v for over 7 years.... Slowly but surely getting there.
Posted: Thu Aug 04, 2011 12:35 pm
by 3B'dB3
You are soo close! Get to it!
Posted: Thu Aug 04, 2011 1:39 pm
by WOMBAT
I know... Gotta make that money 'fo I spenz it!
Right..
Next rare part - strut tower brace! Hits the hood though, so I will need to persuade it downward.
Posted: Fri Aug 05, 2011 5:35 am
by my2000apb
can it be flipped?
Posted: Fri Aug 05, 2011 6:28 am
by WOMBAT
my2000apb wrote:can it be flipped?
Interesting idea.... but no - that would make the mounting surface to the strut towers completely backwards angle-wise
Posted: Fri Aug 05, 2011 6:32 am
by my2000apb
sell it and well weld one in
Posted: Fri Aug 05, 2011 6:39 am
by WOMBAT
my2000apb wrote:sell it and well weld one in
All I have to do is put each end in a vice... et voila. Plus I like that it's a TAP piece that is NLA. Welding one in would make it a bit of a hassle to work behind the motor too..
Posted: Fri Aug 05, 2011 10:31 am
by Ronald G Wainwright+
Cut the frame piece that the bar hits on the underside of the hood.
Posted: Fri Aug 05, 2011 10:37 am
by my2000apb
yeah jstu cut the hood
Posted: Fri Aug 05, 2011 10:41 am
Yeah............depending on how much more clearance he needs looks like there is at least 1 1/2 of material that can be cut out before he gets to the hood sheet itself.
Cut out what hits and then box it back in.
Posted: Fri Aug 05, 2011 10:53 am
by WOMBAT
heck no! I'm not cutting my hood supports up! Y'all er crazy! But you already knew that.
It's just aluminum... I'll bend it .75" downward to clear the hood.
Posted: Fri Aug 05, 2011 11:18 am
by my2000apb
its ok i know im crazy i cut the helloutta my cq
Posted: Fri Aug 05, 2011 12:48 pm
by k2exoman
WOMBAT wrote:
Where'd you come across one of those?
I was considering sourcing some c4 strut brace mounts and coming up with something custom...
Posted: Fri Aug 05, 2011 1:21 pm
by WOMBAT
I snagged it up quickly from someone on here selling two of them used... Before that, I didn't even know they were made!
Posted: Fri Aug 05, 2011 1:56 pm
by 3B'dB3
+50 points for the NLA parts factor
Posted: Fri Aug 05, 2011 6:59 pm
by tbar
Wow, that look awesome! Nice score on the bar, too...and definitely try to bend not cut.
Posted: Sat Aug 06, 2011 4:48 am
by fasterthenrs2
Nice get err done
Posted: Sat Aug 06, 2011 6:34 am
Not to argue the point....read...NOT to argue the point but,
I just don't c the big deal here. The support's aren't even welded or seam sealed the whole length of it.
I cut out the support on a spare V8 hood and bolted it up. I left the hood shock supports and used hood pins at the bottom (or front of the hood) and it wasn't flapping around while driving.
Mind u I only tested it for a few rips around the local streets and highway, so I can't say for sure if the hood would just rip off the car at speed but u would only be cutting a small amount of it and then just boxing it back up to form a outline against the under side of the hood.
That's all :-)
Was that TAP bar intended for a type44 casey?
Re: Casey's 200 20v: mounting the intercooler
Posted: Sat Sep 10, 2011 11:10 am
by WOMBAT
Started working on getting the IC mounted today
Moved the aux radiator upward to make room for the IC - This also lets me keep the hood latch
Then I wanted to use the stock crossmember and snub mount, so I had to do some cutting... welding to follow
Removed:
Modify snub
Cut the crossmember and will weld in some gusseting
About 3/4" between pulley and IC
Here's where I left off:
Posted: Sat Sep 10, 2011 12:58 pm
by jcarrick
Looking good! Did you get your intake mani figured out yet?
Posted: Sat Sep 10, 2011 1:17 pm
What trans and motor mounts u got?
Posted: Sat Sep 10, 2011 1:48 pm
by Matas
How that thing is call that goes from one shock mount to another? Does it have any sensible effect?
Here's an interesting mounting of the intercooler
Full thread if someone is interested
http://www.audiklubas.com/forumas/index ... 131.0.html" onclick="window.open(this.href);return false; ... 131.0.html
Posted: Sat Sep 10, 2011 1:51 pm
Its called a strut tower bar and I don't think Casey has driven the car with it on. Its good to have though because the stock firewall cracks where it meets the strut mounts. The strut bar should help that from propagating.
Posted: Sat Sep 10, 2011 2:56 pm
by a-talk
I'm the one that sold that strut bar to Casey. I called TAP one day and asked if they had any left, and they told me they had two 20v bars in the back that were beat up. Bought them cheap, and I ended up selling them both for cheap since they didn't really fit my 20v, but appeared to be 20V bars.
And then I bought a 20v TAP bar from Steve Ankney (that was actually mounted on his 20v 5000TQ), and funny enough it hits a hard fuel line when I try to bolt it onto my '90 10VTQA! Haven't had the time to mess with figuring out how to mount my TAP bar. Haven't had much time to do anything to the cars of late - new house.
Regardless, it looks great Casey!
loxxrider wrote:Its called a strut tower bar and I don't think Casey has driven the car with it on. Its good to have though because the stock firewall cracks where it meets the strut mounts. The strut bar should help that from propagating.
