Page 20 of 62
Re: Matt's 87 4ktq -
Posted: Sat Jul 27, 2013 2:14 am
by 85oceanic
YAY!!!!
Posted: Sat Jul 27, 2013 10:21 am
by AngryTaco
I thought I was the only person with an epic rack lol
Posted: Sat Jul 27, 2013 1:45 pm
For ducks sake. Injector 5 stuck open when ECU is connected. With ECU connected, 5 shorts to ground. With it disconnected and key on it doesn't go to ground. I'm *slightly* frustrated. I'm hoping i can assign a different output for it and bypass the whole fet. I just don't understand wtf is happening because Jason said it was good to go.
Sigh.
Posted: Sat Jul 27, 2013 4:07 pm
Bit of a development. I took the ECU apart to see if I could find any shorting out and found nothing. But I did find this:
If you compare that to my older "Fried" photo:
You can see that an ignition driver is missing. Made a mental note, took a picture, and then I reinstalled the ECU. Woo! #5 isn't stuck open! So whatever was going on isn't anymore (WEIRD)
But now I have a new problem. #5 has no spark. Tested the systems by swapping connectors at the coils, and verified coils/wiring etc. is good. I'm wondering if it has to do with the missing driver (HUUUUUUH). And, can I swap pins or splice some wires to use a different ignition circuit?
On a positive note, the timing was way off. I really don't know wtf was going on with the old settings but I moved the TDC after trigger by like 16. Not sure if that's in degrees or what, but now it's bang on - 1 degree (as close as I could get to 0, non-adjustable gun) is just a wee bit advanced on the wheel. Perfeeeeect. So now the car runs great. On 4 cylinders. Fak.
Posted: Sat Jul 27, 2013 4:21 pm
Just got off the phone with Marc. I can just repin to an unused ignition driver. It wasn't replaced because Marc took the driver out and then Jason took over the operation, so Jason just put it back the way he got it. Really not anyone's fault and it's an easy fix. WOO. Tomorrow... maybe. Need happy wife first.
Posted: Sun Jul 28, 2013 5:42 pm
Back to square 1. Injector 2 and 4 firing at the same time again.
Posted: Mon Jul 29, 2013 12:17 pm
by jretal
Is the ECU bad? Or do you have a break in the wiring somewhere that's causing an issue?
Super frustrating, Matt... sorry you're going through this! I feel your pain right now.
Posted: Mon Jul 29, 2013 1:27 pm
by themagellan
Time to invest in a downdraft carb
Posted: Mon Jul 29, 2013 1:42 pm
Lol mage. Last test today (when I get home) is to swap my coils to our running parts car, swap the ecu over and see if the problem follows the ecu. If so, it's off to Marc to be replaced under warranty. If not then I've got some annoying troubleshooting to do.
Posted: Tue Jul 30, 2013 7:52 pm
[youtube]http://www.youtube.com/watch?v=hw9RXZNPmlE[/youtube]
Guess it's time...
Posted: Tue Jul 30, 2013 7:58 pm
by 85oceanic
Dude, that is unhealthy.
Posted: Tue Jul 30, 2013 8:16 pm
by Mcstiff
Does the harness test as sound (no continuity between channels)?
Posted: Tue Jul 30, 2013 8:27 pm
The video is my ECU on an Scar (tested on two different cars). But before that test, yes, we isolated and tested everything.
Posted: Tue Jul 30, 2013 9:24 pm
by Mcstiff
Ahhhhhhh. Yeah, thats no good!
Posted: Wed Jul 31, 2013 11:11 pm
by WOMBAT
WTFBBQ this car needs to run! You have patience of steel my friend.
Re: Matt's 87 4ktq - "4 FOX SNAKES"
Posted: Thu Aug 01, 2013 10:26 am
You're telling me!
on my stinking phone!
Posted: Sun Aug 04, 2013 8:52 am
New ignition switch ordered. Sweeeet. That bastage was getting really hard to turn/start.
Posted: Wed Aug 07, 2013 9:43 am
by highlander69
Is it done yet :D
Posted: Wed Aug 07, 2013 10:19 am
You know there'd be driving video if it was!
Posted: Wed Aug 07, 2013 7:26 pm
by 85oceanic
I'm ready to see some driving videos!!! :D
Posted: Wed Aug 14, 2013 2:43 pm
I prepped the car a little last night for when the ecu comes in. I'm going to test the injectors before I try to fire it up. I might try replacing the ign. switch tonight, we'll see how much free time I have.
Posted: Wed Aug 14, 2013 3:09 pm
Patience patience patience patience
Posted: Wed Aug 14, 2013 3:29 pm
by Marc
if it gets tight on time I can replace your ecu with one in stock here. they started sending out ship notices for some other stuff I ordered so chances are good you'll have everything in time. I'll have an update for you via email on it soon.
Posted: Wed Aug 14, 2013 3:30 pm
Thankths Maaarrrc
Posted: Wed Aug 14, 2013 6:01 pm
Well that was a fucking waste of time. Ignition button here I come.
