Nick's Black 90 - 3B Swap: Running!
Nick's Black 90 - 12 Months left until next BBQ
X3 on the shelf being a pain. I gave up on doing it in my last 1991.
nsimps
Re: Nick's Black 90 - 12 Months left until next BBQ
Post by nsimps »
I took off the one bracket on the left for the other trim piece and it fit in there nicely, but lining up the mounting points was a huge pain. It hasn't fallen yet so it will probably stay that way until I decide that I need an excuse to get all worked up over a silly little shelf :wink:
nsimps
Post by nsimps »
Audilard wrote:Leave them green so I can make sure you don't try to get in my car and drive away. :) This car looks more and more like mine every day!
Where do you think I am getting all this inspiration? :D I'm going kinda backward (if you ask Hank), however these are easier tasks and less expensive than turbo/vems/fmic/etc. Soon though, Soon.
Post by jbrentd »
Mcstiff wrote:X3 on the shelf being a pain. I gave up on doing it in my last 1991.
Was your shelf from a coupe? I think I made the mistake of getting one from a sedan and it is completely different than my coupe's knee bolster.
Wheeljack
Post by Wheeljack »
Mine was from a sedan, and once I cleared out some space (mostly the cutting and bending the brackets connected between body and edge of dash on the left on the 91s), the mounting holes all lined up and bolted up fine.
http://brydon-eng.com
nsimps
Post by nsimps »
Mine was from an 80 sedan. But all I had to do was remove the two side brackets, and the other bracket on the left that the other bracket was attached to (phew, that was convoluted). After that the fitment was fine, just trying to line up the mounting points was a pain. This would be true for the OEM one as well on the top mount points.
Good question! I'll have to make sure I get one from a coupe if I decide I want it.
Hybrid_Hatch
Post by Hybrid_Hatch »
mine was from a sedan and fit perfect in my coupe, just needed to remove the brackets as stated above.
Post by jbrentd »
I'll take a look and see. Thanks for the suggestions.
nsimps
Re: Nick's Black 90 - Intermittent Flooding issue
Post by nsimps »
oops. I made a noob mistake :-)
nsimps
Post by nsimps »
Over the last few weeks an issue has been getting worse. Here is the low down on what is happening.
Intermittently, and especially when the car is cold I will have the throttle steady (to maintain speed limit) and the engine will start bogging down. If i give it a little more throttle it will get worse. If I give it full throttle it will get better and accelerate but still act like it is bogging down. If I lift my foot off the throttle and then press on the throttle it acts normal for a few seconds. It will then go back to the flooding issue. It will eventually go back to normal. I recently took a 300 mile road trip and on the way back I had this issue come up ~10 times.
Note that I recently put in different Cat and had to add a bung to it in order to install the O2 sensor. This pushed the O2 sensore further out of the Cat. Also, my temp gauge works intermittently, but that has been going on since I bought the car. Any help will be appreciated!
Re: Nick's Black 90 - Intermittent flooding issue.
Post by ChrisAudi80 »
Sounds like you have a combination of faulty o2 reading and a temp sensor issue. If the temp sensor for the ECU does not work properly, the fuel goes very rich.
nsimps
Post by nsimps »
ChrisAudi80 wrote:Sounds like you have a combination of faulty o2 reading and a temp sensor issue. If the temp sensor for the ECU does not work properly, the fuel goes very rich.
I will start with the temp sensor. It hasn't really worked since I got the car (common problem from what I hear). It did work this morning and there were no flooding issues.
There are two. the MTFS (multi function temp sensor) is for the display, the other is signal for the ECU. If this one is broken, then it runs on cold weather setting, ie rich. This sensor is cheap to replace. Combined with an iffy O2(not cheap), it will run real bad.
Wheeljack
Post by Wheeljack »
Have you pulled codes?
nsimps
Post by nsimps »
cbrydon wrote:Have you pulled codes?
I haven't. All I have is a OBDII VAG COM which I don't think will work.
Why not? Have you tried? The VCDS system can point you in the right direction if there are sensor issues and such.
nsimps
Post by nsimps »
ChrisAudi80 wrote:There are two. the MTFS (multi function temp sensor) is for the display, the other is signal for the ECU. If this one is broken, then it runs on cold weather setting, ie rich. This sensor is cheap to replace. Combined with an iffy O2(not cheap), it will run real bad.
So these two?
https://www.autohausaz.com/search/produ ... 034919369C
https://www.autohausaz.com/search/produ ... e%20Sensor
So these two?
Yep.
The 3 pin is for the display (MTFS), the 2 pin for the ECU signal.
Wheeljack
Post by Wheeljack »
I can help you read the codes. Just shoot me a PM.
nsimps
Re: Nick's Black 90 - Tranny is mad
Post by nsimps »
Took this video of the noise the tranny is making. Any thoughts? Yesterday after getting home from work there was a hint of gear oil smell.
Link to video
nsimps
Re: Nick's Black 90 - Winter punch list
Post by nsimps »
Punch List for this winter:
- Put B4 fenders on
- Prep for paint in the summer
- Fix flooding issue
- detail
nsimps
Re: Nick's Black 90 - Time to start the paint prep!
Post by nsimps »
The 'Paint Your Own Car' class is starting summer semester which doesn't leave me much time to get this thing ready. Question for you who are in the know about prepping for paint:
What's the best way to start prepping and what materials should I be using? I assume sanding is going to be involved but just not sure what the proper procedure is.
Thanks in Advance!!
nsimps
Post by nsimps »
Ok, so I have these wheels sitting in the garage. 16's with a 45 offset. Will they fit? Just by putting them next to the car they are too tall with 205/55's but maybe with a smaller tire? I was thinking of painting the white. Comments?
fwdt
Post by fwdt »
Do 90s have 5 bolt hubs? I would do a color other than whit on a black car. They'd look good as they are in silver.
