Page 3 of 6
Re: Nick's AAN into 4000Q thread. Long-term project.
Posted: Thu Aug 18, 2011 12:03 pm
by Hybrid_Hatch
Rallyfreak202 wrote:
that line looks pinched to me
Posted: Thu Aug 18, 2011 11:41 pm
by Asmodasis
Ya, kinda does, but idk could work
Posted: Fri Aug 19, 2011 8:09 am
by vt10vt
Rallyfreak202 wrote:I leave for school August 18th and won't be back for awhile. Bummer.
It looks great Nick! If you're going to be home in december after classes end I'd love to come down for a few days or whatever and help out, since i'll be graduated and all
Also, what kind of intercooler is that? Looks like a 20v single pass maybe?
Posted: Sun Aug 21, 2011 9:53 am
by Rallyfreak202
Asmodasis wrote:Are you keeping the Lambda sensor on the catalytic converter or mounting on the down pipe?
I will be welding two bungs in the downpipe for the wideband O2 sensor and EGT sensor.
vt10vt wrote:Rallyfreak202 wrote:I leave for school August 18th and won't be back for awhile. Bummer.
That'd be awesome Shawn. The intercooler is actually John Buffum's old intercooler!
Posted: Thu Aug 25, 2011 10:29 am
by my2000apb
the egt sensor should be pre turbo
Posted: Fri Aug 26, 2011 9:28 am
by Rallyfreak202
my2000apb wrote:the egt sensor should be pre turbo
That makes sense. Glad I didn't drill 2 holes in my downpipe yet.
Posted: Fri Aug 26, 2011 9:32 am
by death 4kqt
best to put it in a running in the manifold about 1" from head port or so. Would be best to choose what you think would be the hottest runner.
Posted: Fri Aug 26, 2011 9:34 am
by my2000apb
put it in number 5!
Posted: Fri Aug 26, 2011 11:08 am
by Mentosman42
my2000apb wrote:put it in number 5!
Posted: Fri Aug 26, 2011 12:10 pm
by Asmodasis
Interesting, never really put much thought into an EGT probe. good to know it should be pre-turbo
Posted: Mon Aug 29, 2011 9:43 am
by my2000apb
Asmodasis wrote:Interesting, never really put much thought into an EGT probe. good to know it should be pre-turbo
the closer to combustion the better
Posted: Mon Oct 17, 2011 8:03 pm
by Rallyfreak202
Came home for Fall break and worked on the Audi.
-Painted the intercooler, radiator shroud, and made/painted the intercooler brackets
IMAG0155
IMAG0157Started and almost finished with snub mount mounting
IMAG0156
IMAG0152 Mounted the radiator
IMAG0158-1 Had to cut a little so the fan would clear.
IMAG0151 and grind a little
IMAG0150 Need to figure out some coolant hose to use for this windy route:
IMAG0149Intercooler location
IMAG0144Wheels
IMAG0141 The S4 was sent to the crusher. Got 350 out of it for scrap!
IMAG0133Boost controller
IMAG0153Oil cooler. NEEDS TO BE PAINTED. Might have to move it to clear intercooler piping.
IMAG0154 Still have lots of things to do before it will run. I hope to start it next time I come home which will be Thanksgiving break. Thanks for reading.
Posted: Tue Oct 18, 2011 9:35 am
by Rallyfreak202
To do:
-make throttle cable bracket
-AN line coolant turbo feed
-finish stainless steel coolant turbo drain line
-wastegate dump tube routed into the down pipe
-Intercooler piping
-battery tie down
-turbo bracing (any suggestions?)
-weld O2 sensor bung in to downpipe
-wire TPS
-find/buy flexible coolant hose.
Posted: Wed Nov 16, 2011 8:34 am
by my2000apb
does it run yet?
Posted: Mon Nov 28, 2011 4:30 pm
by Rallyfreak202
Ok, got lots done! Getting super close to running.
Left to do:
-throttle cable
-air intake
-Blow off valve
-PCV route
-coolant lines
-put fluids in
-misc stuff I can't remember and you don't care about. All you want is pictures!
Home made coolant line
IMAG0187 by
rallyfreak202, on Flickr
Intercooler piping done
IMAG0205 by
IMAG0204 by
Downpipe almost finished. Pretty dang proud of it.
IMAG0216 by
IMAG0215 by
IMAG0214 by
More work on the front snub mount stuff
IMAG0190 by
IMAG0191 by
Put some Hella Euro tail lights on my GTi. Love the way they look. JDM as FECK!!
IMAG0195 by
Uh oh
IMAG0206 by
IMAG0203 by
Posted: Tue Nov 29, 2011 9:14 am
by my2000apb
it was hard to see from the pics, but the turbos feed and drain need to be clocked to be plum vertical
Posted: Tue Nov 29, 2011 10:49 am
by Rallyfreak202
my2000apb wrote:it was hard to see from the pics, but the turbos feed and drain need to be clocked to be plum vertical
Dang, thanks for the insight Tim. I've never heard of this before. I can't clock the turbo because it mounts on the manifold at a fixed position :dur: , I guess I could alter the oil feed angle. Can anyone else offer some insight?
Posted: Tue Nov 29, 2011 11:08 am
by easterneurocoupe
If u loosen the bolts on back of hotside the chra will rotate
Posted: Thu Dec 22, 2011 7:25 pm
by Rallyfreak202
Got the turbo clocked. Much heat and a lot of banging. Re did the hard lines for turbo. Lots of work was done in the past few days but it doesn't really show in the photos. Oh well, if anyone is reading, here are some photos.
Heat shield
Gauges
Trunk/battery
Relocation
Blow off valve
IMAG0260Rear block coolant union
Water manifold to resevior tank union
Random fun shot
Front water manifold to top of radiator
IMAG0262 Broken:
Intake with provision for PCV
IMAG0259 Replacing center support bearing
Today
Re: Nick's AAN into 4000Q thread. IT RUNS!
Posted: Sun Dec 25, 2011 5:12 pm
by Rallyfreak202
IT RUNS!!!!!!!!!!!!!!!!!!!!!!
Posted: Sun Dec 25, 2011 5:25 pm
by CorradoGuy
Rallyfreak202 wrote:IT RUNS!!!!!!!!!!!!!!!!!!!!!!
Merry Christmas indeed! That's pretty cool, basically just over a year later it is finally running, I'm sure it must feel good. My Jetta has been 2 or 3 years and counting and hasn't run but it is close.
Posted: Sun Dec 25, 2011 5:31 pm
by Rallyfreak202
CorradoGuy wrote:Rallyfreak202 wrote:IT RUNS!!!!!!!!!!!!!!!!!!!!!!
Thanks man!
http://www.youtube.com/watch?v=I7EYa1fE ... e=youtu.be
Posted: Sun Dec 25, 2011 6:53 pm
by vt10vt
Congratulations man!! :woowoo: sorry I didn't have that throttle cable, if you still need one lmk and I can check Rathe's when I go tuesday (they aren't open tomorrow)
Posted: Fri Dec 30, 2011 2:33 pm
by my2000apb
wooohoooo!!!!!!!!!!
Posted: Fri Mar 09, 2012 10:45 am
by Rallyfreak202
More progress while home on mid term break. It will stay running but only with the MAP line unplugged to ECU. I have some tunning to do with that.
More low quality cell phone pics.
A couple new gaskets. Installed more but they are not in the picture
IMAG0357 Heat wrapped the intercooler pipe since it is so close to the exhaust manifold. I think I'll make a heat sheild some day. Also bought/installed a upper timing belt cover.
IMAG0364 THROTTLE CABLE SOLUTION! I tried a Volkswagen Mk2 throttle cable and it works! Notice the radiator gaurd.
IMAG0359 I tried routing the hood cable through the (home made) front cross support but it was not long enough. I think I might route it on the backside of the support. I hate seeing it out in the open.
IMAG0358 Here is how it sits now while I'm back at college...not studying....and on motorgeek.
IMAG0363And a very poor quality rev video once I upload it.
Thanks for reading.
