dets
dets
Berserker
audifreakjim wrote:Ok, so on the Wiseco pistons. A buddy who has a freind that works there hooked me up big time we'll just leave it at that. :wink: I said, 83mm bore, 8.5:1 CR and he said cool, you should have them in three weeks. I think you could probably tell them it's for a ur-s4 and they would know what to make. If not I can try and share more info once I get the pistons like job #s or something.
Here's what I found out while shopping for pistons. JE is usually the most expensive, probably just because of name. But, they have a reputation of getting stuff out a little quicker and on time. Many of the others it's best to be prepared to send in a sample and wait to have it speced out. Also, talk to your local machine shop or performance shop to see what they can get.
Wiseco has a sample of a stock 3b piston. I know, because it used to belong to me. Brian Nutter was my contact there, when I told him that he could keep the sample, he said that he'd tag/catalog it and put it on the shelf.
I'm glad it possibly helped someone.
shlab
the thing with that wiseco having a 3B piston is only good for the 2.2l(81mm bore) turbo guys. guys like me building a 2.3l(82.5mm bore) turbo will need to send him a different piston. anyone have a 2.3l piston around? if not i could possibly pick one off the junkyard. jim, have you figured out what the 7A head CC is? i know you said you'd try to because if we aren't certain what a NG/7A combo CR is than it'd be difficult to make a custom piston. correct me if i'm wrong.
>>Emy
>>Emy
olsonjus
shlab
JShadzi
shlab wrote:so would it be as easy as jim did? just calling it in and telling wiseco the bore, CR desired, and probably a sample piston?!
>>Emy
You can try, Weisco doesn't really like doing 1-off pistons to people that call in, typically you need a wholesale account or need to commit to buying a minimum quantity. A few years back I did a GB of 10 sets of pistons for this very reason.
HTH,
shlab
well i just got off the phone with them. they said the easiest way would be to just send them a sample piston and the CC of the head i'll be using. as long as i keep the rod length and crank the same, i shouldn't have any problem. they quoted me ~$93 with rings ~$110-115 a piece. did anyone find the CC of the 7A head? now the question ... will they do one run.
>>Emy
>>Emy
pro_mtn_biker
Yea, they're not the nicest welds in the world, but I'm getting pretty good with the MIG and stainless. Aluminum on the other hand..... I may tack the IC together and bribe Brendan to finish it, or I might braze it. I had to patch a hole from a bolt that dug into the core and the brazing worked awesome.
now youve got me wanting a new set of pistons and rings, except I would like an oversized mc bore with CR to run the 7A head. Sounds like a fairly strong 20v for a good chunk less money seeing as you wouldn't have to buy custom rods and still ought to good for 400 hp or so.
pro_mtn_biker
cuatrokoop
shlab wrote:well i just got off the phone with them. they said the easiest way would be to just send them a sample piston and the CC of the head i'll be using. as long as i keep the rod length and crank the same, i shouldn't have any problem. they quoted me ~$93 with rings ~$110-115 a piece. did anyone find the CC of the 7A head? now the question ... will they do one run.
>>Emy
ITS THE SAME AS THE 3B....You don't need to send them a piston, they have a 3B, they know what the CR is, etc. They made Jim's 83mm pistons from a 81mm piston (3B) and he's not using a 3B head, but a 7A. Sheesh.
Thanks guys, yea that's the plan. I'm waiting until the pistons arrive to have the block bored and everything balanced just to make sure it's all perfect. I stated they were for an 83mm bore, but you never know what you'll actually get. Hopefully the machine shop will not have a 2 week backlog when I show up with the parts. I'm still waiting to see what they come up with on the machining for the 3B coolant manifold.
olsonjus
audifreakjim wrote:Thanks guys, yea that's the plan. I'm waiting until the pistons arrive to have the block bored and everything balanced just to make sure it's all perfect. I stated they were for an 83mm bore, but you never know what you'll actually get. Hopefully the machine shop will not have a 2 week backlog when I show up with the parts. I'm still waiting to see what they come up with on the machining for the 3B coolant manifold.
I'm trying to track down a good machine shop in SLC. I may just schedule a trip to San Fran and have Javad and gang machine my ported head for the 3B manifold. Then I will decide between the 82.5mm 7A block or going to 83. Can't decide. Can't wait to see the car next year here at Miller Motorsport. Keep at it Jim!
cuatrokoop
