Swapped pins around last night. I'll get the details mapped out here and post them on a google doc.
I can't seem to get a trigger signal of any kind. On the G4(Crank Sensor) and G28(Speed(RPM) Sensor) I have the middle pins connected to the ecu pins 36-27 (G4) and 18-12 (G28) respectively. The other two pins I have connected to ground. The Red and Blue wires (that connect to pin 48 on the 3b harness) are plugged into 36-26.
EDIT: I'll be ground-testing pin 36-27 today (hopefully) at lunch to see if that will at least get me some trigger logs and go from there.
Below is a screenshot as well if that helps any.
On the engine block - I have one ground from the trans bolt to the firewall and added another using a snub mount bolt to the block and an engine bay bolt on the chassis side.
The weird thing here is that I'm not getting any signal, even if I plug in a loose G4 and touch it to metal while doing a trigger log I get nothing.
I really don't want to trailer this thing down to BBQ but will if I have to
I have Mon-Thur of next week to figure this out. Marc has been a huge help, not to mention super patient with my noobness but the hard part is we are 2 time zones apart and I can't escape from work long enough to test and re-test during the day. If anyone is willing to maybe help with things (over the phone is great) in the evenings next week that would be super awesome!My awesome Econoseal Pin job:
G4 pin situation:
