So as you could guess I have not done much here in the past year. Before I bought 1POd90 I was prepping to replace/upgrade the CQ clutch which had been slipping at full boost for a while (I turned down the boost for longevity); this was put on hold when I bought the 90. Unfortunately, I made the unwise choice to borrow a few parts off the CQ since it was parked awaiting a clutch. This drew out the timeline for the clutch as I had parked it in my driveway so that the garage was open (another bad choice). Anyway, I replaced everything which was borrowed and found that my TPS was unresponsive and the replacement dizzy needed a hall, I figured that the TPS was not a deal breaker and I'd give jumping the cam sensor a shot (this gives you a 1/5 chance of correct timing but
SHULD work. It actually did work and I was able to drive down the block and park in the garage! I felt so good about this that before I actually worked on the CQ I pulled it back out so that I could service the 90 (are we still counting bad ideas?). This brings us to my current predicament, for some reason the CQ does not want to move itself back in the garage. So I ordered a replacement hall sensor and followed the write-up on 12v.org to replace it. The process was not too bad, even though I have a different looking dizzy than in the write-up. So I got it back together, verified #1 TDC, and primed the oil before plugging the hall in to test and start. No signal, dammit! I think I may have to swap the terminals, I followed the directions but that must be it (hopefully). Not wanting to pull it apart again, I figured I'd try the emergency bypass again. I spent the rest of the afternoon/evening trying to figure out why my old tune is not working.
Now for the questions...1. I got it to run, sporadically, by zeroing out every enrichment (warmup, afterstart, etc) and adjusting VE until it fired and ran. At best it will run for a few mins before dying but as soon as I look at adding air (idle screw or throttle) it dies immediately. If left on it's own, it will not run indefinitely (I was hoping to get some heat). I tried increasing and decreasing VE by +-10% and it did not seem to make much of a difference (BTW my WBO2 seems to not self heat and has been this way for a while). I feel like I've heard a different cranking results between rich and lean, am I dreaming? When it does not simply fun for a min or so, it seems to kick over but quickly dies (>cranking RPM 299 maybe).
2. What's up with it idling for over a min than dying? I don't see anything changing in the
LOGS. I'm on a hill (BTW, why I don't simply push the effer in) but ~1/2 tank of mostly newish gas (just dumped in a couple gals of regular for good measure). It's at least getting some fuel as it starts and runs.
The real bitch is that I fully intend on pulling it apart and improving some things so it literally only needs to more ~25' (back down the driveway and drive back up). I may find a trailer to make it happen tomorrow (the city finally caught on, or I was reported by the HOA, that I've been "storing" this car in my driveway without a current title (my thought was clutch>emissions>title).
TlDr, CQ won't start regardless of being in 90% of the state I commuted with a year ago. If I had a shop this would not be an issue
