Page 23 of 119
Posted: Fri Apr 03, 2009 7:12 pm
by oldsklaudidub
did somebody say Tig Weld?
Posted: Fri Apr 03, 2009 7:28 pm
by speeding-g60
also today, the Tial wastegates i got from Issam got here, and i forgot to mention the VC i got from him as well... such a kind hearted soul that man is
Posted: Fri Apr 03, 2009 10:11 pm
by s2 on the way
mmmmm,
thems are some perty aluminium pieces you got there
comin right along
and once again, I can't wait to see this thing in action (i'm sure much less than you though
Posted: Fri Apr 03, 2009 10:38 pm
by pilihp2
ShavedQuattro wrote:
Aaron, feel free to delete if I am getting your thread off topic!!
why has nobody commented on the fact of how FARRRRRRRRR Back that motor is? is that thing RWD? i saw a picture of that in another thread..
INFO PLEASE!!!
Posted: Sat Apr 04, 2009 4:33 am
by WAUG0806
Absolutely sick breather system!
That ought to take care of your blow-by for at least 9 seconds!
Piliph2 - I can't imagine front half shafts on the red 20VT car... unless it's got some non-quattro awd drive train in it.
Posted: Sat Apr 04, 2009 7:12 am
by RSCoupe
That is the UrQ with the custom transfer case and front diff. It's been in various threads many times...
Posted: Sat Apr 04, 2009 8:10 am
Wow thats some nice lookin stuff you got there...this is why I am trying to get good at tig. Just need more practice.
Posted: Sat Apr 04, 2009 8:14 am
by Frank the quattro tank
I believe that the URQ has a sierra or escort 4x4 gearbox.
Posted: Sat Apr 04, 2009 9:10 am
by zerb
nice stuff aaron. 8)
Posted: Sat Apr 04, 2009 9:43 am
by Justin517
INFO PLEASE!!!
Its the KRB trading car
http://www.krbtrading.no/audi_s1_pikes_pike_prosjekt
OK thats not the build of the red car, I cnat find it...but it is KRB's car IIRC
Posted: Sun Apr 05, 2009 12:15 pm
by tsin
speeding-g60 wrote:
hi, i want to make same frame for my engine compartment as you. but i dont know what type of pipe should i use :( thanks for help..
thats my little baby
Posted: Sun Apr 05, 2009 3:59 pm
by speeding-g60
i used what would pass NHRA requirements (i hope haha)
1.25 OD tube, .118 wall thickness.
further back, there is some almost step by steps of what i did and why.
main reason was to fit the big turbo in there....
Posted: Sun Apr 05, 2009 9:48 pm
by tsin
what is OD please?
Posted: Sun Apr 05, 2009 9:59 pm
by auditude
tsin wrote:what is OD please?
Outside Diameter, as opposed to Inside Diameter.
Posted: Tue Apr 07, 2009 1:04 am
by tsin
thx
Posted: Fri Apr 17, 2009 4:27 pm
by speeding-g60
i am still around, working on the rabbit lately getting ready for april 25th. premiere i guess.
a trans without any syncros is definitely interesting to shift. even have half the teeh for the syncros ground off the gears. we'll see.
but i have good faith now for this car, as i have been a little hard on the Lago in the shift department lately. been driving it around a little on the weekends, and runnin the piss out of it, shifting and such. that thing shifts all the time, right on time, no matter what. it will be a treat to race a car that will shift. done a number of second gear chirpy's, too.
been doing some work on the AWIC reservoir, and really not much else.
but the exhaust manifold.... it is going to be pretty good i understand. it is a true divided inlet (twin-scroll) manifold. 1/4 into one side, 2/3 into the other. separate all the way to the turbo. 2 into 1, 2 into 1, and both ones into the turbo.
it is mounted, and the exhaust will snake inside the fender, past the coilover, and out thru the fender side by the door jamb. the twin Tial V-band wastegates (thanks Issam) dump to atmosphere downward. all mandrel bends SS tubing.
i got no pix, cuz i dont want to drive 160 miles to take them, i will do it when i pick up the car.
also got the boost piping. 3.5" OD polished (it comes that way) aluminum tube with mandrel bends. nice and simple, one pipe. V-band at the turbo, 3.5" x 3" at the AWIC. and my welder guy gets it cheap for me thru work. they have three shops, and they bought a CNC mandrel bending machine, but they put it at their shop in Montana, because of him. thats what the owner told him, as he knew he would be bending stuff left and right for his home adventures LOL. oh yeah, cost for 3' polished schd 10 3.5" OD aluminum tube and the short radius mandrel bent 90? $25 bucks. cheap as all can be. i think i am going to design a couple radiator tanks for the cars... he can brake the material and make them for me in nothing flat.
also ordered the AWIC pump. in tank setup, 500 gph. got the -4AN lines and fittings for plumbing the oil feed to the turbo, and the -10AN lines and fittings for the drain. once the motor is here i will have the return bungs welded onto the oil pan, and weld over the factory.
just a little update, i am still here, and still doing stuff....
Posted: Sat Apr 18, 2009 11:50 am
by fasterthenrs2
I thought you past away or something, I needed to search to find your tread
Posted: Sat Apr 18, 2009 11:52 am
by derracuda
he's been sick. i saw him the other day and he was gackin' n' hackin'. he'll be back at it soon.
Posted: Sat Apr 18, 2009 11:55 am
by speeding-g60
oh i work on stuff even though i am sick.
that doesnt stop me
just waiting on so many things. :?
Posted: Sun Apr 19, 2009 5:16 pm
by speeding-g60
played designer for my coolant system. plain, easy, and larger capacity. it helps that i have a great resource for custom welded aluminum goods at an extremely reasonable cost. kinda makes me have things that are not "needed" made out of aluminum just cuz. BLING!!!!
polished aluminum is neat. still gotta figure a radiator though. but i got the parts ordered to do the first one (rabbit) and the AWIC reservoir plumbing as well.
here is my idea, plain and simple. i am going to change the rabbit to this system first. and then the coupe will follow with a different shaped res and catch can. same principal.
the idea is more capacity for coolant, larger reservoir, and all coolant goes into big reservoir then feeds radiator. that way nothing is starved, and boilover should be non-existent.
but this will get me legal to NHRA spec concerning the catch can, and also add cooling capacity to the system. the bright blue line is in case i feel i need more flow.... it is normally the OEM T-stat bypass when coolant is cold. when it gets hot, the T-stat opens up and then coolant is drawn from the radiator also. i have deleted all the useless stuff like oil heat exchanger, heater core, etc. does not apply to a race car. and there is no turbo coolant lines for the CQ, but there is on the rabbit.
Posted: Sun Apr 19, 2009 6:20 pm
by derrish_vulf
good damnit i want to learn how to tig so bad.....
this is looking awesome, i CANNOT wait to see this thing at the track..
Posted: Thu Apr 23, 2009 2:06 pm
by speeding-g60
so i went and looked at the head today. man is it looking pretty.
been thru the specs but quickly:
AEB head, not ported in any way.
Supertech +1mm intake, standard exhaust. Inconel and Nitirided SS.
CAT Billet solid lifter cams and solid lifter buckets
Supertech springs and retainers.
new guides and seals.
single groove keepers on valves.
they are working out the lash caps now....
but check the difference with the side shotz of cams. stock is on the left. some little bit more lift and duration i would say. wonder if its gonna lope like a Chevy?? LOL
Posted: Thu Apr 23, 2009 3:11 pm
by WAUG0806
stock cam lobes look really pointy...
Dayum, looks veddy nice.
Not sure if you already mentioned it...but how high do you plan to rev to?
Posted: Thu Apr 23, 2009 3:15 pm
by speeding-g60
10k rpms or so-ish..... and yeah, they do look rather pointy, huh. not much duration....
and some other random partz.... 3 pr speed bleeders.... and lots of hose and fittings for my radiator reservoir. i have to make one for each car, this is for the rabbit. test it out there, finalize it for here.
