Page 24 of 34
Posted: Wed Apr 02, 2008 6:09 am
by Marc
Nice work on the hub adapter Derek!
Posted: Wed Apr 02, 2008 7:29 am
by s2 on the way
awesome.....soon we get to see it rollin on its steam rolling 5x130's ;D
Posted: Wed Apr 02, 2008 7:33 am
by Highlander
a4kquattro wrote:Nice work on the hub adapter Derek!
:stupid:
Posted: Wed Apr 02, 2008 9:06 am
by Lt. Sarge
You jerk! Now I pretty much have to swap to 5 lug, which means new, bigger brakes and some twists. Do you have any idea what that will cost? At this rate I'm never gonna have a duplex ;)
Posted: Fri Apr 04, 2008 7:12 am
by Rob C
I love the idea. Nice work Derek!
Posted: Fri Apr 04, 2008 12:48 pm
by derracuda
the rears are pressed in, i just gotta wait for wheel bearings for the fronts then those can go together 8)
(yes, that's a front rotor and it's just sitting on there for fits and giggles)
man that's a big rotor!
Posted: Fri Apr 04, 2008 1:20 pm
by a_CQ
Good stuff Derek!
Posted: Fri Apr 04, 2008 3:08 pm
by HT Motorsport
NICE!
Thats pretty clever as usual Derek :)
H
Posted: Fri Apr 04, 2008 3:16 pm
by 90_Koop
Damn you Derek! very creative! :-D
Posted: Fri Apr 04, 2008 9:18 pm
Great work D, I've been thinking about doing this same thing for a while now! Thanks for testing it out. :-D
Posted: Sun Apr 06, 2008 12:48 pm
by derracuda
ahhhhhh, they work!
well, mostly..
the top of the tire is ohhh, about 1.75" not far enough in :P so i gotta work on my strut mods some more.
this is part of my solution...
Posted: Sun Apr 06, 2008 12:53 pm
by glibobbo21
coming along.....
Posted: Sun Apr 06, 2008 12:54 pm
by thegetawaycar
youre like audi macguyver...
"all i need is a welder and some steel and ill build you a bitchen 4kq!"
Posted: Sun Apr 06, 2008 1:45 pm
by nismo
I'm not sure I understand the 3rd pic. What's up with that?
Eric
Posted: Sun Apr 06, 2008 4:19 pm
by derracuda
the third pic is essentially a plumb line showing how far out the top of the tire was tilted out because the inside of the top of the tire, was touching the strut. i made a new plate to get my dimensions more in line for where i need to shoot...
now i got a half inch of clearance between the tire and the strut tube, which i think i might be able to cut down on, but gotta wait for another couple tires to show up just yet, i can't let haydn get the jump on me too bad for max tire width ;)
now we're cookin with gas..
before i go too much further on this suspension part, i need to figure out what i'm gonna do with the upper strut mount points. they need to go in and back 1" each way, and that will change the gap on the bottom end yet again, and i only wanna make struts once :P
Posted: Sun Apr 06, 2008 8:17 pm
by nismo
So the parts you're using are a mix & match, and the plate is to move the strut in/wheel out so you get no rubbing?
Eric
Posted: Sun Apr 06, 2008 8:20 pm
by derracuda
the plate only moves the strut in. the hub has to stay where it's at or else it tilts outward because it's still attached at the lower ball joint ;)
Posted: Sun Apr 06, 2008 8:34 pm
by oldsklaudidub
I am going to be interested to know what the camber, caster, and toe is going to be when this is all said and done.
Looking good Derek
Posted: Mon Apr 07, 2008 1:51 pm
by nismo
Me too!
Eric
Posted: Mon Apr 07, 2008 2:23 pm
by Lt. Sarge
Lookin awesome Derek! Makes me more confident about 9" wheels on my CQ(with steering arm mods maybe?)
Posted: Wed Apr 09, 2008 7:54 pm
by derracuda
round two... my plans are slowly working out. i have a v8q diff here that i wanted to install, so that means i need a shorter driveshaft.. what to do.. custom driveshaft? possibly, but for some reason i kept a driveshaft from a V8q parts car a couple years ago, and it's almost the right length... all i gotta do is move the rear diff forward 1.75", and the engine/trans back 1" and bingo, OEM part for something critical like the driveshaft.
another part of my plan was to move the control arm mount points upward as far as i'm lowering the car(which the target is 3") to give it back it's higher roll center. the stock subframes are kind of a mess to do that to, so i'm starting from scratch, and it also allows me to put the engine,trans, and rear diff where i need them to be. this is today's progress...
there's a 1.25" height difference betwen the front and rear mounts..
my welds are getting better 8)
i'm giving myself room to play with moving the rear diff a little and using the shorter of the two rear axles on both sides... to move the struts inward a little for more tire clearance...
the X is the subframe rail, and the furthest out row of holes are the stock distance from the subframe, the second set is moved in 1". they go up in .75" increments.
this morning front wheel bearings arrived :D so the front hubs went together...
you can see that the new bolt circle is far enough out to allow me to replace the studs without having to press the hub apart.
there's also one more issue with the high offset wide rims. the rear struts have the toe ajustment arms, annnnnd they hit...
so i found out that the rear bearings are 75mm, and early 80/90 fwd cars use a 75mm front wheel bearing, and i happened to have some of the bearing carriers around. so i pressed the whole hub/bearing out of the rear spindle and into the front spindles, and now i'll have to make some sort of steering arm off the strut assembly.
Posted: Wed Apr 09, 2008 8:02 pm
by blklbl540
derracuda wrote:Image
Tire shreddin' stylez!
I like it 8)
Posted: Wed Apr 09, 2008 8:41 pm
by thegetawaycar
everytime i check out this thread i am utterly baffled how you manage to engineer this stuff. forget macguyver, you sir are a quattro magician.
im standing and applauding you from ohio.
Posted: Wed Apr 09, 2008 10:25 pm
by Audi199090
Derek.... Your my hereo! :jawdrop:
Posted: Wed Apr 09, 2008 11:20 pm
by s2 on the way
:stupid: sweet.....
just curious, what steering angle you gonna be able to pull off with the wheel in so close to the wheel well?
