but it is still weak in the idle department :( i have checked to see that the idle motor is working, and it is.ok, finally got to finish up the taillights...
i had to modify the brackets that the center lights bolt to so that they would sit almost even with the outer taillights. for some reason the center section on these all reds like to sit higher on the 4kq's.
i also made a little plate for the top section where i had to cut and narrow the light
and in this here JB weld is a piece of SS tig welding rod
ruh roh!!
once i got the wires fixed... no more blowing the right taillight fuse..ahh, much better
i also got the engine up to temp and had the fan cycle on.... i have the fan setup to run two speeds right now.. low and medium. i never got past low and it cools down RIGHT NOW haha. i think i'm gonna dig this set up for sure!!
that's it for tonight! maybe some more tomorrow night depending on work around here.
