Page 29 of 32
Re: 20vt B3 (The Bandit)
Posted: Mon Feb 19, 2018 6:58 am
by DE80q
AngryTaco wrote:Congrats on the house but the real question is....
Dafuq are the anti-lag videos?
Thanks Jared!
I still havent hooked up launch control. I'll get there...
Posted: Tue Feb 20, 2018 11:36 pm
by my2000apb
vt10vt wrote:
DE80q wrote:Oh, I'm also in contract to buy a house, with closing set for the 16th! It will be strange to have a garage of my own to work in!
WHAT?! CONGRATS DAVE! That is awesome. Having your own garage is the single best tool you can have for a project car. Careful not to let the driveway get too full though ;)
agreed, :beer: :beer: :beer: :beer: :beer: to garage mods!!!
Posted: Tue Feb 20, 2018 11:37 pm
by my2000apb
dafuq youre 20vt?
Posted: Tue Feb 20, 2018 11:42 pm
by DE80q
dafuq youre 20vt?
:rofl: Jared isn't allowed to say 20v... I always know when he posts! :rofl:
Posted: Sun Mar 11, 2018 7:17 pm
by DE80q
Well today I had a car show up in my new garage... An 87 80q... What should I do with it?
Posted: Sun Mar 11, 2018 8:58 pm
Nice!! Body and paint look to be in good shape.
Which engine?
Since I already have a hot rod in the Cq, I intend to make my 80q into a winter beater/commuter car that will challenge and surprise some modern sports cars. For less than $5k, total. With the amount of spare parts I've accumulated over the years (AANs, 01Es, etc) it shouldn't be too difficult to pull off! Finding the time will be the biggest challenge, lol.
Posted: Sun Mar 11, 2018 10:09 pm
by DE80q
PRY4SNO wrote:Nice!! Body and paint look to be in good shape.
Which engine?
The low light pic does it a lot of justice. It's pretty straight, but has definitely had a respray at some point. The interior was swapped from a 90, so it has grey leather now. The engine is the standard NG from the year, so it has the less desirable cam, and slightly less power. It also is quite low on compression, or so I am told. It might be an easy fix, or it might be a swap candidate. I have access to a complete 7A engine, harness and ECU, so who knows...
The funny part is, I bought it off a friend, so it has a bunch of my old parts on it... Exhaust, shifter, clear corners, and some others... I got it plenty cheap, so keep or part out is what I need to decide. Oh, it has new tires and H&R springs too haha.
Posted: Mon Mar 12, 2018 9:37 pm
Keep it for now, rob some parts for the Bandit as you want/need and deal with it later when the right proposition materializes.
Posted: Tue Mar 13, 2018 1:44 pm
by DE80q
I'm seriously considering making a rally inspired lifted sedan. Would be a huge switch from the bandit which pretty much sits on the ground.
Posted: Mon Mar 26, 2018 11:04 pm
by DE80q
The desicion has been made to part out the "new" 80q. I was told it has H&R springs and 2 piece suspension. I also know it has clear corners and my old(came from George's 80q) stebro rear mufer. I'll post up a part out thread soon. Just way to many things have been hacked for me to attempt to save it.
Posted: Sat Apr 07, 2018 6:20 pm
by DE80q
The bandit has found it's new home!
Only issue I had getting it there was when I stopped for gas. When I started it back up, the ISV decided it didn't want to work correcty... This has been a common issue for me though. Still need to figure it out.
Posted: Thu May 17, 2018 9:11 am
by DE80q
With carlsile fast approaching I figured it was time to get the bandit ready. First I swapped the snows out for the summer wheels, then put it up to check out under the car. Only had one pair of stands here at the new house, so dad old school wheel stands got put to work!
Turns out my steering rack, the shift selector shaft seal, and the rear diff is leaking... I'll have to deal with these at a later date...
Looking at the parts car, it has a DS knee cubby, so I decided to put it in, I was pretty surprised about having to remove the brackets for the later style to be able to fit it in... Kind of a PITA with the dash installed, but I got them out.
The cubby already had a switch drilled into it from the he previous ower's mood lighting, so I decided it would be a good switch for the launch control activation! When I pulled back the insulation, the wires that had been soldered to the switch had broken off, so I took it to work and soldered on some 20g wire.
After fighting with the wiring I had tucked away, I was able to get the cubby bolted in. I'll have to pull it out later and reorganize the wiring, but this will work for now.
I'm going to attempt to try the launch control today... Hopefully I don't have any cops knocking on my door later :police:
Posted: Thu May 17, 2018 7:42 pm
by DE80q
Well, I got it to work... It's actually making too much boost though. I think I'm going to have to put the factory spring back in and retune the boost control to bring the launch boost down. Having a 1.8bar spring limits that...
Quick vid of the first real attempt...
Posted: Tue Jul 17, 2018 4:34 am
by DE80q
As of lately I have been fighting to figure out a strange clicking in the front suspension. First I thought it was the el'cheapo strut mounts I threw in, but putting in the new mounts only made my steering wheel off center. Pretty much went over everything I could think of to no avail...
Yesterday I figured it out and fixed it. Turns out the damn nut had backed off on the strut housing allowing the strut to move! I used a massive pair of channel locks, and turned it nearly 2 full turns! Now I can drive this thing without worrying about the RF wheel falling off! Yay!
Posted: Thu Jul 19, 2018 10:46 pm
Man, sometimes it's the crazy little things. Nice that you found it, and thanks for posting. Now I have that as something to look out for on the back burner.
Posted: Fri Jul 20, 2018 1:38 am
by DE80q
I really thought I had a ball joint about to come apart or something of that nature. It was just hard to pin point what was actually making the noise, because it only happened when I would hit a harsh bump like a pot hole.
Posted: Mon Jul 30, 2018 3:01 pm
by DE80q
Went with a friend of mine to a car show on Saturday evening. Had a lot of really nice cars and bikes there. On the other hand, it really wasn't my scene. Most cars were modded out to look pretty, make lots of noise, or light up brighter than the sun...
One thing I didn't know, was they were taking pics of every car as they entered... So attached is the one they too of mine. Could be worse all things considered.
Posted: Sat Aug 11, 2018 1:38 am
by DE80q
I did it again... I have another turbo on the way. This time I will be putting it in! Anyways, it was listed as a Porsche upgrade, but the seller wasn't interested in giving any details. The only thing in the description was "excellent condition". It has obviously been heats cycled many times, as the turbine houseing appears "peeled". That's ok though, I'll get it cleaned up and checked out. I can't find much in the brand though, ITS comes up as a turbo rebuilder in the UK. Anyone have any idea? I'm thinking To4 based.
Posted: Sat Aug 11, 2018 3:13 pm
by Aktapod
Car looks great man! Looks like it'll be a riot running the Mystery Turbo haha
Posted: Sat Aug 11, 2018 4:05 pm
by DE80q
Aktapod wrote:Car looks great man! Looks like it'll be a riot running the Mystery Turbo haha
Thanks, the filter they used was very flattering haha.
Here is another one someone else took...
As for the mystery turbo, I'll have to spec it out, and figure out what turbo it is when it gets here on Monday. I figure I'm ringing out this K24 to 20psi+, so need something different to go more. :drive:
Posted: Mon Aug 20, 2018 4:53 pm
by DE80q
I decided to take some comparison pics of a K26 Vs the new turbo. The exhaust housing is an Audi K26 #6 housing, and I think the compressor housing is from a Porsche K26/6.
Posted: Mon Aug 27, 2018 12:19 pm
by DE80q
Well, I can finally let this one out the bag. About a month ago, I had a lengthy discussion with Tim about making a higher flowing, factory placement manifold. Over the past couple weeks, I've been getting some pretty neat pictures of his progress. It almost done now, just one last tube to make for the wastegate. Figure at this point, I can start sharing some of these pics. Tell me what you guys think.
Posted: Mon Aug 27, 2018 12:31 pm
by dougkehl
I think that looks fantastic. A real nice and tidy package. Also curious as to where you got the wastegate flange or if it was made. I can't find one state side for the manifold I'm building.
Posted: Mon Aug 27, 2018 12:44 pm
by DE80q
Tim made some 304ss ones for the manifolds he was making.
Posted: Mon Aug 27, 2018 10:06 pm
by Afterthought
Dang that’s going to be awesome . Not many tube header 20v’s around
