Page 4 of 6
Re: Justin (bangetek) 1996 UrS6
Posted: Thu Oct 16, 2014 12:54 pm
by Hank
How does the breather system look? What does the inlet from the catch can look like for oil?
No doubt, you are maxing that GTX3071r in a big way, but still it is hard to swallow that it is losing the front seal
Posted: Thu Oct 16, 2014 7:27 pm
by JustinB_20vt
breather system is designed like the stock pcv with a catch can before the turbo intake.
I will check the intercooler in a few days to find out how much oil is actually down there. It may be that when the hose blew off it back fed any oil out of the intercooler. I have blown 4 hoses in 4 days now mark said 310kpa would do that
Posted: Thu Oct 16, 2014 8:38 pm
by Dutchbroracer
How much power did you end up making?
Posted: Thu Oct 16, 2014 9:01 pm
by JustinB_20vt
Dutchbroracer wrote:How much power did you end up making?
Somewhere around 480ish whp .... torque was only measured at the front wheels
Posted: Fri Oct 17, 2014 1:15 am
by Dutchbroracer
Woah, must be a riot to drive. Looks great too man.
Posted: Tue Nov 10, 2015 12:20 pm
by JustinB_20vt
So i am trying to figure out why my car needs so much fuel in one band around 2600 rpm's. Anyone ever run into this before and should i look somewhere else in VEMS.
Logfile attached
Posted: Wed Nov 11, 2015 12:33 pm
by JustinB_20vt
Posted: Sat Nov 14, 2015 11:21 pm
by SEStone
My car has the same lean spike/rich map area around there, plus or minus a few hundred RPM. It may be some kind of harmonic intake or exhaust resonance? A fuel pressure gauge would show if it's a fuel system issue.
Sam
Posted: Sun Nov 15, 2015 11:05 am
by JustinB_20vt
SEStone wrote:My car has the same lean spike/rich map area around there, plus or minus a few hundred RPM. It may be some kind of harmonic intake or exhaust resonance? A fuel pressure gauge would show if it's a fuel system issue.
Sam
I hooked an oscilloscope up to my fuel pressure sensor yesterday to confirm that what VEMS is seeing is correct... around 2100 RPM the turbulence in the fuel system reaches a peak and the fuel pressure changes wildly... sort of a water hammer for fuel going on in there. Time to fab up something different
Posted: Sun Nov 15, 2015 9:36 pm
by SEStone
Weird. Does the RPM it occurs at vary with load?
Posted: Sun Nov 15, 2015 11:37 pm
by JustinB_20vt
hard to say but its more noticeable in taller gears... fuel pressure is CH5 in my vemslog
Posted: Mon Nov 16, 2015 11:22 am
by popdemonic
Justin,where did you get those ebrake calipers from?I'm going to fabricate the bracket for those ebrake with cayenne calipers.i love the exhaust sound though.
Posted: Mon Nov 16, 2015 8:16 pm
by varia
Ferrari
Posted: Mon Nov 16, 2015 11:33 pm
by JustinB_20vt
varia wrote:Ferrari
yup pulled from a f430 but the same calipers that are on the v10 r8's. The bracket is a one off that i made with a local shop... IPSCO was supposidly designing some but i havn't heard any more on that... i plan to pull mine and have them redone one day hopefully that will produce a cad or solidworks file
Posted: Tue Nov 17, 2015 10:01 am
by popdemonic
Thanks Justin.where can i get a pair of used one in States?i remember the Viper and some Jag is using the same calipers.I can get started to use Autocad designed the bracket as soon as i acquired the calipers.
Posted: Tue Nov 17, 2015 11:38 am
by ringbearer
I noticed the tesla model s has a separate ebrake caliper for the record
Posted: Tue Nov 17, 2015 8:48 pm
by JustinB_20vt
ringbearer wrote:I noticed the tesla model s has a separate ebrake caliper for the record
thoes are electric i believe
Pop the calipers are Brembo 228021 & 228022
Posted: Tue Nov 17, 2015 11:51 pm
by ringbearer
Electric, makes perfect sense
Posted: Wed Nov 18, 2015 10:02 am
by popdemonic
Justin,
what about the ebrake cable?do you have any issues on using stock one?
i got an offer BNIB Jaguar Brembo ebrake calipers.ebrake cable holder is slightly
Different from F430 ebrake calipers not sure if it's worth to pay extra $ for
F430's.Thanks Pop
Posted: Wed Nov 18, 2015 10:06 am
by popdemonic
Jaguar ebrake calipers.
Posted: Wed Nov 18, 2015 4:37 pm
by CassaUrS6
I have a BNIB 034 fuel line kit if you're interested in changing the fuel line setup.
Posted: Mon Nov 23, 2015 11:02 am
by JustinB_20vt
Update on my oil cooler. Finished the metal portion of my cowls the plan is to attach rubber to the bottom of each to seal against the belly pan. I added a 6.5" fan to the oil cooler and it seems to really suck
Little bit more trimming to do but hopefully it makes a big difference on the track and during the summer.
Did the same thing on the passenger side to hopefully keep fresh air directed at the intake
Posted: Fri Jan 29, 2016 9:13 pm
by JustinB_20vt
Lots of grinding and melting but I am close to calling it do-able
And now that i have a place to mount a euro plate on the front why not mount this on
Re: Justin (bangetek) 1996 UrS6 - Now with eurogoodies
Posted: Tue Feb 02, 2016 6:44 pm
by A20V200
Good job Justin...A big FMIC behind a Euro bumper...what are you going to reinforce it with?
Posted: Wed Feb 17, 2016 10:30 pm
by JustinB_20vt
A20V200 wrote:Good job Justin...A big FMIC behind a Euro bumper...what are you going to reinforce it with?
Actually enough of the core and support is still there and the FMIC does a good job of holding things in place ... i will reinforce if i start seeing any movement
