Page 4 of 5
Re: Basic 07K Facts?
Posted: Thu Jan 15, 2015 9:27 pm
Hey Hank, just curious what the solution is for the flywheel - are you making your own or is 034 doing something about the ring gear? Or something else entirely?
Posted: Tue May 26, 2015 4:25 am
by mbelt
Hi,
I am pretty new to 07k engines, i just bought BGQ engine that i want to use in URQ with 01E. My question is how far can You go with power using cast crank ( 101F) i am thinking about full spec hillclimb engine ( 600 HP+).
Regards,
Marcin
Posted: Tue May 26, 2015 11:30 am
Given the amount of work and money you have to sink into a swap, making sure you get a forged crank in there is pretty trivial. I would not trust a cast crank at 600+ HP.
Posted: Tue May 26, 2015 12:30 pm
by Marc
2nd. you have two good options for a forged crank. one is to source an early 07k, your likelyhood is high in 06 to get a forged one. or buy a ttrs crank, last I checked they were sub $1500 retail from audi. advantage of the ttrs crank being you get an 8 bolt flywheel flange while you are at it.
Posted: Tue May 26, 2015 12:49 pm
by mushasho
How many failed cast cranks has anyone here witnessed?... I only know of 1 which was used in an AWD drag strip setup, which I would say is more abusive with all the launching needed to get a good time... In a Hillclimb setting I'd bet it would last longer, and perhaps even more durable in 2WD setup... I only say this because of my past experience of seeing soo many boosted ABA's without any failures, granted all have been 2WD but they did see rigorous strip and street abuse using the stock cast crank... I have a nearby fully built 6262 07k mk5 Rabbit thats had NO issues whatsoever in 2WD form...
Posted: Tue May 26, 2015 5:28 pm
by mbelt
Thank You all,
I need more info what is differnce between early and late crankshaft. 8 bolt is for sure better but 6 bolt crank is no big issue for me. Could someone post some photos ? Also what engine codes have forged crank ? my 2007 BGQ has no wide nor narrow seam :)
Will post photos shortly.
Posted: Wed May 27, 2015 10:32 am
by mbelt
I was at machine shop ( crak guy)and that told that crank is for 95% forged. They will do material drilling to make sure. Will be in touch with You.
Posted: Tue Jul 21, 2015 12:46 pm
by elaw
Hank wrote:I have a 240mm 14 lb flywheel made that accepts 7a clutch kits and 1.8t pilot bearings at 340$, so it is not unreasonable.
On your website, it looks like the flywheel has no pilot bearing. I assume since the "snout" on the crank is so long, in this setup the pilot bearing lives in the crankshaft?
Posted: Sun Sep 27, 2015 4:51 pm
by mbelt
Hello again,
after buying few motors i see that only E crank is forged, my first one BQG is not :(
Soon will post some photos form assembly. Starting with head with oversized ferrea valves, IE camshafts and Polish machining.
Posted: Sun Sep 27, 2015 5:36 pm
Can you post a link to the cams?
Posted: Sat Dec 19, 2015 5:54 am
by gabriel.b
Does anyone know the length of an o7k compared to a VR6?
I have seen a VR6 in a coupe quattro and A V8 front mount radiator and the intercooler fit nicely,
wondering if I might be able to do the same with an o7k
Posted: Sat Dec 19, 2015 3:16 pm
by scubagli
mushasho wrote:How many failed cast cranks has anyone here witnessed?... I only know of 1 which was used in an AWD drag strip setup, which I would say is more abusive with all the launching needed to get a good time... In a Hillclimb setting I'd bet it would last longer, and perhaps even more durable in 2WD setup... I only say this because of my past experience of seeing soo many boosted ABA's without any failures, granted all have been 2WD but they did see rigorous strip and street abuse using the stock cast crank... I have a nearby fully built 6262 07k mk5 Rabbit thats had NO issues whatsoever in 2WD form...
Obd 1 aba's were forged, and that is what most people are boosting (fyi).
Posted: Wed Dec 23, 2015 9:07 pm
by mushasho
That makes sense...
Posted: Wed Jan 13, 2016 12:31 pm
I've been searching for flow bench numbers on a stock and ported 07k. Does anyone have some?
Posted: Wed Jan 13, 2016 1:21 pm
They're on integrated engineering's website I believe
Posted: Wed Jan 13, 2016 1:47 pm
by Mcstiff
Posted: Wed Jan 13, 2016 1:55 pm
Yep was just going to post that.
Here's a pretty picture... Needs a white background lol
Posted: Wed Jan 13, 2016 2:05 pm
by Mcstiff
chaloux wrote:Yep was just going to post that.
Seems like Jeff found similar numbers on the Revver head, "peak flow at 0.5" lift is 274 CFM. Exhaust peak is 203 CFM with great laminar flow in the mid lift range". What's the FRP/IMS CNC ur20v head flow?
Posted: Wed Jan 13, 2016 2:11 pm
It's not the static flow of the head that makes the 07k better, it's the cam profile you can run with roller rockers. You can keep the valve open longer so it flows more in the end.
Posted: Wed Jan 13, 2016 2:51 pm
Good point Jim, but the static flow numbers are still interesting to look at. What would be very cool to have is average flow or total flow numbers for a single intake stroke (and exhaust stroke)
Posted: Wed Jan 13, 2016 3:31 pm
Yep, I mean in the end the size of the valves will be similar. The port on the 07k is steeper so it's probably easier to get flow out of, but that doesn't mean you can't get an old head to flow as well.
Posted: Sat Jan 16, 2016 12:22 am
by Hank
Check the 07k 12mm IE cam vs the CAT 305 regrind that also has simar lift but check out the duration.... so yes, static flow may be aimilar or even better in some flavors of 20vt port jobs but it doesnt matter matter what it flows if it isnt open. The flow under the curve on a roller rocker destroys a cam over bucket, simply becauze the cam can ramp crazy fast and not worry about being off the bucket.
Posted: Sat Jan 16, 2016 12:43 am
by Mcstiff
:thumbsup:
Posted: Sat Jan 16, 2016 11:31 am
The difference is crazy to see.
Posted: Sat Jan 16, 2016 12:26 pm
by Hank
Yes, The translation is insane power at low boost levels. The following is TTRS on e85, .85AR 6467 in the way of Xona 8267, Shrick 11mm cams, valve springs, stock head, 9.5:1 compression. The Mule is the other line, 6766 turbo via EFR 9174 on a spool valve .92 AR. E85, CNC head, Cat 305s set at 119/111, 9.3:1 stock compression, etc. Same day pulls.
So yeah, the 20vt can eventually come close to peak, but on a bigger turbo, it still requires more boost vs the TTRS. Note the mule step on ramp up for boost. That is to keep it out of surge.
