Page 4 of 7
Posted: Fri Oct 12, 2018 8:41 pm
by varia
and dont forget more videos !!!!!
Posted: Sat Oct 13, 2018 3:05 pm
by heartlessnomad12
And more boost!!
Posted: Mon Oct 15, 2018 11:56 pm
by the german
I can't express how happy this is making me. I need to start looking for a 4.0T donor...
Posted: Tue Oct 16, 2018 10:50 am
by vt10vt
Awesome progress! Keep the updates coming please.
Posted: Tue Oct 16, 2018 1:23 pm
by heartlessnomad12
the german wrote:I can't express how happy this is making me. I need to start looking for a 4.0T donor...
https://seattle.craigslist.org/sno/pts/ ... 16921.html
Posted: Wed Oct 17, 2018 10:22 pm
by the german
too much cracked/broken on the motor
Posted: Wed Oct 31, 2018 12:19 am
by Haenszel
Finally got this in, gonnna pull engine and drop it in, and will also finish up a lot of unfinished stuff in the bay.
Then got this A8 cover and made my own s8 engine cover. Saves a couple hundred $$ doing it.
Also messing with fan control modules. The s8 Ecu does not like the b6 fan control modules. It always starts on 4 cyl disabled mode when the fans are plugged in. Working on a workaround. Lots of little stuff happening to get this ready for more fab work.
Relay box and battery terminal on the left are now hard mounted permanently. Slowly but surely.
Posted: Wed Oct 31, 2018 3:49 pm
by Haenszel
I couldn’t wait any longer. 1.5 hrs from running till on the floor, first time out. Not bad!
Posted: Wed Oct 31, 2018 6:07 pm
by vt10vt
Haenszel wrote:Slowly but surely.
I don't think you can call the progress you've made on this 'slow' haha awesome work as always!
Posted: Wed Oct 31, 2018 9:28 pm
by Haenszel
vt10vt wrote:Haenszel wrote:Slowly but surely.
Thanks! Getting excited now.
Posted: Wed Oct 31, 2018 11:14 pm
by varia
Haenszel wrote:vt10vt wrote:Haenszel wrote:Slowly but surely.
Just like us! Keep up the good work!
Posted: Thu Nov 01, 2018 8:02 am
by jbrentd
Nice work Brian. That engine looks right at home in there.
Posted: Sat Nov 10, 2018 6:42 pm
by Haenszel
Re: '90 Coupe Quattro - '15 S8 4.0t - Triple disk and fuel l
Posted: Sat Nov 10, 2018 7:34 pm
by speeding-g60
come visit and finish one of mine for me. any one. have your choice.
Posted: Sat Nov 10, 2018 7:59 pm
by Haenszel
speeding-g60 wrote:come visit and finish one of mine for me. any one. have your choice.
Definitely maybe.
If there was any chance of them actually getting finished I’d gladly do it, but your projects are eternal. Haha
Posted: Sat Nov 10, 2018 9:32 pm
by speeding-g60
oh i workin on them. the LS car will be the first for sure. the tube chassis car has to be up too. the Quattro v8 Corrado i dont care about. the ABZ v8 swap into the B4 90 i wanna do, moreso than the Rado. have all the stuff for that but a pilot bushing for the flywheel. gotta have it made or figure it out and make it. then i have it all, pre programmed VEMS and all.
you, on the other hand, are on top of shit for real.
Posted: Tue Dec 04, 2018 9:56 am
by Haenszel
Spent a lot of time cleaning up extra junk in the engine bay and finally got the engine back in. There was lots to take care of while it was out, though it doesn't quite look like much was done! This will essentially be the final product.
I decided to make this thing as easy to remove as possible..
- 50-pin quick disconnect from relay box
- 0ga battery/ground quick disconnect
- -8an PTFE fuel line all the way from pump the rail
Also took a run to Vermont for a very nice black b4 hood, which fits perfect and looks way better.
And time to start some exhaust/rear diff carrier fabrication. Got an early Christmas present
-- now the fun begins!
Re: '90 Coupe Quattro - '15 S8 4.0t - Engine Back In
Posted: Tue Dec 04, 2018 11:30 am
by jbrentd
Very clean looking and well thought out on those latest additions! Hood looks to be in a lot better shape than the original.
Posted: Tue Dec 04, 2018 11:42 am
by vt10vt
Where in Vermont were you? I've got that same bandsaw and I think the same welder (mine's a 200DV) and live in Vermont haha.
Looking awesome as usual, love the harness quick disconnects.
Posted: Tue Dec 04, 2018 1:02 pm
by pilihp2
Man, this is so wicked.
been meaning to ask, was it a pretty penny to purchase that 4.0t and all the ecu and wiring related goodies from the junkyard?
Posted: Tue Dec 04, 2018 2:58 pm
by Haenszel
jbrentd wrote:Very clean looking and well thought out on those latest additions! Hood looks to be in a lot better shape than the original.
Thanks man - I've seen some good progress on yours as well -- hope that engine works out!
vt10vt wrote:Where in Vermont were you? I've got that same bandsaw and I think the same welder (mine's a 200DV) and live in Vermont haha.
I was in Williston, just for about 30 mins though. Been over near Burlington a number of times in the past year though -- seems to be a common trip for me now. haha -- yeah the quick disconnects should be pretty amazing. Not much work at all to pull it out now (though I hope I never have to.... hope...)
pilihp2 wrote:Man, this is so wicked.
Yeah, it certainly wasn't cheap - especially in one big purchase. I ended up getting it off a guy in florida that had a wrecked car, not from a junkyard. But, the way I looked at it, is it was cheaper than building a VR6 or 07k setup and would be more reliable. Once you factor in upgrading the whole engine internally, buying turbo, wastegate, fueling, fuel rail, manifolds, intercooler, standalone etc and fabbing everything... buying a pricier engine that shouldn't ever blow up (cuz it will be mostly stock) started looking very very appealing. So then I started looking around and decided to pull the trigger and jump in with two feet. I just hope it all works out well in the end.
More to come soon!
Posted: Tue Dec 04, 2018 4:51 pm
by ringbearer
You are most definitely off to a good start! Being the first to do this swap is also saying something. Keep up the good work
Posted: Tue Dec 04, 2018 5:53 pm
by rennenmsports
Your doing an awesome job! This is going to be killer!!
Posted: Tue Dec 04, 2018 7:33 pm
by Haenszel
Thanks all. Hope to catch some of you guys at some meets/shows next year. Havnt been to anything really since I sold my last car in 2014!
Posted: Wed Dec 05, 2018 1:32 pm
by vt10vt
Next time you're up this way you should let me know! I have a house/shop in Winooski (15min from Williston), and if you've got more than 30min there's some pretty awesome Audi stuff really local. There's a mid-engine 2.7T quattro tube frame car 5min from my house that I've been looking for an excuse to go check out.
