2.7t AWD 1988 Foxbody Mustang (PHOTO HEAVY!)
Posted: Sat Jul 12, 2014 9:55 am
by BiTurboMustang
Hey my name is Brandon and this is my first post and its going to be a long one ;) For a few years now I've been contemplating taking the 2.3 turbo motor out of my 1988 mustang and throwing the whole drivetrain from an a6 or s4 in. My buddy does car salvaging and he ended up with a 2.7t a6 automatic and i paid $800 to basically gut whatever i want out of it and give him the shell after. So anyways this is where I started. Image
[/IMG]ImageImage
So before i started on the actual swap I needed a new garage sooooo
my dad looking at something lol
a day later
after that the scissor trusses
my brother and dads friend
a bit of plywood
a bit of electrical
some floor paint
some awesome porkrinds from my old work(dads friend owns Porky Co)
and the fun begins
made a subframe/motor/tranny cart out of angle iron and lots of tig welding
removed the rear end all in one piece
got the drive train out and on the cart
removed everything necessary to me and got that shell out of here
now had to get the mustang prepped by removing everything basically lol
play with my puppy Turbo
3d print some nylon parts
it started getting cold
so heater was put it
so i was able to roll the motor under the mustang and see whats what and also it was nice in the garage for being 11 outside
a6 subframe was a lot lower then the mustangs frame
dog!
started working on the mounts using roll cage tubing and 1/8" plate i believe
lil bit of tig welding later
nuts were welded on plate before the pipes were welded on and this is after a long time welding and fitting and re-checking alignment of everything
all welded in
lil paint and they look ok
rear motor subframe mounts that i call ice cream sandwiches. they got some holes drilled in and nuts welded
whole front subframe is now bolted on
removed AC then on to the strut towers and lots of cardboard for templates
welded up the side
templates for the filling sheets
dozens of welding hours later
springs were a lil wide so a hammer and sawzall fixed this lol
test fit of the audi column and pedals ;)
mount the steering rack partially(dont mind the 2 different style mounts lol)
time for the rear end, not that pretty but it works
strut mount
and shes welded in ;) did have to cut out a considerable amount of the stock frame to fit but o well lol
after a few months of welding cutting and gringing shes finally on the ground
and the shifter mounted real easy, yes its tiptronic lol
Turbo loves cars :P
Time for the part that would make or break the car, the wiring! I love working with wiring and this bitch has a lot of it lol this is the loom only under the dash for the cluster AC and all that other BS
label everything!
removed what i didnt need
this is what i was left with
now for test fitting and wire organization(the best i could without cutting it all up)
mount the fuse box with a ground stud welded on and the fuse box acts as a mount for the ECU case which i mounted in above
and she worked first try :) and started after a running the starter interlock relay swith wire to the TCU output wire
my brother made me a logo for the car
time for some wire organizing lol but dash fits and i need to make a cluster mount
got a new tranny with less then 80k on it
did a lil painting and it looks ok
welded the heater core pipes shut
played with the transmissions a lil bit
made a plate to mount the master cylinder and and pedals, also made an extension for the booster and had to extend the bolts and the threaded stud on the booster by 2.25"
put in a new LCD
but before that i went for a lil drive
http://s1294.photobucket.com/user/Bitur ... e.mp4.html
and now im looking for a custom driveshaft so i can take her to get some 1/4 mile times at Great Lakes Dragaway! :flag:
Re: 2.7t AWD 1988 Foxbody Mustang (PHOTO HEAVY!)
Posted: Sat Jul 12, 2014 10:04 am
:o
Awesome! I like how you adapted the car to fit the drivetrain and not the other way around. Should make it easy to refit new parts later on with minimal drama.
Posted: Sat Jul 12, 2014 10:07 am
by BiTurboMustang
thanks! yea its so far pretty easy to work on and also I can remove turbos without removing the whole motor so thats a big plus since its annoying to remove the motor in my 2.7t A6 for stuff like that and the clutch which i get to do as soon as this thing gets the driveshaft
Posted: Sat Jul 12, 2014 10:15 am
by 20VAvant
So much WIN. Want...
This is an awesome build.
Posted: Sat Jul 12, 2014 10:31 am
by speeding-g60
awesome job. i love it doing stuff like this....
Posted: Sat Jul 12, 2014 10:42 am
by vt10vt
AWESOME! I can't say I would have stayed with the tiptronic but it is befitting of the typically drag oriented mustang.
Sweet project looking foreword to more.
Posted: Sat Jul 12, 2014 10:53 am
by BiTurboMustang
Thanks guys! and yea tip isnt probably going to be in after it hits about 400hp but i gotta say this thing was really quick to 95ish yesterday b4 the driveshaft incident and its under 9psi right now and ill b going to about 20 as soon as i go get some drag times just to see how she stacks up against the stock tip a6 times(i gotta see if ive been wasting my time lol) My guess is about low 13's high 12's but we will see ;)
Posted: Sat Jul 12, 2014 10:57 am
by dana
you sir, are a crazy person.
welcome.
Posted: Sat Jul 12, 2014 11:29 am
by themagellan
love the approach on how you mated the motor to the chassis, what a wild build. I was half expecting a power glide at the end Lol!
Posted: Sat Jul 12, 2014 1:16 pm
by scubagli
Very cool.
Posted: Sat Jul 12, 2014 2:32 pm
by alxdgr8
Love it!
Now post some videos on youtube of AWD donuts in the snow, but don't tell anyone what's underneath.
Posted: Sat Jul 12, 2014 2:35 pm
by BiTurboMustang
haha yea i cant wait for snow and possibly going to try finding a lil track ppl carve on a lake here in wisconsin and show up some sti's and evo's at their own game ;)
Posted: Sat Jul 12, 2014 4:17 pm
by k2exoman
Awesome project. I like how you adapted to the lower mounting subframe of the drivetrain.
It likely saved reworking of the transmission tunnel.
Curious why you didn't convert to a manual transmission?
God I need to get a garage....
Posted: Sat Jul 12, 2014 8:27 pm
by Mcstiff
Awesome build!
Posted: Sun Jul 13, 2014 2:00 pm
by BiTurboMustang
Thanks again guys! It will end up being manual after the tip goes out but I really didnt want any extra variables in the wiring process. I also didnt want to spend $2500 on the parts to do it if i didnt know if everything was going to work in the first place.
Posted: Sun Jul 13, 2014 2:16 pm
by pilihp2
I...
Wha...
Wow.
I am amazed. :drool:
Posted: Sat Jul 19, 2014 11:28 pm
by Kuma
Glad you made it Brandon!
Posted: Fri Sep 05, 2014 7:53 pm
by pete82
a conversion thats a bit different to stock, nice work
update with 1/4 mile video ;)
Posted: Sat Sep 20, 2014 11:37 pm
by BiTurboMustang
ok so I've been busy on the car.
got a new 1 piece diveshaft in
I welded in the roll cage ive had laying around for 6 years lol
started building a new exhaust with a ton of pie cut pieces
then it was time to take her to a big car show in milwaukee
and i won most unique which didnt surprise my friends much haha
after that fun stuff i ended up getting my subframe connectors because foxbodies are as ridged as rubber lol
after that it was off to the track with my new carbon fiber(real carbon) plate to hold my fake carbon switch panel lol
added a cooling fan and a PWM to control speed, it may b noisy but this fan helps a ton cuz it blows by your feet and to the window ;)
dog watching over jared lol
got a sweet hazard switch from ebay
merica! lol
and now time for the track, but found out on the freeway that my alignment isnt that great and i might need to re-balance 1 wheel but i wasnt going to let that stuff ruin my day so i said screw it im still running! It was also super busy at Great Lakes Dragaway that day for being a Sunday so i was only able to get in 2 passes. First one is the one i got down here and it was no launch, one front o2 sensor had no signal(still trying to find break in wire) and 7 psi(boost leak which i found 2 days after) Knowing that this drivetrain in the a6 its from would have ran a 15.7 stock and even with me having all these issues i dont think it went to bad. Nothing broke and it doesnt feel like it was really trying so i consider it a success :):popcorn:
after that i figured out one of my front springs was broken and it was one reason it felt weird on bumps so now im putting in my brothers stock gti springs :P
Posted: Sun Sep 21, 2014 12:16 am
by Kuma
I have some b6 springs if you want them. Just pay shipping.
Posted: Sun Sep 21, 2014 2:28 am
by BiTurboMustang
u happen to know the spring rate?
Posted: Mon Nov 10, 2014 12:42 am
by BiTurboMustang
hey guys thanks for the comments! I haven't been keeping this build up to date but here is my latest run at Great Lakes Dragaway.
http://www.youtube.com/embed/l0p6ufKKMHs
If they r open next weekend I know ill get 12's with just slightly more boost(12-14psi)
But please subscribe and like the videos ;)
single turbo build will be on video as i get it done along with o1e tranny install and lots of carbon fiber construction of body panels!
Posted: Mon Nov 10, 2014 8:43 am
by scubagli
Pretty awesome!
