VEMS Bigger Map Sensor Bug?
Posted: Fri Mar 06, 2015 2:14 pm
by black
Hi,
I replaced the internal 400 kPa map sensor by a 700kPa internal.
I changed the ECU calibration like VEMS Wiki tells -->
http://vems.hu/vt/help/v3/v3_ecu_calibration.html
700 : set "MAP range unit"> 510 and MAP range=778 kPa --> done ans sensor is working fine - tested up to 650kPa on VEMS Gauge
Problem, now I see all map values in VEMStune are half and Top Limit in Tables is 255
When I try to set bigger values than 255 in VE or Ignition table I get an error message --> "VEMS value is incorrect or out of range"
??? What is the issue - did I miss something??
regards
3.6 board, 1.2.10 firmware
update - when ECU is connected, all tables can be set up to 510kPa... but not more than 510kPA
When I log and save a logfile - all pressures are up to 510kPa in this logfile... ECU disconnected
But when I save a config file from the ECU, disconnect the ECU and load the config to VEMStune all MAP values are half in this file :bangshead:
Re: VEMS Bigger Map Sensor Bug?
Posted: Fri Mar 06, 2015 4:45 pm
by vems
Did you change "Table kPa unit" to 4? It's right below "MAP Range Unit" You didn't mention that in your description of the problem.
It's always advised to submit a Sharing Center report from the help menu when you run into problems and include a config and log(s). Then you can provide the URL to either your reseller, or even publicly if you wish so it's easier to help you out.
Thanks much,
Jason
Posted: Sat Mar 07, 2015 3:01 am
by black
VEMStune help sais: "Table kPa Unit This is usually set to '2' for standard MAP sensors."
Setting it to 4 when ECU connected is limiting the MAP Sensor Range to 510kPa (should be 1020 like it is on setting it to 2)
When VEMS is connected to VEMStune - all kPa Units are shown right up to 700kPa
When loading the saved config without VEMS connected, all kPa Units are half value...
When opening a logfile without VEMS connected, all kPa units are shown right up to 510 kPa but 510 is still the Limit for Tables
Update
I save the config file from ECU to VEMStune (all KpA right in VT but limited to 510 in Tables)
I disconnect ECU from VEMStune (all kpA still right in VT but limited to 510)
I close VEMStune
I open VEMStune and load the config file again (ECU still disconnected)
All kPa Units are half value now and 255 is max
I edit the kPa AXIS in VE table f.e. 200 (should be 400) to 225
I connect ECU
I upload the saved config file to ECU
All kPa units are shown right... at the place I edited 200 to 225 is now shown 450 in VEMStune when ecu connected...
So this is a ECU offline issue... and an 510 Limit issue even though range is set up to 1020
Posted: Sat Mar 07, 2015 3:40 am
by black
calibration
after setting map range unit to double, VEMStune must be restarted to set values higher then 510 in range (after restart, max is 1020)
Posted: Sat Mar 07, 2015 4:50 am
by black
Update
when trying to set up a config file and ECU disconnected!
First setting map range unit from normal <510 to double >510
Saving config file and closing VEMSTune
ECU still diconnected
Opening VEMSTune an loading config file
Trying to set range from 510 to 1020 --> getting error message... --> "value out of range"
so one is only able to set up range up to 1020 when ECU is connected
short summary:
ECU is connected
Map Range Unit set to double >510
Table kPa Unit = 2
Burn
Save
Restart
Map Sensor Range (Slope) set to 778 (limit is 1020)
Burn
Save
Now VEMS can show MAP up to 700kPa on Gauge
Limit for Map in Tables is 510 --> error
Logs are shown correct up to 700kPa
Setting Table kPa Unit = 4
Limit for Map Sensor Range is 510 now
Limit for Map in Tables is 255
ECU offline
loading the saved config file to VEMSTune - ECU offline
Map Range Unit is double >510
Table kPa Unit = 2
Map Sensor Range (Slope) is 778 (limit is 1020)
All Tables show MAP values half
Limit in Tables is 255kPa
Limit in Menus is 255kPa
typing 240 in Top of VE Table
Loading this file to ECU (connected) and all values are shown correct (480) but limit is 510 in tables :bangshead:
PS
I have to look at the Sharing Center report function in VEMStune...
