Page 1 of 5
My VEMS VRT o1e CQ..
Posted: Sun Oct 18, 2015 2:26 pm
by bdcoombs
I thought I had a thread here but I didn't see it in searches.
VEMS standalone, 7 bar map, dual wheel speeds, knock and egt
car is a stock block, stock compression, stock head.
only runs on e85 and I use the ID 2000cc injectors.
I have parts for a second motor with oversized valves and some porting but I want to see how far I can push this stock motor first.
This winter I plan to finish the cage. and rebuild the rear end suspension and mount components.
need to change exhaust still, my muffler is a tad low in the streets with the small tire setup on it.. was fine with the 17s
Re: My VEMS VRT o1e CQ..
Posted: Sun Oct 18, 2015 2:27 pm
by bdcoombs
changed to a dual 044 surge tank as well.
Put the 16" wheels back on which I like how these look better then the balloon tires on my 17". I need other tires as uts too low on the 16" as well.
I am still looking for a v6 euro bumper, but I made some carbon blanks and put some brake ducts where the fogs sit for now in this short one.
also I've been practicing my launching and burnouts in the driveway..
I have one on youtube.
Posted: Sun Oct 18, 2015 2:28 pm
by bdcoombs
video isn't the best but this was when I was setting up the launch control and boost
[youtube]http://www.youtube.com/watch?v=eHRdZ-QY4-4[/youtube]
[youtube]http://www.youtube.com/watch?v=JoE9dASH6vs[/youtube]
I get my license back in 7 days and ill host more
just bought wildwood front calipers so hopefully I can get them on soon as well
Posted: Sun Oct 18, 2015 2:30 pm
by bdcoombs
looking to rebuild the rear end, first is rear tie rods, anyone know the length of these off hand I have the longer version ones factory
Posted: Tue Oct 20, 2015 12:29 am
by bdcoombs
only had enough moly to make one today,
so I bought some radius rod for now but had to turn the down a touch
Posted: Tue Oct 20, 2015 1:00 am
by DE80q
How long did they end up being? I want to do this on my 80q, but haven't had a chance to look into it.
Also, are you planning to drill the tierod holes straight through? If not, I may be persuaded to make you a pair of taper pins for the rod ends.
Posted: Tue Oct 20, 2015 8:45 am
by bdcoombs
They fit good
Posted: Tue Oct 20, 2015 8:47 am
by bdcoombs
I would love to have a taper pin. However I was going to drill them straight through as that is how my fronts are.
Posted: Tue Oct 20, 2015 8:50 am
by DE80q
Understandable. What did the length on them end up being?
Posted: Tue Oct 20, 2015 11:54 am
by bdcoombs
Chromoly heims too
There are long and short arms factory depending what year rear hubs u have.
Posted: Tue Oct 20, 2015 11:55 am
by bdcoombs
That also dependant if your heims measure the same length as mine.
Posted: Tue Oct 20, 2015 5:16 pm
by bdcoombs
made a video to show someone the Bluetooth
[youtube]http://www.youtube.com/watch?v=X0b1wrwdxaM[/youtube]
Posted: Tue Oct 20, 2015 5:19 pm
by bdcoombs
Posted: Tue Oct 20, 2015 5:23 pm
by bdcoombs
much brighter over normal h4 bulbs which were good quality bulbs to begin with.
h4 on left - LED on right..
Posted: Tue Oct 20, 2015 7:41 pm
by mushasho
LED I'd assume is more durable than HID?
Posted: Tue Oct 20, 2015 7:52 pm
by bdcoombs
yes hid suck an blow bulbs and ballast.. these never blow being LED.. use less power and put out a bright light beam as well as a truer pure white and kelvin is better
Posted: Tue Oct 20, 2015 8:45 pm
by speeding-g60
info on bulbs?
Posted: Tue Oct 20, 2015 9:03 pm
by bdcoombs
Ebay. I found one of the highest lumens of output 9,000
But there are a ton of different ones on there. I have led bulbs in all 5 of our vehicles now.
http://pages.ebay.com/motors/link/?nav= ... 35&alt=web
Posted: Tue Oct 20, 2015 9:21 pm
by bdcoombs
Next order of biz
Posted: Tue Oct 20, 2015 9:57 pm
by mushasho
Do I see a rear caliper with a cable driven e-brake provision?
Posted: Wed Oct 21, 2015 9:06 am
by bdcoombs
You will if this works right
Posted: Wed Oct 21, 2015 9:56 pm
by vt10vt
YES. Always loved this thing from the 1.8T until now, glad to see you posting here!
Posted: Thu Oct 22, 2015 7:33 am
vt10vt wrote:YES. Always loved this thing from the 1.8T until now, glad to see you posting here!
Posted: Thu Oct 22, 2015 5:07 pm
by scubagli
Rad.
Posted: Sat Oct 24, 2015 3:18 pm
by bdcoombs
Thansk guys. Means alot to me.
Well I got the car aligned Friday after the new tie rods. And the mechanic pointed out a leak between trans and engine. First thought was rear main or trans. But when I got home I noticed a drip in the driveway and it looked and smelled like brake fluid. Turns out my slave was leaking. So I put a new one in. Bleeding clutch by yourself sucks. Even with a vaccum pump.
