VSS signal to VEMS EC18-8
Posted: Thu Mar 24, 2016 10:59 pm
Hi everybody,
I am preparing to install the VEMS kit I bought a long time ago at great expense. In hindsight, it would have been better to just buy a PnP unit from Marc. What's done is done.
I have laid out the harness I have in the engine bay on my AEB. A few thing are clear: The connector for the CLT sensor is round, not square. The VSS connector is rounded, not square. I also have an unknown connector. I think this harness was made for a later gen engine (b6? transverse 1.8t?)
So, the issues:
1. The CLT connector issue I can fix by just getting a round connector sensor. Should just fit right in the old style sensor place.
2. The VSS connector is a little more complicated. Do I a. cut off the current rounded connector on the VEMS harness and splice in the square connector? Or b. Can I buy a (later) rounded style connector VSS and bolt it into my trans?
3. Unknown connector with 3 pins. No idea what it is. Do I need it?
4. TPS does not have the idle wires in it. IIRC, Marc said not really needed on an AEB, just adjust timing/idle speed.
5. There is a loose wire in the harness labeled FPR. I assume this is for a fuel pressure sensor. Correct? Do I need it?
I have marked the connectors in the overview picture. Please comment.
So, the issues:
