Vems pnp for 3b question
Posted: Fri May 25, 2018 6:33 pm
by quattrobros
Ive been running the vems pnp setup for about a year now and im curious as to what is all not being used.
There are two knock sensors on by block and i dont think vems uses knock detection at least not im my case. Can anyone confirm this? Can i remove them?
also i see some poeple dont have an isv? How do i go about doing that?
Just trying to clean up my harness as the motor is not in the original car.
Re: Vems pnp for 3b question
Posted: Sat May 26, 2018 5:59 pm
by varia
vems can use knock sensors
Posted: Fri Jun 01, 2018 6:38 pm
by Juizer
How to wire stock knocks to vems?
Guide for dummies please.
OT/ Maxxecu points to use Bosch 0261231046 sensors which only have 2 pin connectors vs stock 3 pin ones, and are not polarity sensitive.
Maybe vems needs these as well instead the stock ones? /OT
Posted: Sat Jun 23, 2018 11:29 am
by 88a5tq
Not sure about what you posted from Maxecu but MANY people are using stock knock sensors fine on 3B and AAN or with stock bolt-through version from either on the older 20vt's as an update. Wait until you see the FAQ concerning dialing in the knock settings lol! Don't be discouraged and decide if you want to run one or 2 sensors from the start.
