Turbo speed signal to VEMS
Posted: Sat Mar 16, 2019 12:14 pm
by Neacail
Yes I searched.
I'm getting a Borg Warner S257SX-E for my AAN, and I'm running VEMS PnP.
I've tried googling, and I've searched here as well and if there is info, I didn't find it.
What capability does VEMS have for turbo speed input software wise? The hardware/wiring side I'm not worried about, it seems pretty straightforward. I was wondering if anyone has set this up in vemstune, and how it might be used as a protection.
Thanks!
Re: Turbo speed signal to VEMS
Posted: Sun Mar 17, 2019 1:26 pm
Lol this isn't vortex man, people here don't jump on a guy for asking questions based on post count.
Anyways, I'm not actually sure as I haven't seen anyone set up like that. Do you have a low/high level limit signal you can input with distinct voltages to set an audible alarm or dash warning (by, say, triggering the MIL)? So that if it reaches the lower threshold you get one warning and the high limit you get another? That would seem relatively simple to set up using an open channel on Vems. Or perhaps not, just spitball'n here.
Posted: Tue Mar 19, 2019 5:07 am
by ChrisAudi80
IIRC you need a frequency input for turbo speed.
"The speed sensor is powered by a +5V supply and the return signal is a variable frequency square wave that has maximum amplitude of 5V and has a 50% duty cycle"
https://www.full-race.com/store/borg-wa ... sor-kit-2/
So, it depends on the spec of your PnP. Does it have the wheel speed 1 or PS2 option? If wheelspeed1, it's on EC18-8. No idea what that corresponds to on the PNP. PS2 is separate.
It would be best to check with the supplier of your ECU.
Here is another sensor, looks the same but only $60 https://www.ebay.com/itm/6-7L-Turbo-Spe ... 53&vxp=mtr
Posted: Wed Mar 20, 2019 11:37 am
I run one of these, but they seem to be unavailable now. https://www.ebay.com.au/itm/Road-Rage-G ... 2509207405
It converts the signal to a standard 0-5v analog output.
Posted: Fri Mar 22, 2019 4:06 pm
by bradyzq
http://www.circuitstoday.com/frequency- ... sing-lm331
requires a bit of breadboard action, but is totally doable.
Posted: Sun Mar 24, 2019 3:02 pm
by Neacail
bradyzq wrote:http://www.circuitstoday.com/frequency-to-voltage-converter-using-lm331
This might be the way to go, it's bench testable and can be calibrated. I've got an oscilloscope with a frequency generator so it might be best to just give VEMS a 0-5v input.
I'll let y'all know how it turns out.
Posted: Mon Mar 25, 2019 2:48 am
by ChrisAudi80
:thumbsup:
