Page 1 of 9
Kennys UrS4 (SX-E 257 Big Turbo Build Complete...Tuning in )
Posted: Sat May 11, 2013 2:54 pm
by morris400
Re: My introduction (UrS4)
Posted: Sun May 12, 2013 9:25 am
by morris400
I'm 99% sure I found my oil leak, it's coming from the oil pan. I'm gonna have to get this fixed. First repair bill in the way. Lol
Posted: Sun May 12, 2013 9:41 am
by ringbearer
Make sure all the oil pan bolts are tight and present. Sometimes they come loose BTDT on unopened engines.
Clean everything too so you can pinpoint where the leaks are.
Posted: Sun May 12, 2013 7:32 pm
by mushasho
Super happy you joined!
And soon you'll realize the joy of diagnosing a UrS vs the B5S4 & the ease of repairing it yourself too... I've had both and feel I made the right choice in sticking to UrS cars...
Posted: Sun May 12, 2013 7:36 pm
by mushasho
And be sure to check out the Project section... Lots of cool stuff there...
Posted: Sun May 19, 2013 1:46 pm
Kenny! You found the spot where the cool kids hang out, I see.
One other thing to check with the oil leak is the crush washer on the drain plug. Might have been reused.
If you need a new oil pan after all, I have one you can buy for cheap.
Posted: Mon May 20, 2013 12:15 pm
by morris400
I may take you up on that offer, I'm gonna be doing a oil change maybe tonight and ill clean the area with brake cleaner and see if I can find a noticeable leak. It's been a cupple drops over night but nothing real bad. Took a look under and saw the oil pan had oil on it. I'm still good for tomorrow to swing by in the morning time say 10 ish.
Posted: Sat May 25, 2013 10:44 pm
by Kuma
i must say, i like you even more since you support our troops.
Posted: Sun May 26, 2013 9:31 am
by Mentosman42
if the oil leak is on the driver side of the engine also check the oil dummy light sender, they can leak and drip oil. I had one that was pissing a stream at one point.
Posted: Sun May 26, 2013 3:39 pm
by morris400
Kuma wrote:i must say, i like you even more since you support our troops.
I also serve, since 2007 I've been in the Canadian military,
2007-2010 with 1 PPCLI ( princess patricas canadain light infantry)
2011-now with 1 signal sqn.
I've meet some amazing people in the last 5 years since I joined, made some amazing friends and lost a few as well.
Posted: Thu Jun 20, 2013 6:04 pm
by morris400
I picked up a new set of oil pan bolts today. I noticed at least one missing when I changed the oil last week ish
Posted: Fri Jun 21, 2013 9:36 am
by Kuma
morris400 wrote:Kuma wrote:i must say, i like you even more since you support our troops.
That's incredible, observed with Canadians, Dutch, and some Ozzies when I was overseas. Great people and soldiers.
Posted: Mon Jun 24, 2013 8:06 pm
by morris400
Tonight I fixed my pwr steering leak, and replaced the 8 missing oil pan bolts...and tightend another 3-4 that were extremely loose.
Posted: Tue Jun 25, 2013 7:52 am
by EDIGREG
8 missing? LOL wow that thing was about to fall off.
Posted: Tue Jun 25, 2013 10:34 am
How'd you deal with the PS leak, buy the fancy dancy tool or use the ol' screwdriver & hammer?
Posted: Tue Jun 25, 2013 2:26 pm
by morris400
i was able to borrow a drag link from work, then file down the corners and it worked. new screw comes in tomorrow from audi. hammer and screw driver was not working as it was fucking up the screw. all i did was use the teflon tape untill the new oring arrives.
im sure it was about to fall off lol.. bottom of car is covered in oil right now ill need to clean that up the next cupple days. i think the PO masked some issues with the car that are coming out now. im a little pissed but ill take it one step at a time and fix ther small things. the turbo is making some sounds it probally should not ( dentist drill ). i checked for shaft play on the cold side and found some but not much. at least this turbo can be swaped in a matter of mins over the B5S4.
Posted: Tue Jul 02, 2013 10:03 am
by morris400
picked up a set of B5 S4 wheels this past weekend, im debating on which color to plastidip them. also looking into engine mounts as well as mine are pertty bad.
Posted: Tue Jul 02, 2013 3:22 pm
by mushasho
Need motor mounts?
Posted: Tue Jul 02, 2013 5:17 pm
by morris400
mushasho wrote:Need motor mounts?
Yea I sure do, and tranny mounts and all mounts. I have a lot of drivetrain play.
Posted: Wed Jul 03, 2013 6:46 am
by mushasho
morris400 wrote:mushasho wrote:Need motor mounts?
Go thru my thread to see what's been done for mounts...
Posted: Wed Jul 03, 2013 11:03 pm
by morris400
You use the jegs ones?
Posted: Thu Jul 04, 2013 5:23 pm
by mushasho
morris400 wrote:You use the jegs ones?
Jegs or summit is fine...
Posted: Sat Jul 06, 2013 6:46 pm
by morris400
Changed the front end a bit today. Thoughts?
Posted: Sat Aug 10, 2013 4:56 pm
by morris400
Today I changed my valve cover and new gasket, also installed a new tps sensor.
Posted: Sat Sep 14, 2013 4:38 pm
by morris400
I've done a bit more since I updated last.
Did some more painting in the bay, swaped out my DV and installed my 17s and sold my 18s.
And for the next thing, I'm working a a new PCV system.
