Page 1 of 2
Bosch spark plug failures
Posted: Mon Nov 25, 2013 11:35 pm
From Andy's 20vt coupe this weekend.. I have heard Bosch plugs suck, but this is insane. I feel bad for his turbine, I hope it's not too beat up
Image .
Re: Bosch spark plug failures
Posted: Tue Nov 26, 2013 12:01 am
by Mcstiff
:hammer:
Posted: Tue Nov 26, 2013 12:56 am
by EDIGREG
wtf? Something weird going on there... ya they are known to fail, one plug failing happens, but all 5?
more detailed photos of the electrodes?
FWIW I have never seen FR5DTC fail, only F5DPOR
Posted: Tue Nov 26, 2013 1:16 am
by SEStone
That sucks. A similar type of failure wrecked the engine on Keith Anderson's white UrQ racecar last Summer. We finally got it running right after three events of trying, and after about 6 laps it dropped a cylinder. The electrode bounced around the cylinder, wrecking the piston and valve and damaging the head.
Posted: Tue Nov 26, 2013 9:00 am
That's why it's only ngk for me.
Posted: Tue Nov 26, 2013 10:22 am
loxxrider wrote:That's why it's only ngk for me.
No kidding. I tossed my spare set into his car and he was of and running.
Posted: Tue Nov 26, 2013 10:43 am
by ringbearer
Sucks, I lost an electrode with the same plugs in my dads S6, didn't help anything downstream...
Posted: Tue Nov 26, 2013 10:47 am
by All_Euro
Wow - I've been running this plug for almost two years... no issues but good to know about this!
Posted: Tue Nov 26, 2013 10:55 am
I looked at his tune, while it may have a bit more timing than I run, it certainly wasn't lean and I could not hear any knock. This was at the track, so while these may get by for onramp blasts, I would not trust them under heavy load.
Posted: Tue Nov 26, 2013 11:46 am
by Audilard
Which NGK is recommended?
Posted: Tue Nov 26, 2013 12:56 pm
by quattro87
It's hard to tell from the pictures, but it looks like they are melted rather than broken to me. Getting hot enough to melt doesn't sound like a fault of the plug. Hank and I have been running Bosch tri-tip plugs in our 20vt cars for awhile now and other than fouling under high boost haven't had any come apart failures. Do you have better pictures Jim? Did Andy's engine sustain known damage?
Posted: Tue Nov 26, 2013 2:32 pm
by Audilard
quattro87 wrote:It's hard to tell from the pictures, but it looks like they are melted rather than broken to me. Getting hot enough to melt doesn't sound like a fault of the plug. Hank and I have been running Bosch tri-tip plugs in our 20vt cars for awhile now and other than fouling under high boost haven't had any come apart failures. Do you have better pictures Jim? Did Andy's engine sustain known damage?
I run those tri-tip plugs too and I pretty sure mine failed. Cracked the porcelain and melted the plug. I think this may have been an isolated event though.
Posted: Wed Nov 27, 2013 1:11 am
That's just damage from detonation on your plug Darin.
So this all started as a miss under boost. First thing we did was inspect the plugs, They were all on one piece at this point. We narrowed it down to cyl 4, I handed him a new plug wire and plug, said swap these out and I am going out for another session. Go back and miss was still there, but I didn't know he didn't actually swap the plugs.
This is when I thought it was a coil, Nate actually sent a few down with a truck they had headed our way if we needed them! We ruled out a coil by swapping in from my car and at this point I was back to the plugs. Pulled it again and the ground strap was gone.
Replaced with my ngk and he half of Sunday before the rest failed.
Not sure how I could take a better pic, the ground staps just fell off. It's like the metal fatigued and fractured. No melting. They are just garbage in my opinion.
Ngk bkr7e. Brett says he runs one stage cooler bkr8e, but it think I fouled those when I tried.
I think the oem style Bosch plugs are fine, it's the generic plugs that suck.
Ngk plugs are cheap, they have relatively good life span, and don't fail like this. Plus you can gap them.
Posted: Wed Nov 27, 2013 10:04 am
by All_Euro
Handy heat range chart...
Posted: Wed Nov 27, 2013 12:05 pm
by 20VAvant
Anyone have the NGK part number for the 3B 20VT?
I'm pretty sure I have the second set of Bosch plugs in @~180K....
Posted: Wed Nov 27, 2013 4:25 pm
by highlander69
Never really seen any bosch wire failures on my end, however I will never run bosch platinum
plugs in any car that I own.
Cheers,
Craig
Posted: Wed Nov 27, 2013 9:22 pm
20VAvant wrote:Anyone have the NGK part number for the 3B 20VT?
I was also going to Suggest det on darins plug.
The NGK bkr7e is what you want. I believe the part number is 4644, correct me if I'm wrong.
Posted: Mon Dec 02, 2013 2:43 pm
by amd is the best
BKR7E is an NGK 4644 which is a 7 heat range. Plug I run in my car on pump fuel.
NGK 4554 is the Racing 8 heat range plug too if you want colder. Plug I run with E85.
Posted: Mon Dec 02, 2013 3:12 pm
by 20VAvant
amd is the best wrote:BKR7E is an NGK 4644 which is a 7 heat range. Plug I run in my car on pump fuel.
Good info. Would you be able to share gapping information as well? :D
Posted: Mon Dec 02, 2013 4:08 pm
by amd is the best
I run .024 usually without an issue. :)
Posted: Wed Dec 11, 2013 8:52 am
by FRP
Hi guys, Jeff @ FRP here, IMO the majority of this plug damage is strictly tune related. Too much timing and or too lean, or both, as related to the fuel being used at the time of the damage.
I run the Bosch triple electrode copper core plugs in the Bonneville engine and they come out looking like new with just a nice chocolate tan patina on the insulator tip.
Posted: Fri Dec 13, 2013 12:49 pm
by Hank
A little late myself, but did you see the rest of the motor Jim? The headgasket was pushed out on the fire ring... Andy's motor detonated, period. I agree with what Jeff said.
Posted: Fri Dec 13, 2013 4:33 pm
No, I didn't. Glad to hear you got a look at it.
Posted: Sat Mar 29, 2014 3:18 pm
by Audilard
I'm still running the Bosch triple electrode copper plugs on my E85 470whp engine. I'm curious, what's the typical life span in an high output engine for plugs?
Posted: Sun Mar 30, 2014 1:06 am
by SEStone
Audilard wrote:I'm still running the Bosch triple electrode copper plugs on my E85 470whp engine. I'm curious, what's the typical life span in an high output engine for plugs?
I typically got 7-10k miles out of a set of those. Running NGK coppers now. Had to regap them after two tanks of gas, PITA. I'm down to a .028" gap, which is kinda on the small side of things IMO.
