Looking for some -6 AN fuel line & fittings
Posted: Mon Feb 03, 2014 1:05 pm
by DE80q
I was about to order a few of these, and then thought I might as well ask if anyone has any kicking around. I know a lot of people order kits of these, and end up not needing some of them. I ordered a kit a while ago, but some of the fittings are messed up.
I am looking for
1-45 degree hose end Found
2-90 degree hose end 1 Found
1-180 degree hose end Found
1- 14mm/6an adapter
I would also be interested in about 3 feet of braided line(stainless or nylon), and maybe some of the "fire sleeve" I see so many people putting on these lines.
Let me know what you have, Thanks
Re: Looking for some -6 AN fuel line & fittings
Posted: Mon Feb 03, 2014 3:11 pm
by elaw
Here's a suggestion: use PTFE (Teflon), or at the very least PTFE-lined rubber hose.
With all the weird stuff they're putting in fuel these days (like lots of Ethanol ;) ), compatibility problems are cropping up with traditional rubber hose.
Also PTFE has much better heat resistance than rubber.
Posted: Mon Feb 03, 2014 5:02 pm
by DE80q
Thanks Eric, that is actually what I was looking at.
Posted: Wed Feb 05, 2014 2:25 pm
by DE80q
Found the 180, anyone else got any colecting dust?
Posted: Mon Feb 10, 2014 2:02 am
by roortube
Search ebay for used an hose...loads coming out of NC from NASCAR shops for cheap.
Posted: Wed Feb 12, 2014 1:09 pm
by DE80q
Thanks roortube, I didnt even think about that. I just figured there are probably a bunch of people that had some extra pieces kicking around.
I found a few more piece, but was wondering if there was anyone else other than 034 that sold the 14mm-6an adapter for the feed line? I would rather do that than use a compression fitting on the feed line.
Posted: Thu Feb 13, 2014 11:18 am
by my2000apb
DE80q wrote:Thanks roortube, I didnt even think about that. I just figured there are probably a bunch of people that had some extra pieces kicking around.
its a standard Earl's piece, should be able to get it at most places
Posted: Sat Feb 15, 2014 8:36 pm
by mushasho
DE80q wrote:the 14mm-6an adapter for the feed line?
Is this for use at the fuel sender location?... I'm trying to find a -8an variant and can't seem to find it... (seems not such a standard item)... I might have to use a barbed end but I'm not sure if it can withstand +100psi of leak free line pressure.
Sent from my KFTT using Tapatalk
Posted: Sat Mar 01, 2014 4:02 pm
by my2000apb
I searched for a long time, and ended up using a 6an flare female to male 8an adapter.
http://www.summitracing.com/parts/ear-9893068erl
Posted: Sat Mar 01, 2014 4:08 pm
by mushasho
I found it
https://www.merlinmotorsport.co.uk/p/m1 ... 76-08-m14d
Posted: Sat Mar 01, 2014 4:22 pm
by my2000apb
Posted: Sat Mar 01, 2014 4:24 pm
by Mcstiff
mushasho wrote:I found it
Better exchange rate http://plumbingmonkey.com/776-08-M14D-A ... -Bolt-14MM
my2000apb wrote:we are talking this one
http://www.summitracing.com/parts/ear-9894dbherl
This one is also cheaper than Summit http://www.anplumbing.com/search/index? ... 9894DBHERL
Posted: Sat Mar 01, 2014 4:44 pm
by my2000apb
yeah Ill use them when I need a bunch of stuff, but shipping is a bit more, well worth it for a good order, but im always needing some summit stuff
Posted: Sat Mar 01, 2014 10:28 pm
by mushasho
Just saying... No adaptor needed if you get the right banjo...
http://www.technafitstore.com/category- ... =16&page=2
Posted: Sat Mar 01, 2014 10:30 pm
by Mcstiff
mushasho wrote:Just saying... No adaptor needed if you get the right banjo...
B3/4s don't have the filter in the front :P
Posted: Sat Mar 01, 2014 10:56 pm
by my2000apb
yeah, haha I always laugh when I see the fuel filter that close to the exhaust/hotside/dp
Posted: Sun Mar 02, 2014 10:31 pm
by EDIGREG
The piece you guys linked is 14x1.5mm O-RING fitting, the factory stuff is all inverted flare fittings.
Hank welded up a set of these for me using Audi/Mercedes fittings
Posted: Sun Mar 02, 2014 11:30 pm
by Mcstiff
Good point, though I sware they used to sell the O-RING fitting for this use (I think i have a set, anyone want?) they now list 14mm Inverted Flair to -6
No to take away from Hank's solution; he should be busy making 07K parts :-P
http://store.034motorsport.com/14mm-inv ... 20843.html
Posted: Mon Mar 03, 2014 7:35 am
by DE80q
Mcstiff wrote:Good point, though I sware they used to sell the O-RING fitting for this use (I think i have a set, anyone want?) they now list 14mm Inverted Flair to -6
These were the fittings I was talking about from 034.
Posted: Tue Mar 11, 2014 3:04 pm
by mushasho
To think the 034 Fuel Line kit doesn't include any inverted flare fittings... C4 Fuel Kit
Posted: Tue Mar 11, 2014 4:00 pm
by Mcstiff
mushasho wrote:To think the 034 Fuel Line kit doesn't include any inverted flare fittings... C4 Fuel Kit
Right but the OP has a T44 and a B3 so I believe we are talking B3s which have hardlines on the firewall as seen in the lower left here (and the fuel filter in the back). No reason that you couldn't run a line from the back of the B3/T89/B4 up to the rail but I think a 20v will run out of air before it needs more fuel that the hardlines will give.
Posted: Wed Mar 12, 2014 7:17 am
by DE80q
Just be clear, when I started this post, I did not own a type44. This post was for the fuel line setup for my B3 20vt project. So yes, the hard lines run to the front, the filter is in the back under the car, and there will be no need to upgrade the fuel lines as the 20vt absoluly will run out of breather before it run out of fuel.
On a side now, the o-ring 14mm-6an adapters is what were used for a long time for this task. Only somewhat recently was the inverted flair version brought out. they work just fine as long as you dont over torque them.
Posted: Wed Mar 12, 2014 9:43 am
by EDIGREG
mushasho wrote:To think the 034 Fuel Line kit doesn't include any inverted flare fittings... [url=http://store.034motorsport.com/fuel-line-kit-high-flow-c4-s4-and-
That kit is for plumbing new lines from the tank, not for attaching fittings to the OE lines.
Posted: Fri May 02, 2014 4:38 pm
by boost_addict
A1 racing. Its the best when its all in stock and you can pickup too.
Shouldn't b to far from you either
They have good pricing too
