another S2 conversion
Posted: Wed May 07, 2014 7:14 pm
1991 Audi Coupe quattro black on black with 117K miles
Purchased this coupe on January of 2013 from Chris M. in San Francisco, he was the second owner of the car, at one point the car was stolen from him, lightly vandalized (scratched paint, cut-ed leather seats), found than returned. Upon recovery the car was repainted in 2003 to Espresso Mocha Black 033, covered and storaged in a warehouse for 10 years. This is how I got it:
During the last year I was collecting parts, information to be ready when the time will come.
Looks like I will be able to pull the engine out today and in the next few week I will be installing the new one
Build Details
Engine:
AAN/3B Engine Stock Internals Head/Block – Rebuilt to OEM specs
OEM LHD S2 ABY engine harness, no slice and dice (imported from Europe)
Fresh MLS Head Gasket
MTM Stage 1 280hp Chipset
034 High Output 034EFI DIS coils
Magnecor LS2 Wire Set
New Spec Stage 3 Clutch
034 Poly Snub Mount
S2 ABY Intercooler (imported from Europe)
S2 ABY Cross-member (imported from Europe)
Battery relocated (to trunk storage area) with OEM Audi RS6 harness
Turbo Smart adjustable diverter valve
7a fuel pressure regulator
AAN injectors
500W Fan (and harness modifications to support)
Custom Radiator Shroud
New Roose Motorsport Silicone Coolant Hose Set (all)
New 034 Silicone Boost Hose Set
034 down-pipe
Vacuum booster brake conversion
Suspension/Drivetrain:
Stock 01A transmission
New Koni adjustable shocks
2Bennett coil-overs
New Sachs top mount with VAP mount saver
New PowerFlex Control Arm Bushings
New Tie rod ends
New Sway bar end links
New Ball joints
Original S2 5-lug Hub Conversion front
Audi B5 A4 rear hub (because needed the extra 8mm offset for the brake)
Brake; Front:
Porsche 993 Turbo (Big Red) 4-piston caliper
Porsche 993tt/GT-3 322x32mm rotor w/ BIRA rotor hat
RS2 front caliper bracket
Rear:
Audi urS4/6 rear calipers
Audi B5 S4 rear caliper brackets
Audi B5 S4 rear vented brake disk
*(Porsche Boxter S Calipers; BIRA caliper brackets; Audi D2 A8 brake disk)
Chassis:
New PowerFlex Delrin Rear Diff Mount
New 034 Aluminum Sub frame Mounts
New 034 Density Line Motor Mounts
New OEM Transmission Mounts (front and rear)
S2 Strut Brace Mounts and Crossbar
Body/Exterior:
New paint job in 2003 Color: Espresso Mocha Black 033 (Car was parked inside and cover since then)
B4 Hood Conversion
S2 Headlights with 35W HID ballasts on low
S2 Front Bumper (imported from Europe)
S2 Rear Bumper (imported from Europe)
Euro License Plate Surround (imported from Europe)
Interior:
Factory Black Leather Seats in excellent condition
3 Spoke S-line Steering Wheel
VDO Boost Gauge (OEM style)
European door cards with trim
Digital Climate Control Unit (more control and reliability over stock electronic CC)
New heater core
DS Parcel Shelf conversion
I would like to say thank you for the support Ive got, especially to Greg W., Dave (hybrid_hatch), Chris and Nelson Serrano and of course for this forum and motorgeek as well. And not for last to my Gf, she is wonderful, helps and support my toy. Actually She gives me a hand with the tools, troubleshoot and provide good food
Thank you!
More pictures: http://quattro4life.com/images/project
Chris
Build Details
Engine:
034 Poly Snub Mount
AAN injectors
034 down-pipe
2Bennett coil-overs
New Tie rod ends
New Ball joints
Brake; Front:
Rear:
Chassis:
Body/Exterior:
B4 Hood Conversion
Interior:
New heater core
Thank you!More pictures: http://quattro4life.com/images/project
Chris
