I took the BLUE Pill. Engine bay painted
Re: I took the BLUE Pill. (Sean's Helios 83 UrQ)
Sweet!! With requiring 40% more fuel for teh same power, you may fill up 5 times in 2011
speeding-g60
Post by speeding-g60 »
hahahaha.
i didnt get to see this car, i was down there on late Sunday/Monday/early Tuesday too. looking for it just like each other time i spotted it driving around. :)
quattro v1.0
Post by quattro v1.0 »
a4kquattro wrote:heh. you'll be smoking the corn crack pipe in no time ;)
Marc, you'll have to come back and put a diff-blowin' tune on the Blue Pill like you did to James car at Glenwood! Wait til I have my torsen staged and ready to swap though.
Aaron, how long with this next project keep you in Vegas? Have a time frame to start?
quattro v1.0
I never got the car aligned after the suspension upgrades / before the Battle Born event. The car went down the road straight but was really twitchy, my basic checks of the rear end was that it was toe'd out. A bunch. This was cause form the prior owner / shop installing the rear tie rods upside down and them making contact with the underside of the chassis and bending at the threads. This not only kept the shop from adjusting them, but probably added some weird bump steer as well. Anyway, as stated in my want-ad, the first one I attempted to straighten broke. It was just too far beyond, and it was bent AT the threads.
I thought that between Martin and I, we had the last three NEW replacements in the World. He sold his pair, so I now have the last known new early tie rod on the planet? Go ME.
What I'd like to do is spearhead a project to develop a solution with available racing parts and get not only my car back on the road by Spring Mountain, but maybe get a couple others back on the road.
The angles will need to be pretty close to what you see below, as well as the little tweak at the subframe-end which helps to clear the subframe itself.
Maybe its as simple as what 034 has done for the later cars (4k's) but utilizing a different adjustment method due to the bends in the tie rod?
Like to hear some ideas and thoughts...
volvadi
Post by volvadi »
Thanks to Louis-Alain Richard from Audifans we know that the Geo Tracker ball joint is the same as the Urq and has the same 16x1.5mm thread. The Tracker turnbuckle is a bit long but can be turned down to fit the Urq. This is just FYI because I would guess that anyone that can make a new inner tie rod can probably make a custom turnbuckle also. Here is a picture of the Tracker parts on my Urq.
foxbat
Post by foxbat »
Sean, I started putting feelers out on Monday to find a local who can accomodate our wishes. Shouldn't be to tough.
Post by glibobbo21 »
The rod end goes into(fits) the hub as well?
Wow. that is really good information Sean. Do you have a specific model or part number for the tracker joint?
quattro v1.0
Hank, if I remember correctly, those discussions were about a 1990 model year tracker.
Greg - thanks for jogging my memory about those.
My issue is still a unique one since my ball joint is actually good, the rods themselves are bent (broke) to sh*t.
Sean, if they need a part in-hand I can provide one.
volvadi
Post by volvadi »
1990 Tracker/Samurai is correct.
http://www.audifans.com/pipermail/urq/2 ... 08818.html" onclick="window.open(this.href);return false; ... 08818.html
84urq20v
Post by 84urq20v »
quattro v1.0 wrote:[/quote]W/E I took a road trip to SLC / Park City in it as well... I think 6000 miles in ~6 years is just right. Don't hate just because my office is 5 miles from home - and I have at least two other cars to drive - and Im out of town roughly 2 weeks a month in some lame rental car.
If it makes y'all feel any better Im now officially on my 4th tank of gas for 2010, not that I'll finish it by years end though :slap: I remember just how painful it is to fill one of these cars, 19.6 gallons yesterday! I tried a new Rebel (76) station near me, I noticed they had 'that extra oddball colored nozzle' in the middle lane which I was hoping to be 100 octane. Come to find out when pulling in - it was E85.[/quote]
Unless I'm on a roadtrip I don't fill it more than half full. Sits in the tank too long - about a month - and its just extra weight to haul around. Heck half a tank is still 12 gallons!
Mentosman42
Post by Mentosman42 »
i run through a tank in a week and 1/2.
good ole CIS.
95.5 ur-S6
83 20vt urQ
quattro v1.0
Well I topped off my tank with 6 gallons of 100 octane and then came home and broke my car lol
I am draining a tank every 4-5 days, but I guess when you are consuming fuel at a rate of 7000cc/min at full tilt
Mentosman42
quattro v1.0 wrote:[/quote]Well I topped off my tank with 6 gallons of 100 octane and then came home and broke my car lol[/quote]
:slap:
95.5 ur-S6
83 20vt urQ
speeding-g60
i want this car.
quattro v1.0
Aaron, you just gotta catch me on one of those days...
Or when there is an Integrale' up for sale in the US hahah
Quattro Krant
Post by Quattro Krant »
Sean-have you ever dynoed this car? I'm curious to see what you are at hp wise. Someone wants me to build the 20vt in it while I want to just leave it as is and enjoy it for what it is.
quattro v1.0
I haven't dyno'd it yet. I really want to as I think its one of the strongest 20v's out there. The shop here in Vegas wasn't able to dyno it last fall due to the style of dyno and I haven't found any other true rolling-road dynos here in town.
If I start prepping a 20v for transplant it really wont be due to a lack of power of the 20v, mainly ease of service and smoothness of the engine itself.
I run it at a lazy 20psi around town and at the track. I have run it up to 24 a couple times and it felt like a totally different car.
speeding-g60
sounds mean as hell with an AWD clutch drop launch spooled up, too. :)
quattro v1.0
Aaron, that sounds quite out-of-character for me ;o)
Quattro Krant
I would imagine that 24psi would be pretty brisk. The 4kq with the VR6t in it now was quite fun with 12 psi and 034IIC on an MC2
Hybrid_Hatch
Post by Hybrid_Hatch »
quattro v1.0 wrote:[/quote]I haven't dyno'd it yet. I really want to as I think its one of the strongest 20v's out there. The shop here in Vegas wasn't able to dyno it last fall due to the style of dyno and I haven't found any other true rolling-road dynos here in town.[/quote]
there is one about 6 hours away... it is a heartbreaker though...
there is one about 6 hours away... it is a heartbreaker though...[/quote]
:drive: to 034!
Wheeljack
Post by Wheeljack »
I know a lot of the EVO guys use this one...
http://www.ddynopower.com
Doug's DynoPower P.O. Box 778072 Henderson, NV 89077
Phone (702) 617-1901 OR (702) 336-2275
http://brydon-eng.com
