Kennys UrS4 (Volvo turbo to ???? Turbo Built engine)
Postby morris400 » Sat May 11, 2013 2:54 pm
:drive: Hello guys, I've been in the audi Scene for about 5 years now, lots of ups and even more downs, I used to have a 2001 B5 S4 until Apr 15 when I blew the motor, car was my baby as much as it could be. It was a stage 3- with BW K04s and tuned by jfonz. After the motor blew I sold her as is for 3k.
Cyl4 spark plug
Cyl4
After this I then picked up a 1994 UrS4 100% stock with 199km. Needs a few things but nothing major. Engine runs amazing, interior amazing.
I've done a couple mods so far, I've added a boost gauge and blacked out the front grille, also ordered a new shift boot.
I've had one of these on ever car I own, this one will be no different.
I'm loving the new car, needs a cupple things like I said. Small oil leak ( I will find it when I change the oil) needs new mounts cause there still stock and lots of play. And she idles around 950 with AC on but normal when AC off.
Other then that I'm happy with the new car. :rofl:
2016 VW GTI DSG Daily Driver
1994 UrS4 - K24 7400 EFI tuned ( EFR build in progress )
2001 B5 S4 Stg 3- (Gone)
morris400
Re: My introduction (UrS4)
Postby morris400 » Sun May 12, 2013 9:25 am
I'm 99% sure I found my oil leak, it's coming from the oil pan. I'm gonna have to get this fixed. First repair bill in the way. Lol
morris400
Postby ringbearer » Sun May 12, 2013 9:41 am
Make sure all the oil pan bolts are tight and present. Sometimes they come loose BTDT on unopened engines.
Clean everything too so you can pinpoint where the leaks are.
Postby mushasho » Sun May 12, 2013 7:32 pm
Super happy you joined!
And soon you'll realize the joy of diagnosing a UrS vs the B5S4 & the ease of repairing it yourself too... I've had both and feel I made the right choice in sticking to UrS cars...
UglyUr 2.5L 95mm Stroker
Postby mushasho » Sun May 12, 2013 7:36 pm
And be sure to check out the Project section... Lots of cool stuff there...
Postby PRY4SNO » Sun May 19, 2013 1:46 pm
Kenny! You found the spot where the cool kids hang out, I see.
One other thing to check with the oil leak is the crush washer on the drain plug. Might have been reused.
If you need a new oil pan after all, I have one you can buy for cheap. :)
Postby morris400 » Mon May 20, 2013 12:15 pm
I may take you up on that offer, I'm gonna be doing a oil change maybe tonight and ill clean the area with brake cleaner and see if I can find a noticeable leak. It's been a cupple drops over night but nothing real bad. Took a look under and saw the oil pan had oil on it. I'm still good for tomorrow to swing by in the morning time say 10 ish.
morris400
Postby Kuma » Sat May 25, 2013 10:44 pm
i must say, i like you even more since you support our troops.
Kuma
Postby Mentosman42 » Sun May 26, 2013 9:31 am
if the oil leak is on the driver side of the engine also check the oil dummy light sender, they can leak and drip oil. I had one that was pissing a stream at one point.
95.5 ur-S6
83 20vt urQ
Mentosman42
Postby morris400 » Sun May 26, 2013 3:39 pm
Kuma wrote:i must say, i like you even more since you support our troops.
I also serve, since 2007 I've been in the Canadian military,
2007-2010 with 1 PPCLI ( princess patricas canadain light infantry)
2011-now with 1 signal sqn.
I've meet some amazing people in the last 5 years since I joined, made some amazing friends and lost a few as well.
morris400
Postby morris400 » Thu Jun 20, 2013 6:04 pm
I picked up a new set of oil pan bolts today. I noticed at least one missing when I changed the oil last week ish
morris400
Postby Kuma » Fri Jun 21, 2013 9:36 am
That's incredible, observed with Canadians, Dutch, and some Ozzies when I was overseas. Great people and soldiers.
Kuma
Postby morris400 » Mon Jun 24, 2013 8:06 pm
Tonight I fixed my pwr steering leak, and replaced the 8 missing oil pan bolts...and tightend another 3-4 that were extremely loose.
morris400
Postby EDIGREG » Tue Jun 25, 2013 7:52 am
8 missing? LOL wow that thing was about to fall off.
Postby PRY4SNO » Tue Jun 25, 2013 10:34 am
How'd you deal with the PS leak, buy the fancy dancy tool or use the ol' screwdriver & hammer?
Postby morris400 » Tue Jun 25, 2013 2:26 pm
i was able to borrow a drag link from work, then file down the corners and it worked. new screw comes in tomorrow from audi. hammer and screw driver was not working as it was fucking up the screw. all i did was use the teflon tape untill the new oring arrives.
im sure it was about to fall off lol.. bottom of car is covered in oil right now ill need to clean that up the next cupple days. i think the PO masked some issues with the car that are coming out now. im a little pissed but ill take it one step at a time and fix ther small things. the turbo is making some sounds it probally should not ( dentist drill ). i checked for shaft play on the cold side and found some but not much. at least this turbo can be swaped in a matter of mins over the B5S4.
morris400
Postby morris400 » Tue Jul 02, 2013 10:03 am
picked up a set of B5 S4 wheels this past weekend, im debating on which color to plastidip them. also looking into engine mounts as well as mine are pertty bad.
morris400
Postby mushasho » Tue Jul 02, 2013 3:22 pm
Need motor mounts?
Postby morris400 » Tue Jul 02, 2013 5:17 pm
mushasho wrote:Need motor mounts?
Yea I sure do, and tranny mounts and all mounts. I have a lot of drivetrain play.
morris400
Postby mushasho » Wed Jul 03, 2013 6:46 am
Go thru my thread to see what's been done for mounts...
Postby morris400 » Wed Jul 03, 2013 11:03 pm
You use the jegs ones?
morris400
Postby mushasho » Thu Jul 04, 2013 5:23 pm
morris400 wrote:You use the jegs ones?
Jegs or summit is fine...
Postby morris400 » Sat Jul 06, 2013 6:46 pm
Changed the front end a bit today. Thoughts?
morris400
Postby morris400 » Sat Aug 10, 2013 4:56 pm
Today I changed my valve cover and new gasket, also installed a new tps sensor.
morris400
Postby morris400 » Sat Sep 14, 2013 4:38 pm
I've done a bit more since I updated last.
Did some more painting in the bay, swaped out my DV and installed my 17s and sold my 18s.
And for the next thing, I'm working a a new PCV system.
morris400
Next
Return to Projects
Users browsing this forum: AudiSport4000 and 15 guests
cron
