Hank wrote:Dude, ping the developers for dual outputs!!!!!! I must have this!
looks like there is quite a lot to do to make that work. what it would do is repurpose the serial interface that is currently used for the GPS feature in vems, but its currently RX only.
What you *can* do, is take your current serial setup you are using for your AIM, remove the TX pin, and 't' the ground and RX, wired to this bluetooth module. that will allow two AIM stream devices to talk at the same time without messing up the stream. For instance for your MXL and an android display simultaneous.
