FS: 996 Turbo/C4S/997S Rear Brake Calipers - Price drop
SEStone
Post by SEStone »
I got a full set of 996 Turbo brakes, and will only be using the fronts. Not sure if anyone is interested in the rears, but I'm ready to let go of them.
I removed these myself from a 2003 911 Turbo to install 997 Turbo brakes on it as an upgrade. They are in great shape as far as finish and function, with only a few minor scratches. Seals are in good condition. They come with pads but they are nearly down to the wear sensor. The wear sensors are installed bu the connectors are clipped off.
They are monoblock calipers, same shape externally as the popular Boxster S/996 front calipers, only with 30/36mm pistons installed and smaller mounting pads I believe. The rear rotors are 330x28mm stock.
Looking for $250 shipped for the pair, email me at sstone@imolamotorsports.com or contact me here if interested.
Sam
Sam Stone
SEStone
Re: FS: 996 Turbo/C4S/997S Rear Brake Calipers
Post by SEStone »
Bump, price drop.
Sam
Sam Stone
SEStone
Re: FS: 996 Turbo/C4S/997S Rear Brake Calipers - Price drop
Post by SEStone »
Current pic:
Pads have 20-30% left, a fair bit more...they could be run for a little while before needing replacement. I checked and these do have the standard 130mm caliper spacing, so same casting as the 996 C2 fronts just with smaller pistons. They would need a caliper bracket made to work with any VW/Audi, front or rear.
Sam
Sam Stone
SEStone
Post by SEStone »
Sold! To some guy with a red car
Sam Stone
